sandymctyre
Everything posted by sandymctyre
  1. Thanks LeeG for the prompt response. The KPL button is both a responder and controller in the scene already. Is there a different way to add it into the scene? Thanks, John
  2. Good day all, newbie to the forum, and to UDI / Insteon. I have an ISY994i running 3.2.6 and a 2487S V4.1. If I turn a scene off or on using the button on the KPL...the LED indicator turns on (or off) as the case may be. However, if I control as a scene through the ISY, the LED indicator never changes...so I cannot tell, looking at the KPL if a scene is off or on. Is there any way to have the indicator work, even if controlled through a scene? (ON when the scene is on...OFF when the scene is off?) Thanks, John
  3. Update: Had an epiphany and tried to guess the IP address, based on the first device...successful! Thanks, John
  4. Hi all, NOOB here. I am trying to hook up my third Insteon system using ISY994I, and this one is complicated... I have a house on a seperate hydro meter from a shop, and devices in both locations. Distance from shop to house is 100+ft. I have dual linc modules outside both locations, but the signal cannot bridge the distance (porobably because they are all in metal enclosures). The solution I would like to try is to have two ISY994I, one in the house, one in the shop...problem is...they are both on the same network. Is this possible? When i log into http://isy from a computer, I only find the first ISY connected. Any way to do this? Thanks, John
