SpencerM
  1. Both are good ideas...thanks! I managed to work it out in a slightly different way. I added the All off button as a responder in the scene and changed it's toggle mode back to regular on/off. I created a program that detects the state of the all off button. It that button is on then it sets the scene "All Off" to Off which turns off the devices I want and also turns off the keypad button. There is a slight delay (maybe a second or two) but this is fine since the point is just to make sure the devices get turned off.
  2. I have a Keypadlinc v.36 Button that is the controller for a Scene called "All Off" When I Turn the Scene Off in my ISY the behavior is as expected, all lights turn off. When I Turn the Scene On in my ISY it is a little odd, the lights all turn off (the On Levels are set to 0), so the lights are off but status lights turn on all over the house. Seems odd since the ISY even asked me what I wanted to do for devices that don't support On Level and I said Turn Off. Not a huge issue since I plan on using a non-toggle mode on the button that will just send the off command anyways. I am planning to control the scene from the Keypad Button. The toggle mode on the button is Non-Toggle Off. When I press the button at night, all the lights turn off in the house, including the status lights around the house. The problem is that the status light on my keypad is now lit up. When I look at the admin on the ISY the Current State of the button is Off even though looking at the keypad I can see clearly the button state is on. The only way I am able to get the keypad button off is if I run the scene off on my phone or tablet. I have restored the keypad....just not sure what could be causing this behaviour.
  3. I think you've cleared it up for me. They must just be showing the last command they sent. The scene details for the Dining Room Scene are: Controller: Dining Room Switch Controller: RemoteLinc 1 Controller: RemoteLinc 2 It just seemed odd to report the ON status...but Mobilinc is clever enough to show the Scene status as off. Admin is the only place I see the remotelinc as ON.
  4. Hi All, I have a question....I've just finished the initial setup on my ISY99, I'm coming from a Houselinc / Smartlinc setup so I cleared all links and re-linked everything fresh. Everything seems to be operating fine I've just noticed some oddities when viewing the system in the admin. Some of my scenes that have Remotelincs or Remotelinc 2 controllers show odd current states. For instance I have a Dining Area Scene that shows: Dining Lights: Off RemoteLinc 1 Dining Lights: On RemoteLinc 2 Dining Lights: 49% A similar thing occurs with my EZX10RF buttons. They show a current state of ON when I look at their scenes. What is with that? Is this normal? I causes some weirdness when I look at my admin, although Mobilinc seems to be ok and just shows the state of OFF for the scene.
