raypanic
  1. raypanic replied to raypanic's topic in ISY994
    I ran the PLM restore program it took most the day but now all seems fine. thanks for the tips and help. Not sure what happend to the 99I but it seems something is wrong on the com side of the system going to the PLM. I will be testing the 2314 to se if that is the problem. then I will have a 99i I can sell on e-bay.
  2. raypanic replied to raypanic's topic in ISY994
    I bought new unit and it works, kind of. on off commands work very quick but changin the ramp rate takes minuites. something is wrong. I got new unit and PLM from SH as a kit ($400.00 IN ALL) hooked it up to ethetnet and plugged in PLM. started 99 console and it hooked up and seemed to work fine. restored database from backup to new system and it all seemed to be there and working fine for on/off commands. I did noting to PLM to add it I just plugged it in. After problem with long times then i tried to restore PLM and the it never completed. just box says system busy.... ramp rates in switch do program eventually. Looking for some ideas.
  3. isy
    Thank you do you know if I use the back ups from the old to the new unit?
  4. isy
    raypanic posted a topic in ISY994
    still not working, manual on 2413 has no testing info, The isy seems to work ok but system does not send or receive any traffic. when I first noticed problem the lan lights on this port were not working. So lan port on isy may be bad or the 2413 is blown. any help would be helpfull on the reset/testing of the PLM/PLC Combiniation
  5. raypanic replied to raypanic's topic in ISY994
    still not working, manual on 2413 has no testing info, The isy seems to work ok but system does not send or receive any traffic. when I first noticed problem the lan lights on this port were not working. So the PLC port on isy may be bad or the 2413 is blown. any help would be helpfull on the reset/testing of the PLM/PLC Combiniation
  6. raypanic replied to raypanic's topic in ISY994
    2413S PLC is what I have I am looking for manual right now fro, SH.
  7. raypanic replied to raypanic's topic in ISY994
    Yes PLM.. My mind error
  8. raypanic replied to raypanic's topic in ISY994
    Sorry dont use forums very well. No LED at all even on the RJ45 this includes the PWR
  9. raypanic replied to raypanic's topic in ISY994
    I put power on the power jack and now it lights and it works fine from the network side... i am trying to get it control lights and such but nothing, maybe the PLC is bad. All LEDs work fine even the rj45 plug. Now see if I can fix the PLC
  10. raypanic replied to raypanic's topic in ISY994
    I try one of these ideas otherwise its junk right? is there a chip inside you can plug into the mew one?
  11. raypanic replied to raypanic's topic in ISY994
    what is the voltage input on the i99?
  12. raypanic posted a topic in ISY994
    I think my i99 is dead, with multicables and other ports still dead. isy-ir pr sn/005214 ray
  13. Still wont program, must be broke other one programmed fine.
  14. Ah Thank you! I see it now, I casually looked the other day but missed it. I even read the revision number printed on the sticker but it never registered the other numbers were the address. Always the simple things...... Thanks Ray
  15. I have a Remote link 2440 that stopped working and am trying to restore the links to it. When changing a link or trying to restore it the program times out and nothing changes. So in trying to start fresh I deleted the 2440 from the data base and I use the Link management/Link a remote link/ program but no Inseton address pop up in the address box. I hold the dim and bright as instructed. No link. I also can link the 2440 to other switches manually without using ISY and it works so i know it is transmitting and communicating. I also reset the 2440 to factory setting by taking out the batteries and holding the bright on reinsertion of the battery. I have anothe 2440 and it will program by isy when making changes and works fine but also will not show up in the address field when trying to linkk t ti the ISY I have not unpowered the ISY or PLM I have a ISY99i, 2.7.0, using a iMAC, and the Java work around. Any help would be great
