stephan
Everything posted by stephan
  1. I'll disable the Dyson node server and provide more information on the wemo one (after checking out the README) tonight. Thanks for the responses so far.
  2. My Polisy device has been running somewhat reliable in the past but over the weekend it has gotten unusable and I could use a few ideas before I just do a hard reset and lose all my connections into ISY. When I say somewhat reliable I mean that one node server in particular that I rely on has been flaky and not always reliably worked. A reboot usually helped, but all that changed over the weekend when I updated the Polyglot (57 updates since last time). No when it starts (and to be fair I haven't checked the logs before hand so I don't know if this is new or not) I see two things happening. a) The logs are going crazy and the same messages just keep printing forever in a very rapid fashion. I attached a log file for reference. b) All node servers seem to have started AFTER 5 minutes. it took forever... except the wemo one and I get SQL Lite exceptions. I even tried removing the node server and I couldn't do it. The ISY config is still correctly set btw. Any information I can share here to help with recovery? or should I just factory reset and try again? -Stephan polyglot_log.txt
  3. I ran this command instead and now the install worked. Thanks curl -s https://pkg.isy.io/script/update121.sh | sudo bash
  4. Even after updating to 2.2.11 I still get the error cloneRepo: Error: runInstallProcess: undefined when I try to install a new Node Server. Any tips? Update: I have the same issue as this user reported: This is the error message: libpython3.7m.so.1.0: Undefined symbol "close_range@FBSD_1.6"
  5. I also wanted to provide feedback that a new power supply worked for me. As of last night (just like @dantoronto) nothing worked anymore. The blue light in the back was on, but the power light in front was very dim and not fully lighted up. I used another power adapter and I am back in business now. Thanks everybody for the tip. -Stephan
  6. @Michel Kohanim this sounds very intriguing and promising. I am looking forward to it! Is there a way to participate in a iOS Beta? -Stephan
  7. I am going to revive this thread here as I keep coming back to the same question over and over. I am using the MobiLinc app and it has been working great in recent years, however as I have been adding more and more z-wave devices it falls short of displaying and controlling said devices. For instance I have a new thermostat that is fully controllable in the ISY admin console, but I can only see the temp in the MobiLinc app. The MobiLinc app hasn't been updated for years and I am not ready to pay monthly subscriptions for "MobiLink X" either. What other alternatives are there? Can we expect something based on polisy maybe? What are others using instead? -Stephan
  8. Btw, is there a good overview about the new capabilities of v5? I found one page on the wiki but it didn't say anything about the new node server menu and what I can do with it. https://wiki.universal-devices.com/index.php?title=V50_MAIN
  9. From 4.7.3
  10. I just upgrade to RC1 and it looks all good except zwave. I followed the instructions but all programs lost their links and most of my multilink shades have disabled devices. Do I have to re-enroll all of them now? Any ideas how to fix this? -Stephan
  11. I got this resolved. FYI for anyone who is interested: I opened a support ticket with UDI and Michael figured out that I hit the node limits of the basic version. Unfortunately the logs didn't say anything about that I upgraded now to the pro version and I can successfully add that device now
  12. Sorry for not being clear @stusviews. I did remove it first before adding when I did my testrun because I know it sometimes works in that case, but I did not capture the logs. Because of that I did not write it down in my earlier post.
  13. I tried that as well in my last attempt that I shared above, I just didn't get the logs for it
  14. Hi, yes it is 4.6.2 for both the UI and the ISY firmware. I just did the add and then two removes and I get this ADD Mon 09/18/2017 22:01:00 : [ZWAVE-TX-NR ] [0105004AC16110] Mon 09/18/2017 22:01:00 : [UZW-CMD 1 ] Start Include Mon 09/18/2017 22:01:00 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:00 : [ZWAVE-RX ] [0107004A61010000]... Mon 09/18/2017 22:01:00 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:00 : Listening for Z-Wave devices to add to the network Mon 09/18/2017 22:01:10 : [ZWAVE-RX ] [0107004A61020000]... Mon 09/18/2017 22:01:10 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:10 : Z-Wave device detected, retrieving info 2 Mon 09/18/2017 22:01:10 : [ZWAVE-RX ] [0115004A6103190E]... Mon 09/18/2017 22:01:10 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:10 : Z-Wave device detected, retrieving info 3 Mon 09/18/2017 22:01:22 : [ZWAVE-RX ] [0107004A61051900]... Mon 09/18/2017 22:01:22 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:22 : Z-Wave device detected, retrieving info 5 Mon 09/18/2017 22:01:22 : [ZWAVE-TX ] [0105004A856257] Mon 09/18/2017 22:01:23 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:23 : [ZWAVE-RX ] [0107004A62061900]... Mon 09/18/2017 22:01:23 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:23 : Adding Z-Wave devices stopped Mon 09/18/2017 22:01:23 : [ZWAVE-TX ] [01030020DC] Mon 09/18/2017 22:01:23 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:23 : [ZWAVE-RX ] [01080120EC772964]... Mon 09/18/2017 22:01:23 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] [01030002FE] Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] [0125010205001DBD]... Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] [01030005F9] Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] [0104010508F7] Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : Device 25 of type 4.17.7 included into Z-Wave network Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] [0109001319027204]... Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] [0104011301E8] Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] [0105001363008A] Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : [ZWAVE-RX ] [010E000400190872]... Mon 09/18/2017 22:01:24 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:01:24 : Adding ISY node(s) for new Z-Wave device 25 type 4.17.7 Mon 09/18/2017 22:01:24 : [ZWAVE-ADD-NODE ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07 SYNC Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 25 (0x19) ---- Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] [010400601982] Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] [01040160019B] Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] [0114004984190E04]... Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] [0109001319027204]... Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] [0104011301E8] Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] [0105001364008D] Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-RX ] [010E000400190872]... Mon 09/18/2017 22:04:16 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:04:16 : [ZWAVE-DB ] Warning: Database already exists for uid=25 0x19 Mon 09/18/2017 22:04:16 : Adding ISY node(s) for new Z-Wave device 25 type 4.17.7 Mon 09/18/2017 22:04:16 : [ZWAVE-ADD-NODE ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07 Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] Processing Z-Wave Node 25 (0x19) Failed, node ignored Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] -- Finished -- ISY/Z-Wave Node Sync -- REMOVE 1 Mon 09/18/2017 22:05:55 : [ZWAVE-TX-NR ] [0105004B0165D5] Mon 09/18/2017 22:05:55 : [UZW-CMD 2 ] Start Exclude Mon 09/18/2017 22:05:55 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:05:55 : [ZWAVE-RX ] [0107004B65010000]... Mon 09/18/2017 22:05:55 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:05:55 : Listening for Z-Wave devices to remove from the network Mon 09/18/2017 22:06:05 : [ZWAVE-RX ] [0107004B65020000]... Mon 09/18/2017 22:06:05 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] [0115004B6503190E]... Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] [0115004B6506190E]... Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : Removing Z-Wave devices stopped Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] [01030020DC] Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] [01080120EC772964]... Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] [01030002FE] Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] [0125010205001DBD]... Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] [01030005F9] Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:06 : [ZWAVE-RX ] [0104010508F7] Mon 09/18/2017 22:06:06 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:06 : Device 25 excluded from Z-Wave network REMOVE 2 Mon 09/18/2017 22:06:34 : [ZWAVE-TX-NR ] [0105004B0166D6] Mon 09/18/2017 22:06:34 : [UZW-CMD 2 ] Start Exclude Mon 09/18/2017 22:06:34 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:34 : [ZWAVE-RX ] [0107004B66010000]... Mon 09/18/2017 22:06:34 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:34 : Listening for Z-Wave devices to remove from the network Mon 09/18/2017 22:06:43 : [ZWAVE-RX ] [0107004B66020000]... Mon 09/18/2017 22:06:43 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] [0115004B6603000E]... Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] [0115004B6606000E]... Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:44 : Removing Z-Wave devices stopped Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] [01030020DC] Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] [01080120EC772964]... Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] [01030002FE] Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] [0125010205001DBD]... Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] [01030005F9] Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] ACK Mon 09/18/2017 22:06:44 : [ZWAVE-RX ] [0104010508F7] Mon 09/18/2017 22:06:44 : [ZWAVE-TX ] ACK Hope any of that helps I really would like to get to the bottom of this. Very annoying that I cannot control this blind but the others work flawlessly. -Stephan
  15. ISY: v4.6.2 Z-Wave Version 4.55 Bootloader Version 1.03 Also, just want make sure my comment from above was noticed. I have the exact same model already working and I can remove and add it. But this last one that was part of my order doesn't seem to work to connect. Shd I send you some trace information ? Or do I need a reset ? I was trying to avoid a reset and re-enroll of all my devices -Stephan
  16. Do you need the ISY firmware or the zwave dongle ? I'll check as soon as I am back home
  17. Thanks for the reply. yes I tried heal and synchronize. On synchronize I get the message as pasted above Sun 09/17/2017 14:52:45 : [ZWAVE-DB ] Warning: Database already exists for uid=24 0x18 Sun 09/17/2017 14:52:45 : Adding ISY node(s) for new Z-Wave device 24 type 4.17.7 Sun 09/17/2017 14:52:45 : [ZWAVE-ADD-NODE ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07 Sun 09/17/2017 14:52:45 : [ZWAVE-NODE-SYNC] Processing Z-Wave Node 24 (0x18) Failed, node ignored
  18. I have the same issue as this post but did not find any solution. http://forum.universal-devices.com/topic/14045-cant-add-z-wave-devices/ Before I explain the issue I would like to say that I have a bunch of Bali Z-Wave Motorized Shades already working and I also tried removing and adding them again, and they work just fine. But this last one that I am trying to add I get the following issue: In the admin console, I go to Z-wave then Add. I put the shade into link mode and it seems to link just fine: Sun 09/17/2017 14:17:21 : Listening for Z-Wave devices to add to the network Sun 09/17/2017 14:17:39 : [ZWAVE-RX ] [0107004A19020000]... Sun 09/17/2017 14:17:39 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:39 : Z-Wave device detected, retrieving info 2 Sun 09/17/2017 14:17:39 : [ZWAVE-RX ] [0115004A1903130E]... Sun 09/17/2017 14:17:39 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:39 : Z-Wave device detected, retrieving info 3 Sun 09/17/2017 14:17:51 : [ZWAVE-RX ] [0107004A19051300]... Sun 09/17/2017 14:17:51 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:51 : Z-Wave device detected, retrieving info 5 Sun 09/17/2017 14:17:51 : [ZWAVE-TX ] [0105004A851A2F] Sun 09/17/2017 14:17:51 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:17:51 : [ZWAVE-RX ] [0107004A1A061300]... Sun 09/17/2017 14:17:51 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:51 : Adding Z-Wave devices stopped Sun 09/17/2017 14:17:51 : [ZWAVE-TX ] [01030020DC] Sun 09/17/2017 14:17:51 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:17:51 : [ZWAVE-RX ] [01080120EC772964]... Sun 09/17/2017 14:17:51 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] [01030002FE] Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] [0125010205001DBD]... Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] [01030005F9] Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] [0104010508F7] Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : Device 24 of type 4.17.7 included into Z-Wave network Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] [0109001313027204]... Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] [0104011301E8] Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] [010500131B00F2] Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : [ZWAVE-RX ] [010E000400130872]... Sun 09/17/2017 14:17:52 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:17:52 : Adding ISY node(s) for new Z-Wave device 24 type 4.17.7 Sun 09/17/2017 14:17:52 : [ZWAVE-ADD-NODE ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07 I know that the linking was successful because the shade jogs which is the shade's tell for it. I can also exclude the device successfully, and try to add again, but same problem. The devices never show up in the tree, though the ISY seems to remember them. When I Sync New & Deleted Nodes I get this output for it. Sun 09/17/2017 14:52:44 : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 24 (0x18) ---- Sun 09/17/2017 14:52:44 : [ZWAVE-TX ] [010400601883] Sun 09/17/2017 14:52:44 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:52:44 : [ZWAVE-RX ] [01040160019B] Sun 09/17/2017 14:52:44 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-RX ] [0114004984180E04]... Sun 09/17/2017 14:52:45 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-TX ] [0109001318027204]... Sun 09/17/2017 14:52:45 : [ZWAVE-RX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-RX ] [0104011301E8] Sun 09/17/2017 14:52:45 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-RX ] [01050013900079] Sun 09/17/2017 14:52:45 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-RX ] [010E000400180872]... Sun 09/17/2017 14:52:45 : [ZWAVE-TX ] ACK Sun 09/17/2017 14:52:45 : [ZWAVE-DB ] Warning: Database already exists for uid=24 0x18 Sun 09/17/2017 14:52:45 : Adding ISY node(s) for new Z-Wave device 24 type 4.17.7 Sun 09/17/2017 14:52:45 : [ZWAVE-ADD-NODE ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07 Sun 09/17/2017 14:52:45 : [ZWAVE-NODE-SYNC] Processing Z-Wave Node 24 (0x18) Failed, node ignored How can I fix this ? Any help would be greatly appreciated
  19. Hi guys, I have the same problem now with KPL from that time frame. What I was wondering is whether I can still use them - without flickering - if I don't control any load. I could use them to remote control other parts of the house for instance. -Stephan
  20. stephan replied to abartello's topic in ISY994
    Resurrecting this thread as I have the same problem with the weak certificate and the fact that browsers reject this. I also have a the problem that MobiLink with SSL is not as reliable as without. According to the MobiLinc support this is caused by the slow response from the ISY (10sec to establish a connection). Turning of SSL though is not an option for me. I currently have a ISY994i and would the PRO version have a faster processor that allows me to upgrade to a better/stronger certificate ?
  21. I think I just answered it myself. I can use the ST name which on a thermostat gets me the degrees. Any chance that can be added to the wiki -Stephan
  22. Hi all, I am trying to send me an email with the actual temperature that my venkstar thermostat measures. This wiki link shows me how to get humidity and set points, but not the temperature: http://www.universal-devices.com/mwiki/ ... _Variables Is it possible to retrieve that information and use that in an email as well ? Thanks Stephan
  23. I have the capture now. Do you want me to post it here ? Also since this is HTTPS to notifo.com the data on the wire is encrypted and I don't have the notifo.com secret to decrypt. Not sure if that is still helpful this way. Figured I ask before hand Stephan
  24. interesting idea. This would work for instance for PCs that have that capability. Other devices with a more limited set of capabilities such as my Denon A/V Receiver which has a built in web interface wouldn't work. Thanks for the idea, it definitely provide a partial solution for my WOL "problem" as I wanna see when my server is fully available to rock. Stephan
