pmoles
  1. Solved - duh, works using https://isy .......kills me THANKS ALL!! Peter
  2. Geddy, Took your advice and placed ISY directly into eero hub and my pc on wireless. No joy. Reloaded Java, and all, no joy. Setup telnet and able to access. Strange that all other means of access to the ISY work but not the Launcher. Will reach out to UDI for help. Thanks for your time and help, Peter
  3. It was not, set it to same network level 192.168.4.xx as PC with no joy - same results. In either case, able to access the ISY through the URL via browser. Ideas? T/Peter
  4. Michel, That may be true in this case. Let me check tonight. Thanks. R/Peter
  5. Michel, Both plugged into same 8 port switch. R/Peter
  6. Michel, Power comes on, then TX and RX come on, the memory flashes and then stops, the TX stops and then RX stops - leaving only the power on. T/Peter
  7. Bought a new ISY994i ZW+ PRO and ISY Launcher cannot find ISY. Run start(5).jnlp and brings up ISY FInder dialog box but does not find ISY nor allows me to Add via URL https://isy (invalid ISY error) Have cleared all cache including all applications Linked u_d_.com to java security ISY boots up with correct lights - Power On remains Computer and ISY both wired into eero mesh network (same unit) No PLM installed yet Had a previous ISY994i (15+years) at previous house and removed from network, .etc - why start(5).jnlp Frustrating. Any thoughts? Thanks, Peter
  8. pmoles replied to pmoles's topic in ISY994
    PERFECT - THANKS - I AM IN!!!
  9. pmoles replied to pmoles's topic in ISY994
    Yes, they are on 192.168.4.XX series.
  10. pmoles posted a topic in ISY994
    Today I replaced by Cisco Router with a EERO Mesh Network. The ISY994i is now assigned a URL of 192.168.4.44 When I start the ISY Launcher, it cannot locate it and when I try to ADD it, it gives me a "Invalid URL" error. I powered the ISY994i on and off, completed a factory reset with no joy. Anybody had the same issue? Thanks, Peter
