pmoeller
Everything posted by pmoeller
  1. pmoeller replied to pmoeller's topic in Polisy
    Wow after 4 hours it seems to have shown up. Still not in finder.
  2. pmoeller posted a topic in Polisy
    Polisy has been moved to a new network after a move. Cannot find it anywhere. ARP no mac address. Can't add it in finder. Nothing is really on Polisy. Have tried to get back to factory defaults etc, no luck. Any help would be appreciated.
  3. Which gets the hot wire from the box, Red or Black?
  4. Thank you I'll work on that. It's been a long time since I replaced any of these devices.
  5. No it doesn't. It's a new switch, but I will try another new switch. The wires ore on the same way as before(I hope). Scene only has two devices in it, both set as controllers. One device is a dimmer and the other is a 5 button.
  6. thank you ramp rate is set to .1 seconds.
  7. Hi Bill When I added the devices I had the system erase the links. Is that enough? Light does not turn on manually. The LEDs functon, just no light.
  8. Reset them both to controllers. Same problem Here's the event Viewer Mon 07/05/2021 04:25:44 PM : [INST-TX-I1 ] 02 62 00 00 14 CF 11 00 Mon 07/05/2021 04:25:44 PM : [INST-ACK ] 02 62 00.00.14 CF 11 00 06 LTONRR (00) Mon 07/05/2021 04:25:44 PM : [D2D EVENT ] Event [53 48 11 6] [ST] [255] uom=100 prec=0 Mon 07/05/2021 04:25:44 PM : [ 53 48 11 6] ST 255 (uom=100 prec=0) Mon 07/05/2021 04:25:44 PM : [D2D EVENT ] Event [52 97 C9 1] [ST] [255] uom=100 prec=0 Mon 07/05/2021 04:25:44 PM : [ 52 97 C9 1] ST 255 (uom=100 prec=0) lem.
  9. Have a ISY994I, replaced 2 devices, a 2477D and a 2334-232. The LEDs respond to commands, but the light will not turn on. They are in a scene and acting as a 2-way switch. I have worked on this problem for 6 hours but have found no solution. Anybody see an answer?
  10. Thanks to you both! Cleared event viewer and wrote to switch. No entries, I assume that means no communication. Then ran restore, which I have done several times before, however this time it worked and we are finally back to normal. Again thanks for your great help.
  11. buttons are configured in scenes, no programs. Buttons are controllers. All buttons have the write icon next to them. I have executed the write commands and the system writes, but the write icon remains. Techman: I replaced a 6 button with a 6 button
  12. Just Replaced 2486D with 2334-2. Main switch works, but A, B, C, and D buttons do not. When I press a button the links(commands} do not execute. Any thoughts?
  13. pmoeller replied to pmoeller's topic in ISY994
    Thanks for your help all is now back to normal.
  14. pmoeller replied to pmoeller's topic in ISY994
    Everything you said was correct. Restored device and the scene worked. Now running restore devices. Hopefully this will do it. Thanks for your help. I'll let you know how it turns out.
  15. pmoeller replied to pmoeller's topic in ISY994
    Restored from old backup. 414 links. Restored PLM. Scenes still don't work. Ran scene trace below. Wed 05/22/2013 08:01:07 AM : [GRP-RX ] 02 61 34 13 00 06 Wed 05/22/2013 08:01:08 AM : [CLEAN-UP-RPT] 02 58 06 Wed 05/22/2013 08:01:08 AM : [iNST-SRX ] 02 50 0D.73.B1 1F.25.10 E1 13 FF LTOFFRR(FF) ----- Scene-Den Test Results ----- [Failed] Inside-Ceiling-Den (D 73 B1 1) ----- Scene-Den Test Results ----- Wed 05/22/2013 08:01:15 AM : [iNST-TX-I1 ] 02 62 00 00 34 CF 13 00 Wed 05/22/2013 08:01:15 AM : [iNST-ACK ] 02 62 00.00.34 CF 13 00 06 LTOFFRR(00)
  16. pmoeller replied to pmoeller's topic in ISY994
    you are correct no links, o count. Will find backup that works. Thank you.
  17. pmoeller replied to pmoeller's topic in ISY994
    I switched to a new one when I started having this problem.
  18. pmoeller replied to pmoeller's topic in ISY994
    Ran PLM restore again and here are the results. Thanks Tue 05/21/2013 06:56:16 AM : [GRP-RX ] 02 61 16 13 00 15 ----- Living Room Test Results ----- [Failed] Living Room Outlets (7 A2 30 1) [Failed] Cont-Wall Kitch-A (E 2E 2C 3) [Failed] Living Room Outlets (7 A2 2B 1) [Failed] Living Room Ceiling (D 80 E9 1) [Failed] Family Room Outlets (E A8 93 1) ----- Living Room Test Results ----- Tue 05/21/2013 06:56:24 AM : [iNST-TX-I1 ] 02 62 00 00 16 CF 13 00 Tue 05/21/2013 06:56:24 AM : [iNST-ACK ] 02 62 00.00.16 CF 13 00 06 LTOFFRR(00)
  19. pmoeller replied to pmoeller's topic in ISY994
    Sun 05/19/2013 05:10:39 PM : [GRP-RX ] 02 61 16 13 00 15 ----- Living Room Test Results ----- [Failed] Living Room Outlets (7 A2 30 1) [Failed] Cont-Wall Kitch-A (E 2E 2C 3) [Failed] Living Room Outlets (7 A2 2B 1) [Failed] Living Room Ceiling (D 80 E9 1) [Failed] Family Room Outlets (E A8 93 1) ----- Living Room Test Results ----- Sun 05/19/2013 05:10:47 PM : [iNST-ACK ] 02 62 00.00.16 CF 13 00 06 LTOFFRR(00) Sun 05/19/2013 05:10:47 PM : [std MH ] Unexpected Ack imCmd=62 cmd1=LTOFFRR 0x13 Sun 05/19/2013 05:10:52 PM : [iNST-TX-I1 ] 02 62 0F 28 51 0F 28 0F Sun 05/19/2013 05:10:52 PM : [iNST-ACK ] 02 62 0F.28.51 0F 28 0F 06 SET-MSB(0F) Sun 05/19/2013 05:10:52 PM : [iNST-SRX ] 02 50 0F.28.51 1F.25.10 27 28 0F SET-MSB(0F) Sun 05/19/2013 05:10:52 PM : [std-Direct Ack] 0F.28.51-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Sun 05/19/2013 05:10:52 PM : [iNST-TX-I1 ] 02 62 0F 28 51 0F 2B F8 Sun 05/19/2013 05:10:52 PM : [iNST-ACK ] 02 62 0F.28.51 0F 2B F8 06 PEEK (F8) Sun 05/19/2013 05:11:01 PM : [iNST-TX-I1 ] 02 62 0F 28 51 0F 28 0F Sun 05/19/2013 05:11:01 PM : [iNST-ACK ] 02 62 0F.28.51 0F 28 0F 06 SET-MSB(0F) Sun 05/19/2013 05:11:01 PM : [iNST-SRX ] 02 50 0F.28.51 1F.25.10 27 28 0F SET-MSB(0F) Sun 05/19/2013 05:11:01 PM : [std-Direct Ack] 0F.28.51-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Sun 05/19/2013 05:11:01 PM : [iNST-TX-I1 ] 02 62 0F 28 51 0F 2B F8 Sun 05/19/2013 05:11:02 PM : [iNST-ACK ] 02 62 0F.28.51 0F 2B F8 06 PEEK (F8) Sun 05/19/2013 05:11:06 PM : [ F 28 51 1] ERR 1
  20. pmoeller replied to pmoeller's topic in ISY994
    UI is UD 994 v. 3.3.10 restored from 3.2.6
  21. pmoeller posted a topic in ISY994
    Recently upgraded from 99I to 994i. Scenes not longer working. tried to restore isy, reload PLM. no help. any thoughts? Thanks
