bitboy53
Everything posted by bitboy53
  1. It worked! Thank you Thank you
  2. First off...thanks again for helping a newby get started Here is what I did so far: #1 Downloaded the simplehomenet utility #2 Connected ther PLM to my serial port #3 Ran the Utility and connected with the PLM #4 Clicked on the EZIOx tab #5 entered the ID# for my EXIO4 module and connected to it #6 Told it to enable the timers in sec #7 Wrote to the EXIO4 module #8 exited the utlity and connected my PLM back up to the 99i and opened the admin console Nothing has changed! I was expecting to see some timer controls for the EXIO4 module but nothing was there to change the output timer other than on/off What am I missing
  3. Can you be more specific on the utility? The list is shown below. Which one is it? Thank you! John Software Utilities, API's, and Tutorials <--click for more files Of Groups and Links... 10/21/07 - Tutorial on the basics of Insteon All-Link (Group) messaging SimpleHomeNet Utility Suite 5/7/11 - Supports the EZIComm and Smarthome PLM (#2412 or #2413) Windows XP Setup and configuration utility for all devices. Thanks to Lee Griffith for adding PLM support and contributing this version compatible with EZSrve 2.xx. Download ZIP File EZSrve Discovery and software upgrade tool 6/10/10 - V2.0 Java utility that discovers the EZSrve in your network, facilitates the software upgrade process, and allows for backing up and restoring files, independently of operating system or browser. The Java JRE must be installed in your machine and firewalls must be open for it to run. Harmony Gateway/Platinum Discovery and software upgrade tool Java utility that discovers the Harmony Gateway and Harmony Platinum in your network, facilitates the software upgrade process, and allows for backing up and restoring files, independently of operating system or browser. The Java JRE must be installed in your machine and firewalls must be open for it to run. HarmonyGUI AIR The Downloadable version of the HarmonyGUI will be available when the application has completed the BETA phase. EZSrve Live Demo with Beta preview of the new HarmonyGUIâ„¢ Flash Interface 9/24/09 - Login to an EZSrve in our office (or your own), and see the functionality and ease of use for yourself! First go to http://www.compacta.org then enter the local IP of your EZSrve or "98.189.165.252" with the password: Simplehomenet if you are trying ours. Once the application initializes, it runs entirely in your local machine interacting with the connected EZSrve. PLEASE NOTE THIS SOFTWARE WILL ONLY RUN WITH EZSRVE FIRMWARE 2.05 AND ABOVE. EZSrve API INSTEON & X10 API ZBPCID API 6/26/12 - API for ZigBee commands for USB-CID and ZBPLM ZBPLM Docklight Script 3/2/11 - ZBPLM_Parser.ptp file to open ZBPLM for programming
  4. I am sorry I am such a newby but I need help getting my EZI040 4-relay turn on then off in 1 sec. Is there a mode I can put the device in or do I need to program the 99i control to do it? Thank you!
  5. Thanks! I found out what I was doing wrong....
  6. My 99i comes with the ports 80/443 already set. However, I already have a camera system on 80/9000. Can I change the 80 to another port. I tried 50/443 and it wouldnt work. Any ideas on what port I should pick so both the camera and the 99i can work on the same network? Thanks in advance for your help
