jdlegan
Everything posted by jdlegan
  1. jdlegan replied to jdlegan's topic in ISY994
    If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Repeat Every 1 hour Set 'Rope Light' Off Else - No Actions - (To add one, press 'Action') Works great now. Thanks
  2. jdlegan replied to jdlegan's topic in ISY994
    Thanks for the reply I can't seem to post the program, but it is simple. No condition Under then repeat every 30 minutes set rope light off This does not work?
  3. jdlegan posted a topic in ISY994
    I feel dumb even asking this, but I cannot seem to resolve this programming. I simply want to repeat a set off command 24/7 once an hour to a module. I have tried the "repeat" command in both then and else and nothing I have tried seems to work.
  4. I did a preliminary test and hooked light to an inside lamp. No problem with recognition on ISY using LampLinc 2 pin Dim. The light responds instantly with ISY and does dim, but there is a flicker when dimming down. Once light is dimmed there is no flicker. I set it up with motion detector and it works as programmed. So far I am happy with this and will be putting in garage overhead light over the weekend. The LED appears to be the same or brighter than a 60 watt. Can you hear any buzzing noise?? If so can you describe how loud it is? Teken . . . I did not hear buzzing in table lamp or ceiling garage light.
  5. I did a preliminary test and hooked light to an inside lamp. No problem with recognition on ISY using LampLinc 2 pin Dim. The light responds instantly with ISY and does dim, but there is a flicker when dimming down. Once light is dimmed there is no flicker. I set it up with motion detector and it works as programmed. So far I am happy with this and will be putting in garage overhead light over the weekend. The LED appears to be the same or brighter than a 60 watt. What about color? Is it like your typical 2700k incandescent or more bluish like a lot of cheaper led's? It appears (far from an expert) to be whiter or brighter than another lamp with the incandescent 60 watt bulb in the same room.
  6. I did a preliminary test and hooked light to an inside lamp. No problem with recognition on ISY using LampLinc 2 pin Dim. The light responds instantly with ISY and does dim, but there is a flicker when dimming down. Once light is dimmed there is no flicker. I set it up with motion detector and it works as programmed. So far I am happy with this and will be putting in garage overhead light over the weekend. The LED appears to be the same or brighter than a 60 watt.
  7. Thanks Chris, My bulb arrived today and I should have it set up tonight. Good to hear it works with ISY
  8. I plan on using this presuming that it works with ISY in the garage light that is left on. I was going to replace the switch, but saw this and was thinking it would be a quick fix. I also plan on utilizing the motion detector currently in the garage to auto turn on and shut off when no motion is detected. I will update when bulb arrives. Thanks to everyone on your input.
  9. I just ordered the new Insteon LED light bulb which has an address. Will I be able to program this new item on ISY or do you have to create an update for it?
