girgises
  1. I just recently installed the network module, mainly for Sonos, and I was able to integrate it well using the zip file that was provided in another post. I also have a Pioneer VSX - 822 so I figured I would make use of the module and integrate it as well. I tried to import the zip file that is listed but for some reason it will not import (tried several times). I tried to follow the step by step to send the commands to the receiver but that did not work either. I found that I could telnet to the receiver using port 8102 and sending the commands through PuTTY telnet works perfectly. Does anyone know how to send these commands through the network module? I'm not sure but I think that the other Pioneer modules may have a network GUI to send commands. This receiver has a minimal GUI that does not accept any commands and really has no control value. Thanks for any help in advance. Update** So I figured out that you can integrate the VSX - 822K using port 8102. I also figured out to use the Dennon commands that are listed in this forum (download and import the zip file) and using the Pioneer commands that are also in this forum. Still can't figure out how to use Pandora. Haven't been able to find the commands for Pandora other than to switch to the Pandora input but can't get it to play.
