Everything posted by raderu
How to set up ISY for first time
tried to clear Java cache....same error message comes up.....I have another question: Do I have to have ISY994 Admin Console on my PC? Can I access it thru web browser?.... Another question : when I go to my Network place on PC, I don't see my ISY 994i Mobil Link....Does this has anything to do with the fact I can not download ISY994 Admin Console?..Thanks
downloaded fresh java....same error message.....any other ideas?
i tried to disable Avast- same result....
I am using Avast.....tried your link to launch ISY- same result : it will ask me if i want to open/save this program and when i choose open it comes up with blank page
Hello....i just purchased new pc ( with windows 11 )....tried to use Universal Devices link to install ISY994 Admin Console - i see file download, but every time i tried to open file , something is blocking it....i checked my pop-up block is off....can someone help?....thanks
can not access my ISY99
its says: this page can not be displayed!.....hmmm...any advise?
hello...I can not access my ISY99 thru short cut on my PC desk top ...I did not change anything...was ok last week, tried to get in to write new program and its says can not find ISY on my network. I tried to restart ISY-it did not work...please advice...btw:I still can access it thru my MobilLinc and all programs work fine...
Loss of connection with ISY-994i
hello...using smart system for 2 years now. Couple days ago my programs stopped working.When i accessed Admin Console i was not able to connect to any devices. Please advise..
firewall problem
Greg.....i am new at this....can you walk me thru how to "use the MAC address of the ISY to tell your DHCP to always give it the same IP address"
firewall problem
Hello....i have ISY-99i....pretty much new user.....using Kaspersky Firewall on my PC.....tried to set up in Kaspersky settings so it will recognize this unit and would not block any of it content: input ip address in it web setting menu.....but recently noticed it was blocked by kaspersky again.....checked the settings: now ISY-99i has different IP address...does ISY change IP addresses? What is my solution for this? Thanks
SCENE CONFIGURATION
i miss understood you....i was clicking "on" and "off" botton on the bttom of that paticular scene screen.....sorry i am new at this...
SCENE CONFIGURATION
ic....i am actually at work right now.....but now i understand what you mean about firmware.....something i noticed, when last time i was loged in in admin console: right at the top it says:" new firmware 3.2.6. now available".....based on this i assume most likely i have the other version...does this help?...if not i would need to get back to you in couple hours....
SCENE CONFIGURATION
i do not understand your question about firmware....and if i run a scene test thru admin console: dimmers will turn on....switch links will not . On the scene screen : it will show next to switch links "on"( in red color )....but in reality they not "on".
SCENE CONFIGURATION
yes..this is new insteon install...i am using ISY994i INSTEON Compatible Automation Controller with Dual-Band PLM ....i have 26 light switches and dimmers....none of them controling each other....using 2 wireless phase couplers to connect opposite phases....yes , it passed connecting test....all switches work fine if i try to turn them on/off ....dimm...thru admin console...also work fine as part of program. But when tried to build a scene, i noticed dimmers responding to scene commands.....switches - not. So....switches work fine outside scenes, but not when they part of the scene....and all switches defined as Responders. My scene is pretty simple: 2 dimmers connected to lights and 2 relay switches connected to flurecent lights. any ideas?
SCENE CONFIGURATION
i am new ISY-99i user...trying to create scenes...working with switchlinc dimmers and switchlinc relays.....when completed scene with combination of switches and dimmers: dimmers work ..switches not responding....any idea?
issue with ISY-99i
ok...i get it....so just like you said...click "add" botton....new window came up asking for URL address....inputed http://ip address/....errormsg came up: Not Found .....and XML Parse Error http://ip address/ ?????? what is next?
issue with ISY-99i
sorry not that good with this....when i click "add"....little window poped out asking for URL number...where i get that one?
issue with ISY-99i
i am new isy-99 user...just installed ISY-99 and 26 swithches....in the proccess to link all devices.....just loged in today in Admin Console...it is swoing all my devices...but unable to control any of them thru admin console...it feels like it is no conection....any ideas?
