Audiosports
  1. No, the switches expired along time ago and were replaced along time ago. So the dead switches were never programmed in the isy and their links never showed up in the scenes tree, but the links do show up under the device viewer. I just added the isy into the system to manage the links more efficiently than running back and forth and to use the replace function on upcoming dead switches. Deleting the switches is not a very good option since that would require reseting 3kpl8, 2kpl6, and 3 switchlincs. I would be basically be starting over
  2. I just installed a 994i/ir pro and was hoping to clean up so old links from switches that have died and been replaced. I cannot find a way in the program to individually remove commands. From searching the forums, it seems a way to remove commands is to add them into the isy and then remove them, but that is not an option with a dead switch. If I were to do a factory reset of my kpl and then do a restore through the isy , would that restore all the links that were previously stored in the kpl or just the links from my scenes in the isy?
