PSquare
Everything posted by PSquare
  1. I suspected either the braker or a loose wireing as mentioned above but just wanted to know before going into my 6 switches. I'll take a poke at it during the week. Thank you for your insight.
  2. That section that failed was installed by an electrician.
  3. But if the wiring would be faulty wouldn't the breaker have jumped?
  4. These were working fine for about 3 weeks. No I made sure that the wires do not stick out. I have a tester not a voltmeter.
  5. I did I turned off the braker and turned it back on and the led on the switch are still off and nothing happens when I try to turn on the lights.
  6. I have 2 on/off (2477S) and 4 dimmers (2477D) those are all in the same circuit but I have another 20 or so around house. My question is those 6 switches just went dead I opened a light and they went out no led lights and paddle doesn't turn on the devices. The braker at the braker box didn't jump. Is this faulty insteon devices or faulty breaker? Thanks.
  7. Would u mind sharing ur solution? Also doesn't the phone iPhone in my case disconnect from the network if not used or locked so the ping would fail and trigger your away program? Tks
  8. Is there a way to log in to a custom web interface hosted by my ISY without entering a username password via local wifi? But still keep the username password over https from outside.
  9. Yes it is the default ISY interface.
  10. Did you guys find a solution to the https over 3G kuz I seem to have the same issue but after a few reloads of the web page and reloading safari eventually I get in. But I decide to turn on debug mode on my iPhone Safari and I found a few HTML and JavaScript errors that do not show up when the connection actually work so maybe you can take a look at this. I will post the screenshots.
