palmer082
  1. Thanks for all of the replies. I'll give it a try.
  2. I have just recently installed an Insteon Garage Door Controller Kit.(74551) and am having some difficulty programming it the way I want it to work. I have tried various configurations on my ISY with no luck. What I am trying to accomplish is this. When the garage door is closed I want the ISY, and a KeypadLinc to indicate OFF . When the garage door is open I want them to indicate ON. I also want to be able to open or close the door from the single button on the KeypadLinc. In other words if the KeypadLinc button is ON the garage door is open. I can tap the button and close the door and the button goes off. Any suggestions are greatly appreciated.
  3. oberkc, Thanks for the quick reply. I will try the program as you state. Believe me I know I'm making this harder that it really is but I guess that comes with the learning process. I really appreciate your help and the help of others in this forum. "Your current folder condition (pump is off) allows included programs to run ONLY if the pump is off. If the pump is on, NONE of the included programs will trigger, including the program to turn off the pump." That's what I was trying to explain in my second post, so OUT with the folder and in with your program. Thanks again!!
  4. OK LeeG I think I now understand what you're saying after reading over your post many, many times. Because of the folder condition which indicates IF the controller is OFF run the programs in the folder, when my second program attempts to run it is checking if the controller is ON which is NOT the condition that the FOLDER (false) dictates therefore that program will not run. I hope I got it right. I'll play around with it when I get home.
  5. Thanks for the quick reply LeeG. I believe I understand what you are saying. Correct me if I'm wrong. Can I create the single program w/o the folder and leave the IF section empty. I thought something had to be in the IF section on a program. What I'm looking for is for the pump to go on say at 8:00AM-1100AM, then back on again at 3:00PM to 6:00PM, and then maybe 9:00PM to 11:00PM. I guess I thought that to do that I needed to put the separate programs in a folder in order for all three to work. Thanks again.
  6. I installed the load controller (normally open) to control a 240 volt pool pump. I want the pump to go on and off three times within a twenty four hour period. I created programs the same way that I did for turning lights on and off. The only problem is that the controller turns on at the programmed time but will no shut off at the programmed time. I've tried different ways of running the programs, like having it go on , then WAIT four hours and then OFF. I've actually set the times for ON and OFF but it will not shut off. I've even set up different programs within a folder, one program turning it ON and one program turning it OFF but to no avail. I'm pretty new to Insteon but I'm learning. This is one pair of programs I'm trying just to get it to work then I'll work from there: Folder Conditions for 'Pool Pump' Add conditions to limit when programs in this folder are allowed to run. If Status 'My Lighting / Pool Pump' is Off Then Allow the programs in this folder to run. If Status 'My Lighting / Pool Pump' is Off And Time is 8:00:00PM Then Set 'My Lighting / Pool Pump' On Else - No Actions - (To add one, press 'Action') If Status 'My Lighting / Pool Pump' is On And Time is 11:00:00PM Then Set 'My Lighting / Pool Pump' Off Else - No Actions - (To add one, press 'Action') Any help is greatly appreciated!
