Wilbert
  1. I have searched and can not find this anywhere. I have a simple scene with two light switches and a keypadlinc button - the button turns the light switches on/off. However, when I control the scene (turning it on/off) via the ISY 994 the button led does not change, but the light switches do change. When I run the scene diagnostic test, the keypadlinc button fails. What have I missed? Thanks in advance
  2. I can confirm that I have the same issue and I need a fix - and my firmware version is v.0D - how does one upgrade the firmware - this thermostat was recently purchased so I find it odd that the firmware is old
  3. Thanks for your help I moved my 2nd access point closer to the switch and tried the New Device as you suggested and it worked. I have two more switches downstairs but they still do not work. So I am wondering if I need more access points. I believe I have bridged the 2nd phase which I thought would be enough, but clearly something is missing. Our house is about 2500 square feet. How many access points would I typically need (if that is in fact the issue). I am not sure if this is related, but when I start up the UDI console, it reports that it can not communicate with any of my lights, but when I try to turn them on/off via the console, they do work - is this related? Thanks for your help
  4. I am using the Start Linking feature of the Console - is that not the best way to do it? As to the address, I have installed the light switch already - is it still possible to get the device address after it is installed? Right now when I press the Start Linking on the console, then I go to the device and press the set button for 3 seconds, the LEDs on the switch then flash quickly - this has not happened with the other switches I installed. Is that a better explanation?
  5. I am new but have not been able to find the answer to my problem by searching the forum and reading the user manual I have a 99i working with (2) 2476S, a 2486S/WH6 KeypadLink and a 2443 Access Point. I am trying to link to another 2476S but when I press the set button for 3 seconds, the LED lights just blink fast - I can not find a description of what that error code means - what have I done wrong? Thanks in advance
