osurh18
  1. Thanks for the help. Not sure what happened, but when I went through the steps you described the test came back successful and the switch worked from then on. Thanks again
  2. Sorry didnt realize there were multiple versions. It is a 2473. It has a lamp plugged into it. The lamp does turn on and off with pressing the button on the outletlinc. The only way I've been able to get the switchlinc to be able to control it is by using a program If Switch is On then Set Outlet On else Set Outlet Off Is this the only way to do it?
  3. It's an outletlinc that has a lamp plugged into it
  4. I've added both my switch and outlet to a scene called Room Lamp. I have set the switch to be the controller and the outlet to be the responder. However when I turn the switch on or off nothing happens with the outlet. Please help. Thanks.
  5. So I just tried to link to a different IOLinc plugged into an outlet within the house and I got the same error Any suggestions
  6. I had an IO Linc and garage door sensor kit that had been working fine. We moved into a new house and took it with us. We factory reset our ISY and have been setting up our dimmers and switches without any issues. I installed the IO Linc and sensor yesterday. When I first started to link it to my ISY everything seemed fine. I was able to setup the device and use the admin console to control the device. The next time I logged in through the admin panel I got "Cannot communicate with.....Sensor. Please check connections. I tried removing the device and relinking it. I got the same error. I then removed the device again and did a factory reset to my IOLinc. I got the same error when I tried to link it again. All of the other devices are working fine. Any suggestions
  7. Took forever but I was able to login. I was ultimately trying to be able to restore my ISY because I've been having a few issues. One issue I have right now is that even though I can see all my devices and scenes the console cannot load the current states of the devices which makes me think I am not communicating with the isy completely. I backed up the ISY the last time everything was working well. However I cannot seem to find the location of the backup. What is the default or file extenstion?
  8. Thanks, that resolved the Java issue, New problem When the console screen pops up it never asks me to login and doesn't populate anything in the ISY. I tried to manually login by going to File<Logon. Nothing happened. I tried to go to restore ISY...nothing happened
  9. I am trying to connect to my admin console of my isy-99i, I tried using the link: http://universal-devices.com/99i/. However while the java section tries to load I got this error: ClassNotFoundException - com.universaldevices.client.ui.UDClientApplet.class Any suggestions? I made sure my java was up to date already
  10. osurh18 replied to osurh18's topic in ISY994
    I removed the device and relinked it and that worked. Thanks for help. Hope this doesn't happen frequently.
  11. osurh18 replied to osurh18's topic in ISY994
    I upgraded the firmware. Can you suggest the best way to remove and relink the IOLinc?
  12. osurh18 replied to osurh18's topic in ISY994
    The programs seem to be there now. Not sure what changed but the Tab is active again.
  13. osurh18 replied to osurh18's topic in ISY994
    I ran the Links Table for the IOLinc and it was empty. Since the IOLinc is close the PLM right now I tried restoring the device again. I rechecked the Links Table and it was still empty. I will try the removal and reinstall of the IOlinc. Firmware version is: 3.2.6
  14. osurh18 replied to osurh18's topic in ISY994
    [ignore] 0FF8 : 00 00 00.00.00 FF 1F 01
  15. osurh18 replied to osurh18's topic in ISY994
    To help clarify my last post a bit. When I created the event log I was toggling the IOlinc and was not jumping/unjumping the sensor
