ertyu
  1. Thanks for posting this topic, it both answered what was wrong with my PLM and how to fix it. Indeed mine is about 2.5 years old now, but the issues started a couple months ago. The issues didn't seem as severe as others. I would notice it stop responding and checked to see that it's LED was out. Sometimes unplugging it and plugging it back in was enough to get it to work for a few more weeks, sometimes it needed to be unplugged for some time before working again. Ordered from Digikey to cut the Canadian shipping costs to $8 (remarkably delivered in under 24 hours, ordered 7:30pm one night, delivered the next day at 2:30pm) so I made a few substitutions I hope were suitable for what Digikey had available in small quantities: Replace YICCON 6.8uF 250V cap with ESX106M400AH4AA 10uF 400 volt Substituted ESG106M400AH4AA -- long life version of ESX Replace FUJICON 100uF 25V cap with UTT1E101MPD 100uF 25 volt UTT1E101MPD Replace SAMCON 10uF 35v cap with EKY-500ETD100ME11D 10uF 50 Volt (2 of these) Substituted EKY-500ELL100ME11D -- same part with different leads Original part available in large quantities Replace FUJICON 10uF 16V cap with UTS1C100MDD 10uF 16 volt Substituted UTT1C100MDD1TP Original part available in large quantities
  2. ertyu replied to ertyu's topic in ISY994
    Thank you, that did it (deleting and re-adding the affected devices). Curiously I needed to update my programs, even though it seemed to map to the new devices automatically anyway.
  3. ertyu replied to ertyu's topic in ISY994
    I'm not sure, I'll delete and re-add them this evening.
  4. ertyu replied to ertyu's topic in ISY994
    I have a Lamplinc that doesn't work already plugged into the same spot as one that does work and its on the same plug as the PLM. I've previously upgraded to 3.2.6 as well.
  5. ertyu replied to ertyu's topic in ISY994
    Would signal issues explain why the scenes always fail, but directly commanding the device from ISY always works? I currently have the PLM and 2 of the Lamplincs plugged in at the same spot, one lamp works, the other doesn't in scenes. The other Lamplinc that doesn't work is a dual band on the other phase that is bridging the phases with the PLM.
  6. ertyu posted a topic in ISY994
    I've got some lamplincs and controlincs. I've linked them to ISY and I can control the lamplincs individually via ISY. I created a scene for each lamplinc and put the lamplinc and a button from each of the controlincs into the scene. The controlincs physically work to turn off the lamps as desired, but only one of the scenes will cycle the lamp when directed by ISY online. Even then, it shows the controlincs as "Failed" status during a scene test. The other scenes show all devices as "Failed". I'm relatively new to Insteon and ISY so I'm having trouble figuring out where I've gone wrong. Any pointers as to where to look or what to try?
