WDS
  1. WDS replied to a post in a topic in ISY994
    Thanks for your help. Please forgive my ignorance as I'm really new to this product. I'm not using any software. What is an ISY? The basic instructions do not indicate that any additional software is required to link the switch to the remote. They indicate that if I follow the instructions described above that the two should pair up, but they don't seem to be seeing each other via that process. If I need to install some software, can you direct me to a link for it? EDIT: I see now where the confusion may lie. I thought this was the Insteon forum, but it's clearly just for ISY users (I just looked up what an ISY is). My apologies. I have moved my request to the Insteon forum. Thanks for your help!
  2. WDS replied to a post in a topic in ISY994
    Thanks for your quick response! Following the basic linking instructions (from memory here): 1) Tap the 2444A3 Switchlinc2 remote on the "on" side of the paddle. 2) Put the 2476S switch into the mode for which I want to set the "scene". In this case "on". 2) Press and hold the linking button on the bottom of the 2444A3. Remote beeps and green light starts blinking. 3) Press the linking button on the bottom of the 2476S. 2476S beeps and starts blinking. 4) At this point they're supposed to link up, but both just blink at each other until I cancel the operation or they time out. I have tried this with two 2444A3 and a 2444A4. None have connected. Right now my 2476S is functioning as a $45 light switch, which is $44.25 too much to pay for a light switch.
  3. WDS replied to a post in a topic in ISY994
    I have an 2476s installed and so far two different RL2 2444A3 refuse to recognize it. Is there a model mismatch?
