HowganTech
Everything posted by HowganTech
  1. Hope I've gotten everything here..... Sensors are all Insteon 2420M. Programming device is a 994i. Program is Universal Devices Admin Console (99i Administrative Console). When I look at the Main tab on the admin console and check any of the motion sensors, there is nothing listed in “Current Stateâ€. I’m assuming my predecessor did not program these devices before installing them. Is my assumption correct or not? There are three "Night time" Programs running. The first one is for Night time motion sensor trigger; code is as follows: If Control 'EAST END MOTION-Sensor' is switched On And Control 'EAST END MOTION-Sensor' is not switched Off Then Set Scene 'Front Stoop Motion' Fast On Wait 20 minutes Set Scene 'Front Stoop Motion' Off Else - No Actions - (To add one, press 'Action') “Front Stoop Motion†Scene encompasses all outside motion sensors (4 total). It is set this way for each of the different motion sensors on the property. All motion sensors are nested under one folder which has the following code applied to it: Another "Night Time" Program is as follows: Folder Conditions for 'Dark Outside' Add conditions to limit when programs in this folder are allowed to run. If On Sun, Tue, Thu Time is 9:00:00PM Or On Sat, Mon, Wed, Fri Time is 9:20:00PM Then Allow the programs in this folder to run. The other two other “Night time†Programs running. Code for AFTER SUNSET SMWF is as follows: If On Sat, Mon, Wed, Fri From 6:50:00PM For 3 hours Then Wait 20 minutes (Random) Set Scene 'Front Stoop Motion' On Wait 1 hour and 50 minutes Wait 20 minutes (Random) Set Scene 'Front Stoop Motion' Off Else - No Actions - (To add one, press 'Action') The last “Night Time†Program for AFTER SUNSET STT is as follows: If On Sun, Tue, Thu From 7:10:00PM For 3 hours Then Wait 20 minutes (Random) Set Scene 'Front Stoop Motion' On Wait 1 hour and 50 minutes Wait 20 minutes (Random) Set Scene 'Front Stoop Motion' Off Else - No Actions - (To add one, press 'Action') There is one “daytime†program running called Sunrise Off; code is: If From Sunrise + 10 minutes To Sunset (same day) Then Set Scene 'Front Stoop Motion' Off Else - No Actions - (To add one, press 'Action')
  2. Hi, I have taken over an installation and programming project from a former employee. I've finished cleaning up many issues with the programming except the fact that the Motion Sensors still trigger the outdoor lighting during the day. Is this by design? If by design, how do I program them to not trigger during the day? Thanks
