glynde
Everything posted by glynde
  1. Awesome! Thanks for your help!!!
  2. Hi, I've followed the directions in this old thread. I have an ISY-994i running on v4.2.18 and a 2477D v 7.6. I created a scene called "office cans" and put the switch (also named "office cans") into the scene as a controller. My program adds a command to turn to lights just to I can see if the program is actually running. If I turn the lights on either with the paddle or the administrative console during the time period, they still turn on to 100%. I've attached a snip of my program and my log showing the program running. ISY-Events-Log.v4.2.18__Sat 2015.01.17 01.40.18 PM.txt
  3. I cured it!!!!!! Thanks for the brainstorm. When I looked at the firmware, it said firmware is v.00. Made me think something was wrong with the link between it and the ISY. So when I looked at the Link Management menu on the admin console, I noticed I was going through "Link a ControLinc" and tried the "New INSTEON Device" instead. I allowed it to autolink. When it came up it said my firmware is v.40 and when I tried (again...) to reprogram the scenes it worked perfectly. Anyway, thanks again for your help. Grant
  4. Old keypadlinc: 5.1. New: 5.9. I'm able to create the scene using another switchlink located in another room. Another data point, simplifying the programming: -Button "C" controlling the main on button. If I set the scene to 60%, it works if directly activated via ISY. However if pressed locally, the light goes to 100%. If I then click on Button "C" in the program it says it's set for 100%. If I lower it and click anywhere else then back again, it says 100%. Again, if I do this from any other switchlink it acts as expected.
  5. Hi, I have a 6 button switchlinc, a dimmer, and an ISY. There are 2 scenes: Dim and Bright. Button "C" is to turn on Dim and Button "D" is to turn on "Bright". I programmed 2 scenes. -Button "C" is the controller, the main "ON" button is a responder and is set to 60%, as is the dimmer switch. -Button "D" is the controller, the main "On" button is a responder and is set to 100% and the dimmer switch is the same. On my insteon admin page the scene responds as expected. When I hit button "D", everything is 100% as expected. When I hit button "C", the dimmer is appropriate at 60%, but the main is 100%. I've restored the device. I replaced it thinking that a recent lightning storm maybe fried something. I've restored my PLM. And my ISY. Any suggestions? I have a similar problem with another switchlinc and dimmer combo. Thanks.
