Glenn Hargett
Everything posted by Glenn Hargett
  1. I have tried and failed to add an Insteon Mini Remote 8 Scenes. I get the Error (Capture attached) Cannot Determine Insteon Engine. Just purchased this device directly from Smarthome. Checked the count on my system and have about a hundred links. (Saw another topic that indicated the advance to Pro solved the issue) There was a question about what unit number to select in the dropdown box, used the one indicated in the pix. Also used "Self Discover" with same result. Have remote fully charged, turned on, but I did not push the Set button as I have not done that before. Any suggestions, issues?
  2. As recently referred to in the ISY99 forum, I too have an issue on both of my home computers with certificate issues for my ISY994IR. I ran the admin.jnlp that Michael loaded to the ISY99 forum and it worked well, but as with the ISY99 forum, it does not work from the normal log in. I must run the admin.jnlp to get in. I have firmware 3.3.10 and was going to do a manual upgrade, but elected to write in first. BTW: Could this have anything to do with my failure to be able to change over to the new weather system? Glenn Hargett
