fuentesa
Everything posted by fuentesa
  1. Hi: My isy 99i stop working last week. I tried a couple of suggestions with no luck; and finally decide to upgrade to a new 994. Unfortunately I didn't have a recent backup of the isy. Is there any way to get a backup from the sd card? I'm able to read from the sd card. Sent from my iPad using Tapatalk
  2. It seems that you also change your router. Your ISY is probably configured to use DHCP address instead of a static one. As long as you don't disconnect your iSY for too long; it will came with the same address. However if you want to assure that it always have the same IP; you need to configure a static IP in your ISY. Just go to network settings and select static IP. It is important that the IP that you assign be in the same subnet as your router. It seems that your old router was using 192.168.1.x and the new one is using 192.168.3.x.
  3. fuentesa replied to Dodger's topic in ISY994
    Are you using your browser in Full Screen? I get the same problem in Full Screen. Try using safari in a normal window.
  4. I was thinking of something similar. I don't know if it will introduce some lag to the response though. Is there an option for you to manually select the type of EZIO40? Small or Large? Probably for a future version?
  5. Thanks for your help... I will contact smarthome for a replacement, I just purchase this unit 3 weeks ago...
  6. When I add the link manually, the shn utility shows thet link when set in the small database, it didn't show if I select the large database. The links that ISY creates shows only when I select the large database.
  7. I reset the EZI to defaults and added again to ISY. This is the log when I added the EZIO40 to the ISY and added it to a scene. Gate-4 was added to "Open Gate" Scene. When the scene is activated the EZIO40 does not activate, however if I turn the only device to ON it operates. Thu 03/08/2012 09:43:20 PM : ---- Initializing the linked devices ---- Thu 03/08/2012 09:43:20 PM : ---- All Linked Devices are now initialized ---- Thu 03/08/2012 09:43:20 PM : ---- Add remaining devices ---- Thu 03/08/2012 09:43:20 PM : [1 72 18 1 ] Calculating EZxx Address Offset Thu 03/08/2012 09:43:20 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:20 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:43:21 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:43:21 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:21 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:21 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:43:21 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:21 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:21 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:43:22 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:43:22 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:22 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:22 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF) Thu 03/08/2012 09:43:22 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:22 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:22 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:43:23 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:23 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:43:23 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:23 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:23 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:43:23 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:43:24 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:24 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:24 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:43:24 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:24 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 01 06 POKE (01) Thu 03/08/2012 09:43:24 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 01 POKE (01) Thu 03/08/2012 09:43:24 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:24 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:25 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:43:25 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:43:25 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:25 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:25 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF) Thu 03/08/2012 09:43:25 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:26 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 02 06 POKE (02) Thu 03/08/2012 09:43:26 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 02 POKE (02) Thu 03/08/2012 09:43:26 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:26 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:26 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:43:26 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:43:26 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:27 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:27 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:43:27 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:27 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03) Thu 03/08/2012 09:43:27 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:43:27 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:27 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:28 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:43:28 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:43:28 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:28 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:28 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01) Thu 03/08/2012 09:43:28 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:28 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:29 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:43:29 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:43:29 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:29 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:29 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02) Thu 03/08/2012 09:43:29 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:29 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:30 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:43:30 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:43:30 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:30 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:30 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03) Thu 03/08/2012 09:43:30 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:30 PM : [1 72 18 1 ] EZxx Address Offset at 3FFF Thu 03/08/2012 09:43:30 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:31 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:43:31 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:43:31 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:31 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:31 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01) Thu 03/08/2012 09:43:31 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:32 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00) Thu 03/08/2012 09:43:32 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00) Thu 03/08/2012 09:43:32 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:32 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:32 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:43:32 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:43:32 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02) Thu 03/08/2012 09:43:33 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 FF 06 POKE (FF) Thu 03/08/2012 09:43:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 FF POKE (FF) Thu 03/08/2012 09:43:33 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:33 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:43:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:43:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:43:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:43:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03) Thu 03/08/2012 09:43:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00) Thu 03/08/2012 09:43:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00) Thu 03/08/2012 09:43:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:35 PM : [ 1 72 18 1] Writing High Water Mark at Link 0 Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Querying engine version Thu 03/08/2012 09:43:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 0D 00 06 (00) Thu 03/08/2012 09:43:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 0D 01 (01) Thu 03/08/2012 09:43:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Retrieved engine version is i2 Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] Calibrating engine version ensuring support for i2 Thu 03/08/2012 09:43:35 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:43:36 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Thu 03/08/2012 09:43:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00) Thu 03/08/2012 09:43:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:45 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:43:45 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Thu 03/08/2012 09:43:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00) Thu 03/08/2012 09:43:45 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:54 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:43:54 PM : [iNST-ACK ] 02 62 01.72.18 1F 2F 00 00 00 3F FF 01 00 00 00 00 00 00 00 00 00 06 (00) Thu 03/08/2012 09:43:55 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2F 00 (00) Thu 03/08/2012 09:43:55 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] i2 data transfer commands do not work. Reverting to i1 Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] Using engine version i1 Thu 03/08/2012 09:43:59 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:43:59 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:43:59 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:43:59 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:43:59 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F8 06 PEEK (F8) Thu 03/08/2012 09:44:00 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:44:00 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:00 PM : [ 1 72 18 1] Adding device to ISY t=07.08.0000 Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Start : Adding device to ISY Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Finish : Adding device to ISY was Successful Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:00 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:00 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:44:00 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:44:00 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:00 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:01 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:44:01 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:01 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:01 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:44:01 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:44:01 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:01 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:02 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF) Thu 03/08/2012 09:44:02 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:02 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:02 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:44:02 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:44:02 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:02 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:03 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:44:03 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:03 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:03 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:44:03 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:44:03 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:03 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:03 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:44:03 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:04 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 01 06 POKE (01) Thu 03/08/2012 09:44:04 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 01 POKE (01) Thu 03/08/2012 09:44:04 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:04 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:04 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:44:04 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:44:04 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:05 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:05 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B FF PEEK (FF) Thu 03/08/2012 09:44:05 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:05 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 02 06 POKE (02) Thu 03/08/2012 09:44:05 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 02 POKE (02) Thu 03/08/2012 09:44:05 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:05 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:06 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:44:06 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:44:06 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:06 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:06 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:44:06 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:07 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03) Thu 03/08/2012 09:44:07 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:44:07 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:07 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:07 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:44:07 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:44:07 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:08 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:08 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01) Thu 03/08/2012 09:44:08 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:08 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:08 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:44:08 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:44:08 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:09 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:09 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02) Thu 03/08/2012 09:44:09 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:09 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:09 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:44:09 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:44:09 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:10 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:10 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03) Thu 03/08/2012 09:44:10 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:10 PM : [1 72 18 1 ] EZxx Address Offset at 3FFF Thu 03/08/2012 09:44:10 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:10 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:44:10 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:44:10 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:11 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:11 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 01 PEEK (01) Thu 03/08/2012 09:44:11 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:11 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00) Thu 03/08/2012 09:44:11 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00) Thu 03/08/2012 09:44:11 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:11 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:12 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 1F 06 SET-MSB(1F) Thu 03/08/2012 09:44:12 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 1F SET-MSB(1F) Thu 03/08/2012 09:44:12 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:12 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:12 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 02 PEEK (02) Thu 03/08/2012 09:44:12 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:13 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 FF 06 POKE (FF) Thu 03/08/2012 09:44:13 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 FF POKE (FF) Thu 03/08/2012 09:44:13 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:13 PM : [1 72 18 1 ] EZxx start address at 0x0FFF Thu 03/08/2012 09:44:13 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:44:13 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:44:13 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:14 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:44:14 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03) Thu 03/08/2012 09:44:14 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:14 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 00 06 POKE (00) Thu 03/08/2012 09:44:14 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 00 POKE (00) Thu 03/08/2012 09:44:14 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:14 PM : [1 72 18 1 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:15 PM : [iNST-ACK ] 02 62 01.72.18 0F 4D 44 06 (44) Thu 03/08/2012 09:44:15 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4D 44 (44) Thu 03/08/2012 09:44:15 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:15 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 02 06 IOCTL (QUERY) Thu 03/08/2012 09:44:15 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 00 IOCTL (00) Thu 03/08/2012 09:44:15 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:15 PM : [ 1 72 18 1] ST 0 Thu 03/08/2012 09:44:16 PM : [iNST-ACK ] 02 62 01.72.18 0F 49 00 06 RINPUT (00) Thu 03/08/2012 09:44:16 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 49 00 RINPUT (00) Thu 03/08/2012 09:44:16 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Start : Adding device to ISY Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Finish : Adding device to ISY was Successful Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:16 PM : [1 72 18 2 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Start : Adding device to ISY Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Finish : Adding device to ISY was Successful Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:16 PM : [1 72 18 3 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Start : Adding device to ISY Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Finish : Adding device to ISY was Successful Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:16 PM : [1 72 18 4 ] Calculating EZxx Address Offset Thu 03/08/2012 09:44:17 PM : [1 72 18 1 ] Device added to ISY Thu 03/08/2012 09:44:17 PM : ---- All Remaining Device Added ---- Thu 03/08/2012 09:44:17 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 02 06 IOCTL (QUERY) Thu 03/08/2012 09:44:18 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 00 IOCTL (00) Thu 03/08/2012 09:44:18 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:18 PM : [ 1 72 18 1] ST 0 Thu 03/08/2012 09:44:18 PM : [ 1 72 18 2] ST 0 Thu 03/08/2012 09:44:18 PM : [ 1 72 18 3] ST 0 Thu 03/08/2012 09:44:18 PM : [ 1 72 18 4] ST 0 Thu 03/08/2012 09:44:18 PM : [iNST-ACK ] 02 62 01.72.18 0F 49 00 06 RINPUT (00) Thu 03/08/2012 09:44:18 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 49 00 RINPUT (00) Thu 03/08/2012 09:44:18 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:44:18 PM : [All ] Writing 0 bytes to devices Thu 03/08/2012 09:45:32 PM : [Gate - 4] Start : Adding to scene 'Open Gate' Thu 03/08/2012 09:45:32 PM : [Gate - 4] Making 'Open Gate' a Controller Thu 03/08/2012 09:45:32 PM : [MNG-LNK-RSP ] 02 6F 40 E2 15 01 72 18 07 08 00 06 Thu 03/08/2012 09:45:32 PM : [1 72 18 4 ] Link 0 : 0FF8 [A2151982E7000003] Saving [A2151982E7000003] Thu 03/08/2012 09:45:32 PM : [Gate - 4] Making 'CocinaOpen' a Controller Thu 03/08/2012 09:45:33 PM : [19 21 CE 3 ] Link 9 : 0FB0 [E203017218FF1F03] Saving [E203017218FF1F03] Thu 03/08/2012 09:45:33 PM : [1 72 18 4 ] Link 1 : 0FF0 [A2031921CE000003] Saving [A2031921CE000003] Thu 03/08/2012 09:45:33 PM : [Gate - 4] Finish : Adding to scene 'Open Gate' was Successful Thu 03/08/2012 09:45:33 PM : [All ] Writing 25 bytes to devices Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] Using engine version i1 for 'Gate' Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] Link 2 : 0FE8 [0000000000000000] Writing [00..............] Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:33 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:33 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:33 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:33 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B E8 06 PEEK (E8) Thu 03/08/2012 09:45:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:34 PM : [1 72 18 1 ] Link 3 : 0FE0 : Writing High Water Byte Thu 03/08/2012 09:45:34 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:34 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:34 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:34 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B E0 06 PEEK (E0) Thu 03/08/2012 09:45:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] Using engine version i1 for 'Gate' Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] Link 0 : 0FF8 [A2151982E7000003] Writing [A2151982E7000003] Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:35 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:35 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:35 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:35 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F8 06 PEEK (F8) Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:36 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 A2 06 POKE (A2) Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 A2 POKE (A2) Thu 03/08/2012 09:45:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:36 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:36 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F9 06 PEEK (F9) Thu 03/08/2012 09:45:36 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 15 PEEK (15) Thu 03/08/2012 09:45:36 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:36 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:37 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:37 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:37 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:37 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FA 06 PEEK (FA) Thu 03/08/2012 09:45:37 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 19 PEEK (19) Thu 03/08/2012 09:45:37 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:37 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:38 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:38 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:38 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:38 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FB 06 PEEK (FB) Thu 03/08/2012 09:45:38 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 82 PEEK (82) Thu 03/08/2012 09:45:38 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:38 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:39 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:39 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:39 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:39 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FC 06 PEEK (FC) Thu 03/08/2012 09:45:39 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B E7 PEEK (E7) Thu 03/08/2012 09:45:39 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:39 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:40 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:40 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:40 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:40 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FD 06 PEEK (FD) Thu 03/08/2012 09:45:40 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:40 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:40 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:41 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:41 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:41 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:41 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FE 06 PEEK (FE) Thu 03/08/2012 09:45:41 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:41 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:41 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:42 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:42 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:42 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:42 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B FF 06 PEEK (FF) Thu 03/08/2012 09:45:42 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:42 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:43 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03) Thu 03/08/2012 09:45:43 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:45:43 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:43 PM : [MNG-LNK-RSP ] 02 6F 40 E2 15 01 72 18 07 08 00 06 Thu 03/08/2012 09:45:43 PM : [PLM ] Group 21 : Writing Controller Link matching [1 72 18 1 ] Link 0 : 0FF8 [A2151982E7000003] Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] Using engine version i1 for 'Gate' Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] Link 1 : 0FF0 [A2031921CE000003] Writing [A2031921CE000003] Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:43 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:44 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:44 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:44 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:44 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F0 06 PEEK (F0) Thu 03/08/2012 09:45:44 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:44 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:45 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 A2 06 POKE (A2) Thu 03/08/2012 09:45:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 A2 POKE (A2) Thu 03/08/2012 09:45:45 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:45 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:45 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F1 06 PEEK (F1) Thu 03/08/2012 09:45:45 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 03 PEEK (03) Thu 03/08/2012 09:45:45 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:45 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:46 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:46 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:46 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:46 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F2 06 PEEK (F2) Thu 03/08/2012 09:45:46 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 19 PEEK (19) Thu 03/08/2012 09:45:46 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:46 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:47 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:47 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:47 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:47 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F3 06 PEEK (F3) Thu 03/08/2012 09:45:47 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 21 PEEK (21) Thu 03/08/2012 09:45:47 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:47 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:48 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:48 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:48 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:48 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F4 06 PEEK (F4) Thu 03/08/2012 09:45:48 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B CE PEEK (CE) Thu 03/08/2012 09:45:48 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:48 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:49 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:49 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:49 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:49 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F5 06 PEEK (F5) Thu 03/08/2012 09:45:49 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:49 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:49 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:49 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:50 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:50 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:50 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F6 06 PEEK (F6) Thu 03/08/2012 09:45:50 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:50 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:50 PM : [1 72 18 1 ] EZxx start address at 3FFF Thu 03/08/2012 09:45:50 PM : [iNST-ACK ] 02 62 01.72.18 0F 28 3F 06 SET-MSB(3F) Thu 03/08/2012 09:45:51 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 28 3F SET-MSB(3F) Thu 03/08/2012 09:45:51 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:51 PM : [iNST-ACK ] 02 62 01.72.18 0F 2B F7 06 PEEK (F7) Thu 03/08/2012 09:45:51 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:51 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:51 PM : [iNST-ACK ] 02 62 01.72.18 0F 29 03 06 POKE (03) Thu 03/08/2012 09:45:52 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:45:52 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:52 PM : [iNST-ACK ] 02 62 01.72.18 0F 4F 01 06 IOCTL (01) Thu 03/08/2012 09:45:52 PM : [iNST-SRX ] 02 50 01.72.18 19.82.E7 2B 4F 01 IOCTL (01) Thu 03/08/2012 09:45:52 PM : [standard-Direct Ack][01.72.18-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:52 PM : [1 72 18 1 ] Memory : EPROM Refreshed Thu 03/08/2012 09:45:52 PM : [19 21 CE 1 ] Using engine version i1 for 'Cocina' Thu 03/08/2012 09:45:52 PM : [19 21 CE 1 ] Link 10 : 0FA8 [0000000000000000] Writing [00..............] Thu 03/08/2012 09:45:52 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:45:53 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:45:53 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:53 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B A8 06 PEEK (A8) Thu 03/08/2012 09:45:54 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:54 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:54 PM : [19 21 CE 1 ] Link 11 : 0FA0 : Writing High Water Byte Thu 03/08/2012 09:45:54 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:45:55 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:45:55 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:55 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B A0 06 PEEK (A0) Thu 03/08/2012 09:45:56 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 00 PEEK (00) Thu 03/08/2012 09:45:56 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:56 PM : [19 21 CE 1 ] Using engine version i1 for 'Cocina' Thu 03/08/2012 09:45:56 PM : [19 21 CE 1 ] Link 9 : 0FB0 [E203017218FF1F03] Writing [E203017218FF1F03] Thu 03/08/2012 09:45:56 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:45:56 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:45:56 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:56 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B0 06 PEEK (B0) Thu 03/08/2012 09:45:57 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B E2 PEEK (E2) Thu 03/08/2012 09:45:57 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:57 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:45:57 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:45:57 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:57 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B1 06 PEEK (B1) Thu 03/08/2012 09:45:58 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 06 PEEK (06) Thu 03/08/2012 09:45:58 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:58 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 03 06 POKE (03) Thu 03/08/2012 09:45:58 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:45:58 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:58 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B2 06 PEEK (B2) Thu 03/08/2012 09:45:59 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 01 PEEK (01) Thu 03/08/2012 09:45:59 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:59 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:45:59 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:45:59 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:45:59 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B3 06 PEEK (B3) Thu 03/08/2012 09:46:00 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 72 PEEK (72) Thu 03/08/2012 09:46:00 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:00 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:46:01 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:46:01 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:01 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B4 06 PEEK (B4) Thu 03/08/2012 09:46:02 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 18 PEEK (18) Thu 03/08/2012 09:46:02 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:02 PM : [iNST-ACK ] 02 62 19.21.CE 0F 28 0F 06 SET-MSB(0F) Thu 03/08/2012 09:46:03 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 28 0F SET-MSB(0F) Thu 03/08/2012 09:46:03 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:03 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B5 06 PEEK (B5) Thu 03/08/2012 09:46:04 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 05 PEEK (05) Thu 03/08/2012 09:46:04 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:04 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 FF 06 POKE (FF) Thu 03/08/2012 09:46:04 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 FF POKE (FF) Thu 03/08/2012 09:46:04 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:04 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B6 06 PEEK (B6) Thu 03/08/2012 09:46:05 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 1C PEEK (1C) Thu 03/08/2012 09:46:05 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:05 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 1F 06 POKE (1F) Thu 03/08/2012 09:46:05 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 1F POKE (1F) Thu 03/08/2012 09:46:05 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:05 PM : [iNST-ACK ] 02 62 19.21.CE 0F 2B B7 06 PEEK (B7) Thu 03/08/2012 09:46:06 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 2B 06 PEEK (06) Thu 03/08/2012 09:46:06 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:46:06 PM : [iNST-ACK ] 02 62 19.21.CE 0F 29 03 06 POKE (03) Thu 03/08/2012 09:46:07 PM : [iNST-SRX ] 02 50 19.21.CE 19.82.E7 2B 29 03 POKE (03) Thu 03/08/2012 09:46:07 PM : [standard-Direct Ack][19.21.CE-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Thu 03/08/2012 09:50:12 PM : [iNST-ACK ] 02 62 00.00.15 CF 11 00 06 LTONRR (00) Thu 03/08/2012 09:50:12 PM : [ 19 21 CE 3] ST 255 Thu 03/08/2012 09:50:12 PM : [ 1 72 18 4] ST 255
  8. I added it using the new insteon device, enter the device address and selecting the device type as a EZIO40 from the list. It was added successfully and the four outputs were displayed. I will post the event log when once I get home.
  9. I'm having the same problems with an EZIO40. It shows on ISY as a v.00. I can control the outputs directly but they didn't respond to the scenes command. It work if I establish the link manually. The link was added mannualy does not appears when in the device link table. When I connect to the EZI using the SHN software it displays as a version 28 and shows as a large memory device. I just purchase the EZI last month, so the version should be recent, however I haven't found what is the most recent version. The version of ISY is 3.1.17. The links begins at memory 0FF8. Any help?
