Jeffg
  1. Jeffg replied to Jeffg's topic in ISY994
    Both Responders are set at 100% There are 26 insteon devices. About 16 Switchlincs, the rest are lamplinc, or appliancelincs and the 1 KeyPadLinc. I do have 2 access points, one in the attached garage and the second in my workshop (about 80 ft from the house). The insteon devices are working ok, even the wones in the workshop which are on a seperate meter. I had a problem when installing some of the Switchlincs and had them linked to another one. But finally figured out how to unlink them.
  2. Jeffg posted a topic in ISY994
    I am trying my first Scene (actually been trying for 4 or 5 days) I have a scene that contains one button from a Keypadlinc Relay and 2 ceiling lights switched with Switchlinc Relays. See picture below. If I select the scene in the left column, I can use the on and off buttons in the right section to turn on or off the two lights. But, I cannot turn the lights on or off using the "A" button on the Keypadlinc. I tried doing the same setup with a RemoteLinc, and got the same results. I know this can't be that hard, but it sure has me confused... Jeff
  3. Jeffg posted a topic in ISY994
