ThisIsTheWay
  1. I know previously people have suggested Phillips warm glow 6” retrofit can lights but those seem to have gone off the market. Can anyone suggest a currently available 6” retrofit LED can light that is compatible with Insteon dimmers?
  2. Want to come back and say I followed the suggestions of paulbates and it worked 100%. Thank you!
  3. Correct. I dont need the second scene. My issues with not understanding that scenes do not respond to switching done in the Admin Console like they do to they physical item being switched.
  4. Yes. This was my issue. I was thinking that switching the device in the Admin Console would trigger the scene....but it does not. Physical presses of the devices does in fact work.
  5. Thu 01/02/2025 06:59:25 PM : [GRP-RX ] 02 61 58 13 00 06 Thu 01/02/2025 06:59:26 PM : [INST-SRX ] 02 50 70.FA.19 46.C2.78 61 13 58 LTOFFRR(58) Thu 01/02/2025 06:59:26 PM : [Std-Cleanup Ack] 70.FA.19-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Thu 01/02/2025 06:59:26 PM : [CLEAN-UP-RPT] 02 58 06 Thu 01/02/2025 06:59:26 PM : [INST-SRX ] 02 50 71.37.6C 46.C2.78 65 13 58 LTOFFRR(58) Thu 01/02/2025 06:59:26 PM : [Std-Cleanup Ack] 71.37.6C-->ISY/PLM Group=0, Max Hops=1, Hops Left=1 <html><font color="red">----- LL_FrontRight Test Results -----</font></html> <html><font color="red">[Succeeded]</font> LL_FrontRight (70 FA 19 2)</html> <html><font color="red">[Succeeded]</font> Landscape Front Right (71 37 6C 1)</html> <html><font color="red">----- LL_FrontRight Test Results -----</font></html> Thu 01/02/2025 06:59:33 PM : [INST-TX-I1 ] 02 62 00 00 58 CF 13 00 Thu 01/02/2025 06:59:33 PM : [INST-ACK ] 02 62 00.00.58 CF 13 00 06 LTOFFRR(00) Thu 01/02/2025 06:59:47 PM : [ Time] 19:00:00 28(0)
  6. I had not. Now I have. Seems to be the same result.
  7. I wanted to add an 8 button keypadlinc button to a scene with an on/off switch. Both are set as controllers in 1 scene. I was hoping that when the on/off switch is turned on/off, that the KPL button would go on/off accordingly. But when i trigger the on/off switch from the console app, the keypadLinc does not go on.off.
  8. I have a scene that controls a light. That light is also controlled by an 8 button RL in toggle mode. Is there a way to have the scene also flip the RL buttons toggle from off to on? I added it to the scene but i only see ability to set default, command, or ignore...and none of those did what I was wanting
  9. 🤯 I had no idea this was possible. That is amazing. Even better that it could be done with a device in place. WOW thank you.
  10. Im not following. Are you discussing a model other than the 2334-222?
  11. Its too bad the stopped making the on/off 8 button keypad....cant seem to find an old one on ebay either.
  12. Is there any way to remove the dimmer function and have the 2334-222 be on/off?
  13. I have the following setup M.BeDd-Overhead - scene - to drive both overhead can lights PBed Can 1 + PBed Can 2 PBedOverhead(dummy) - switch linc dimmer - load is capped as it is just a dummy switch- controls M.Bed-Overhead PBed Can 1 - micro dimmer module - driving a top hat can light PBed Can 2 - micro dimmer module - driving another top hat can light RL_Bed_Left-C-D - remotelinc as an 8 scene where buttons C/D controls M.Bed-Overhead RL_Bed_Right-E-F - remotelinc as an 8 scene where buttons E/F controls M.Bed-Overhead I setup a program that when PBed Can 2 is off and someone pressed off RL_Bed_Left-C-D, it should turn on only Can 2 (plan to do the same with RL_Bed_Right-E-F when it get it working on RL_Bed_Left-C-D) Whenever i press, RL_Bed_Left-C-D while PBed Can 2 is off, it does turn on only PBed Can 2 but after a second or two, PBed Can 2 turns off. I cannot figure out why...
  14. I cannot find any infroamtion on these errors. Should I be concerned? Wed 2024/10/23 09:00:11 AM 0 -10 n/a Wed 2024/10/23 10:46:02 AM 0 -170001 <s:Envelope><s:Body><u:GetISYConfig xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetISYConfig></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 Authenticate Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetStartupTime xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetStartupTime></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>/CONF/INTEGER.VAR</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>/CONF/STATE.VAR</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetVariables xmlns:u="urn:udi-com:service:X_IoX_Service:1"><type>1</type></u:GetVariables></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetVariables xmlns:u="urn:udi-com:service:X_IoX_Service:1"><type>2</type></u:GetVariables></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemOptions xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemOptions></s:Body></s:Envelope> Wed 2024/10/23 10:46:07 AM 0 -170001 <s:Envelope><s:Body><u:GetNodesConfig xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetNodesConfig></s:Body></s:Envelope> Wed 2024/10/23 10:46:08 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemTime xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemTime></s:Body></s:Envelope> Wed 2024/10/23 10:46:08 AM 0 -170001 <s:Envelope><s:Body><u:SetDebugLevel xmlns:u="urn:udi-com:service:X_IoX_Service:1"><option>1</option></u:SetDebugLevel></s:Body></s:Envelope> Wed 2024/10/23 10:46:08 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemOptions xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemOptions></s:Body></s:Envelope> Wed 2024/10/23 10:46:09 AM 0 -170001 <s:Envelope><s:Body><u:Subscribe xmlns:u="urn:udi-com:service:X_IoX_Service:1"><reportURL>REUSE_SOCKET</reportURL><duration>infinite</duration><send>F</send></u:Subscribe></s:Body></s:Envelope> Wed 2024/10/23 10:46:09 AM 0 -170001 <s:Envelope><s:Body><u:IsSubscribed xmlns:u="urn:udi-com:service:X_IoX_Service:1"><SID>uuid:90</SID></u:IsSubscribed></s:Body></s:Envelope> Wed 2024/10/23 10:46:09 AM 0 -170001 <s:Envelope><s:Body><u:RefreshDeviceStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"><sid>uuid:90</sid></u:RefreshDeviceStatus></s:Body></s:Envelope> Wed 2024/10/23 10:46:09 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:46:12 AM 0 -170001 <s:Envelope><s:Body><u:GetDisclaimerStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetDisclaimerStatus></s:Body></s:Envelope> Wed 2024/10/23 10:47:35 AM 0 -170001 <s:Envelope><s:Body><u:DeviceSpecific xmlns:u="urn:udi-com:service:X_IoX_Service:1"><command>G_DEV_ALL</command><node>57 4D 39 1</node><option></option><flag>1</flag><CDATA>0 -1</CDATA></u:DeviceSpecific></s:Body></s:Envelope> Wed 2024/10/23 10:47:35 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:47:35 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:47:55 AM 0 -170001 <s:Envelope><s:Body><u:DeviceSpecific xmlns:u="urn:udi-com:service:X_IoX_Service:1"><command>G_ISY_ALL</command><node>57 4D 39 1</node><option></option><flag>1</flag><CDATA>0 -1</CDATA></u:DeviceSpecific></s:Body></s:Envelope> Wed 2024/10/23 10:47:55 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:49:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:54:01 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:54:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:10 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:56:11 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:59:19 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 10:59:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:04:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:47 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:47 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:47 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:06:47 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:09:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:30 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:13:31 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:14:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:19:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:24:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:29:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:34:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:39:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:43:12 AM 0 -170001 <s:Envelope><s:Body><u:RestoreDeviceFromNode xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>50 C6 E9 1</id><flag>0</flag></u:RestoreDeviceFromNode></s:Body></s:Envelope> Wed 2024/10/23 11:43:12 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:43:12 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:WriteDeviceUpdates xmlns:u="urn:udi-com:service:X_IoX_Service:1"><node>50 C6 E9 1</node></u:WriteDeviceUpdates></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:06 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:14 AM 0 -170001 <s:Envelope><s:Body><u:RestoreDeviceFromNode xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>57 3D 3F 1</id><flag>0</flag></u:RestoreDeviceFromNode></s:Body></s:Envelope> Wed 2024/10/23 11:44:14 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:14 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:41 AM 0 -170001 <s:Envelope><s:Body><u:WriteDeviceUpdates xmlns:u="urn:udi-com:service:X_IoX_Service:1"><node>57 4D 39 1</node></u:WriteDeviceUpdates></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:42 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:44 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:45 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:RestoreDeviceFromNode xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>57 4D 39 1</id><flag>0</flag></u:RestoreDeviceFromNode></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:44:46 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:45:57 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:45:58 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:46:29 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemTime xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemTime></s:Body></s:Envelope> Wed 2024/10/23 11:46:36 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:46:59 AM 0 -170001 <s:Envelope><s:Body><u:DeviceSpecific xmlns:u="urn:udi-com:service:X_IoX_Service:1"><command>G_DEV_ALL</command><node>57 4D 39 1</node><option></option><flag>1</flag><CDATA>0 -1</CDATA></u:DeviceSpecific></s:Body></s:Envelope> Wed 2024/10/23 11:46:59 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:46:59 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:49:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:54:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:58:07 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 11:59:43 AM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:02:07 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:04:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:09:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:12:48 PM 0 -170001 <s:Envelope><s:Body><u:SetNodeEnabled xmlns:u="urn:udi-com:service:X_IoX_Service:1"><node>58 1E 29 1</node><flag>0</flag></u:SetNodeEnabled></s:Body></s:Envelope> Wed 2024/10/23 12:12:48 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:12:53 PM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>IOXBACKUP</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 12:14:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:16:47 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:19:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:21:34 PM 0 -170001 <s:Envelope><s:Body><u:RestoreDeviceFromNode xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>57 E5 FA 1</id><flag>0</flag></u:RestoreDeviceFromNode></s:Body></s:Envelope> Wed 2024/10/23 12:21:35 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:21:35 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:21:59 PM 0 -170001 <s:Envelope><s:Body><u:RestoreDeviceFromNode xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>57 CF 13 1</id><flag>0</flag></u:RestoreDeviceFromNode></s:Body></s:Envelope> Wed 2024/10/23 12:21:59 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:21:59 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:23:53 PM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>IOXBACKUP</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 12:24:08 PM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>/CONF/NET/WOL.CFG</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 12:24:08 PM 0 -170001 <s:Envelope><s:Body><u:GetAllD2D xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetAllD2D></s:Body></s:Envelope> Wed 2024/10/23 12:24:08 PM 0 -170001 <s:Envelope><s:Body><u:GetAllD2DStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"><key>B05C9EF3.59E1</key></u:GetAllD2DStatus></s:Body></s:Envelope> Wed 2024/10/23 12:24:12 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:24:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:39 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:26:40 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:29:43 PM 0 -170001 <s:Envelope><s:Body><u:GetSystemStatus xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetSystemStatus></s:Body></s:Envelope> Wed 2024/10/23 12:30:35 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>0</id><key>B05C9EF3.59E1</key><CDATA><cmd><setKey>BA373F4C.4F5D</setKey></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:35 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>38</id><key>BA373F4C.4F5D</key><CDATA><cmd><enable /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:43 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>38</id><key>BA373F4C.4F5D</key><CDATA><cmd><notRunAtReboot /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:43 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>39</id><key>BA373F4C.4F5D</key><CDATA><cmd><enable /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:43 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>39</id><key>BA373F4C.4F5D</key><CDATA><cmd><notRunAtReboot /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:43 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>0</id><key>BA373F4C.4F5D</key><CDATA><cmd><broadcast /><setKey>BA3761AC.4F5D</setKey></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:47 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>0</id><key>BA3761AC.4F5D</key><CDATA><cmd><setKey>BA376DA4.4F5D</setKey></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:47 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>38</id><key>BA376DA4.4F5D</key><CDATA><cmd><enable /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:54 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>38</id><key>BA376DA4.4F5D</key><CDATA><cmd><notRunAtReboot /></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:30:54 PM 0 -170001 <s:Envelope><s:Body><u:D2DCommand xmlns:u="urn:udi-com:service:X_IoX_Service:1"><id>0</id><key>BA376DA4.4F5D</key><CDATA><cmd><broadcast /><setKey>BA378A9D.4F5D</setKey></cmd></CDATA></u:D2DCommand></s:Body></s:Envelope> Wed 2024/10/23 12:31:44 PM 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>IOXBACKUP</name></u:GetSysConf></s:Body></s:Envelope> Wed 2024/10/23 12:32:03 PM 0 -170001 <s:Envelope><s:Body><u:GetErrorLog xmlns:u="urn:udi-com:service:X_IoX_Service:1"></u:GetErrorLog></s:Body></s:Envelope>
  15. Process for backup is almost instant on newer versions of IoX. Is this expected or do I have an issue?
