captndelta
Everything posted by captndelta
  1. And then there is this: https://github.com/thorsten-gehrig/alexa-remote-control based on: https://www.gehrig.info/alexa/Alexa.html Someone is working on a openhab binding for this: https://community.openhab.org/t/beta-tester-required-openhab2-amazonechocontrol-binding-controling-alexa-from-openhab2/37844 maybe it can be used to get the ISY network module to work too. Cheers, -Th
  2. Hi Michel, no apology needed, we all want our weekends. I have send you the requested info to the given address, please let me know if you need anything else. -Th
  3. Ok, did this, including clearing cache. added both URL's to the Finder, the local one was ok, the remote URL ('isy.domain.tld') took some time, then the following was displayed, and the remote URL was not added. Thanks for your help, -Th Edit: there was nothing on the console (no trace etc)
  4. Hello Michel, no, a 'nslookup isy.doman.tld' gives me my outside ip (as it should). Thanks, -Th
  5. Hello Michel, yes, this does work via ProxyPass, the result is: 1 0 http://192.168.1.99 urn:udi-com:device:X_Insteon_Lighting_Device:1 ISY Universal Devices Inc. http://www.universal-devices.com X_Insteon_Lighting_Device:1 ISY 994i 256 1120 uuid:00:21:b9:00:f4:6a uuid:00:21:b9:00:f4:6a urn:udi-com:service:X_Insteon_Lighting_Service:1 urn:udi-com:serviceId:uuid:00:21:b9:00:f4:6a /services.wsdl /services /eventing UDIELKWebServices uuid:00:21:b9:00:f4:6a-UDIELKWebServices /elkServices.wsdl /security/elk UDISEPWebServices uuid:00:21:b9:00:f4:6a-UDISEPWebServices /sepServices.wsdl /sepServices / Am I right to suspect that http://192.168.1.99 has something to do with this (thats the internal IP of the ISY), which would need to be proxied/rewritten in the response? (Just guessing) Thanks for your help, -Th
  6. My internet gateway (a FreeBSD box) has a bit of a quirk (designed) in regards to port forwarding via natd, which makes it somewhat impossible to use it with the isy from 'inside' the network as well as from the 'outside' using the same URL (i.e. in mobilinc, ekeypad, etc). Therefore I tried to use apache proxypass to forward the external traffic to my internal isy (which works pretty well for the two security cams I have), however the ISY is giving me trouble. The isy is a 994i, firmware 3.2.6, UI 3.2.6. Here is the apache virtualhost section I'm trying to use on the gateway: ServerName isy.domain.tld ServerAdmin webmaster@domain.tld DocumentRoot /usr/local/www/data ErrorLog /var/log/httpd/isy-errors.log CustomLog /var/log/httpd/isy-access.log common ProxyRequests on ProxyPass / http://isy.homenetwork.domain.tld:80/ ProxyPassReverse / http://isy.homenetwork.domain.tld:80/ The network names all resolve etc, I can access the isy from the "inside" no problem using the 'isy.homenetwork.domain.tld' url given in the ProxyPass statement. Using the 'isy.domain.tld' url from the inside or outside, the web (html) gui works pretty well. Trouble starts when trying to use the 'admin console' applet. It looks as if it starts ok (the blue applet starts, the menus work), but then there is a error box that states XML Parse Error http://isy.domain.tld:80/desc . Clicking that away, the logon button in the file menu is disabled. Clicking on link management results in the following (partial) trace in the console: Exception in thread "AWT-EventQueue-2" java.lang.NullPointerException at com.universaldevices.ui.driver.rcs.RCSProductDriver.isModuleSupported(Unknown Source) at com.universaldevices.ui.driver.UDProductDrivers.addDeviceMenuItems(Unknown Source) at com.universaldevices.ui.UDMenuSystem.makeDeviceSubMenu(Unknown Source) at com.universaldevices.ui.UDMenuSystem.menuSelected(Unknown Source) at javax.swing.JMenu.fireMenuSelected(JMenu.java:1028) at javax.swing.JMenu$MenuChangeListener.stateChanged(JMenu.java:1107) at javax.swing.DefaultButtonModel.fireStateChanged(DefaultButtonModel.java:333) at javax.swing.DefaultButtonModel.setSelected(DefaultButtonModel.java:215) at javax.swing.JMenu.setSelected(JMenu.java:294) at javax.swing.JMenu.menuSelectionChanged(JMenu.java:1175) at javax.swing.MenuSelectionManager.setSelectedPath(MenuSelectionManager.java:100) at com.apple.laf.AquaMenuUI$AquaMouseInputHandler.mouseEntered(AquaMenuUI.java:134) at java.awt.Component.processMouseEvent(Component.java:6384) Any way to make this work via ProxyPass? The ProxyPass statement should be able to proxy any http request on port 80 of 'isy.domain.tld' to the isy on the inside. Is there another channel open which I'm missing with this proxy? (The error message says port 80, tho) Thanks for any help or clues, -Th
