mjennings
Everything posted by mjennings
  1. I couldn't find a "My Lighting" button. I clicked on network which showed all my devices name, state, address and type in a table. The triggerlinc I'm trying to connect was not listed in that table.
  2. Wait, you said "New INSTEON Device does not expect any device buttons to be pressed", but then you also said "Note that battery RF devices such as the Motion Sensor, TriggerLinc, RemoteLinc2 must be put into linking mode manually by pressing the device Set button for 3-5 seconds before using New INSTEON Device." Anyways for some reason this problem has stopped. Now I've got a light dimmer, triggerlinc, and motion sensor successfully connected. I added the triggerlinc and motion sensor by holding the set button on each and then doing New INSTEON device. The problem is, I have another triggerlinc I'm trying to add, but it won't work. When I add it the progress bar gets to 7% and then closes and nothing happens. Also, my light dimmer keeps randomly turning off on its own.
  3. I don't think theres any cordless phones or anything like that. When I've been adding devices I've been holding down the set button until the led on each device starts to flash. Was I not supposed to do that?
  4. Yes, both the firmware levels are 3.2.6. The cable from the ISY to the PLM is only like 3 ft long. I'm using the New INSTEON device option to add devices. Just now I was able to add a device, but when I tried adding another one it failed again. I noticed that whenever this was happening the led on the PLM was flashing red. Also, I figured out you could stop the loop by just disconnecting the PLM from the ISY for like 20 seconds. Also, I tried adding my light dimmer and it failed just like before. Then I disconnected the PLM from the ISY for 20 seconds, and then plugged it in. The admin console said the light dimmer could not be reached, but then I modified the power level and the console instantly recognized the device. It tried the same thing with my motion sensor but it didn't work. I think this might have something to do with the fact that the light dimmer doubles as an access point. I'm not really sure how this all works but maybe when we were initially setting things up we connected them to the light dimmer and somehow thats messing things up?
  5. I've had my ISY994i for a couple days now and until recently it's worked fine. But now, when I add devices, the progress bar will go to 100%, disappear for a second, then start from 0% again. It does this forever, even if I delete the device. The only way I can get it to stop is if I cut the power to the ISY. I looked at the event viewer log and the only thing its sending is the following line every one or two seconds: [uNKNOWN ] 02 00 How can I fix this?
