tflores
  1. So another problem has arisen. I can now touch each button with the appropriate response following your instructions however is it possible to have control with mobilinc? If I go to scenes and or/devices, and select fan medium, it actually turns on all scene devices. Same for any other speed control button within the mobilinc app
  2. I linked each individual button through the devices themselves as described by the fanlinc instructions, holding down each button to correlate with the flashing of the fanlinc. Works great as a keypad but otherwise no control from the mobile app.
  3. If I may clarify, does this mean that each button needs to be set up as a scene?
  4. So my current projects is as followed 6 scene keypad connects to a fanlinc On-turns on Fan Fan High-Speed Control Fan Med-Speed Control Fan Low-Speed Control Fan Off-Off Off-Shut Off So the problem that I can't figure out is if I press the button fan high, then press fan medium, the speed switches correctly however the Fan High light on the keypad remains on. The second problem is that I cant directly change the fan speeds using mobilinc. I see an option for grouping but I don't understand this option very well and the ISY gives me multiple warnings.
  5. tflores posted a topic in ISY994
    I'm sure this conversation has been brought about before however some of the Google links provided seem to be outdated. I recently purchased a ISY994iZS/IR PRO without doing more research than I should have in regards to the ideas planned. Here are my objectives. 1. INSTEON home lighting...currently being implemented 2. Currently looking for a electronic deadbolt. I have seen many posts suggesting morning linc however trying not to be a Diva, the only finished provided do not match the rest of my house. 3. Purchased the Zigbee ISY hoping that maybe it would correlate with my Ecobee however just recently read that it doesn't. I have also read that if a Z-wave compatibility is released, will I have to remove the Zigbee module? Any update with Z-Wave?
