dpierre
  1. Hello.... Approximately mid July I noticed the routines related to the Bond Bridge had stopped. I noticed there was an update, executed the update, no change. Totally deleted Bond from the ISY and the Polyglot dashboard, reinstalled, no change. Manually entered the hostname (IP) and token info, doesn't discover. The Bridge does PING on the network. Any thoughts out there? ISY is running on version 5.8.3 and the Bond looks like it's on 3.2.14 Thanks, Dan
  2. Hi Guys, Finally got around to set this up. Bingo! Both KPL are working and sync'd to control the fan. I realized the problem was that I didn't define the operation of the buttons in the scenes. Go figure, live and learn. Thanks for your time. Dan
  3. Thank you both for your input. I'll reattempt
  4. THIS IS A REPOST: Hello... Trying to control a fanlinc with two KPLs. One KPL is a an eight button the other is a six button. I have spent several hours and several iterations trying to get this to work and sync both keypads. Thought it would be pretty simple.... NOT! As a starting point I began with: https://wiki.universal-devices.com/index.php?title=ISY994i:INSTEON_Device:FanLinc-KPL_FanLinc_KeypadLinc_Configuration. Adding the second keypad in the mix. That was a NO-GO. Attempted too many things to try to explain here.... So, does anybody have a working configuration utilizing two KPLs that work, that I may plagiarize? I don't normally throw in the towel, but I'm at the end here. Any help would be appreciated.
  5. Hello... Trying to control a fanlinc with two KPLs. One KPL is a an eight button the other is a six button. I have spent several hours and several iterations trying to get this to work and sync both keypads. Thought it would be pretty simple.... NOT! As a starting point I began with: https://wiki.universal-devices.com/index.php?title=ISY994i:INSTEON_Device:FanLinc-KPL_FanLinc_KeypadLinc_Configuration. Adding the second keypad in the mix. That was a NO-GO. Attempted too many things to try to explain here.... So, does anybody have a working configuration utilizing two KPLs that work, that I may plagiarize? I don't normally throw in the towel, but I'm at the end here. Got yard work to do Thanks
  6. Not sure what happened... Logged in and my console (again) and the credentials populated to PG3x. Magic. Thanks for replying. Dan
  7. Good morning, I'm locked out of the Polyglot plugin. Does anyone know how to recover/reset password for PG3x? Any help would be most appreciated. Thanks, Dan
  8. DOH! You got me.... Thought I did install it. Anyway, that was the issue. Appreciate the input Paul. All is good. Regards, Dan
  9. Happy new year UDI team, Question.... I purchased the YOLINK plugin, but am not seeing it in either the PG dashboard or on the ISY. I do see it as a purchased plugin though. I've rebooted the system and reinstalled all of my current plugins thinking it would appear, no-go. The only thing I haven't done is updated the packages. Thought I'd check with you first. Firmware is 5.8... I know there is a new firmware package out, but saw it wasn't a major upgrade thought I'd hold off. Always get a bunch of water sensor alarms when I update, a little annoying. Any assistance would be appreciated, Dan
  10. Thank you for providing the above info
  11. Does anybody know or heard of, if there is an integration for Wyze Cameras within UD mobile? Thanks
  12. It was a browser issue. I normally run Firefox, attempted the process on Chrome. It migrated. Thanks for everyone's input.
  13. Oh man.... Too easy, now I remember seeing this. Thank you! Maybe you can tell me or direct me to the pros/cons of migrating to PG3x? The only reason why I'm wanting to migrate, is to try the "Notification" feature within UDI mobile and or the GEO fencing addition. Also when I attempt to go to the hyperlink I get a security error. See attachment. Thanks for replying.
  14. Hello... I have looked all over the place. How do you upgrade from PG3 to PG3x? I updated IOX to 5.6.3. Can't locate where in the PG where to update it. It's running on PG3 version 3.1.21 Thanks
  15. @tlightne Sorry just saw this... I was informed to reach out to z-wave alliance for my info. It's not complete but it helped. https://products.z-wavealliance.org/products/3898/configs
