max90034
  1. I just moved to a new house. I moved ISY but 99% of devices is gone. I can do factory reset but I am wondering if I can clean all devices but keep other settings (like portal login, security, etc). Does it even make sense or may be factory reset is best option? I have now ~200 dead devices so I am definitely not planning to delete them one by one. Just to add that the first thing I am planning to do after reset is to update FW to 5.x Thanks, Max
  2. Thank you. I am using Venstar thermostat with insteon module. It is pretty reliable, I have 3 of them total. I am pretty sure that it shows set themperature in the log ( probably x2 indeed). I am trying to find out if it also reports room temperature in the log...
  3. Does ISY log save current room temperature or does it only save "set up" temperature set by user? I remember it has a record of set up one but potentially it can also have a record of the current room temperature since it has a sensor, right? Also, how to convert the temperature value saved by ISY to the real temperature? Thank a lot.
  4. I believe that subscription to simple control service is required before you can use any triggers.
  5. Do I still need SimpleControl Service to do this?
  6. Can you please explain just a tiny bit more? My understanding is that I need simple control sync soft to trigger my existing simple control scenes and then I need to subscribe to simple control service to incorporate Echo as described here: https://www.simplecontrol.com/wp-content/uploads/2016/01/SimpleControlEchoIntegration.pdf Thanks!
  7. I found more info about using roomie sync software. My major problem is that I am now using subscription free old purchase of roomie (simple control) with unlimited number of devices. It seems that to integrate Echo, I will need to buy $50/y subscription for 100 devices... I hate subscriptions and I had to buy ISY portal subscription already....
  8. It would be fantastic! I am searching for roomie ISY triggers but not very successfully. Can you please point me to any discussion of site when I can learn more? Thanks a lot!!
  9. I would like to control my Home Theater using Echo and ISY. I currently use Roomie that can access my devices either directly (by IP) or through GC-100 devices. I know that one way is to use ISY network resources and I have implemented few comments but I was never able to set all the comments I need. I can potentially map to ISY network resources all the IR sequences used by my GC-100 but it is way too much manual work for me. I read that ppl use Logitech Home Control. I know it would mean for me to reprogram all my scenes but I may want to try this approach. Is there any thread on how to use it with Amazon Echo and ISY portal? Any other suggestions? The simplest solution for me would be to start Roomie scenes from Echo/ISY but it seems to be not possible. Thanks. Maxim
  10. Just bought and set up isy portal, etc for Amazon echos and isy in the primary home. I have separate isy in vacation home. Do I need to pay $50 again to buy isy portal for it?
  11. Barry, I have it working. It was my mistake, I did not realize that I have to edit .ini file to enter login/password. Thanks again!
  12. Barry, first of all thanks so much for your time and efforts. It really contributes a lot to this whole project. I will run it again on PC hardware and will send you those files. Can you please just clarify how should I:"add the ini option in the systems section as follows: debug = All". Does it mean I should start the program from the term with this option? It has been a long time since I did something on the windows OS... Thanks!
  13. I just tried it on 3 computers running Win 7-64: 1) vmware 8 under MacOS; 2) Win 7 native on Mac through bootcamp; 3) Win 7 native on PC hardware (i7, 64 bit). In all the cases I got the same issue: (1) during installation I got error on copying 4 DLLs (expsrv.dll; ....., DAO???.dll). The only option I had was to select Ignore (2) I was able to start the program and it found ISY and Brigde running under Linux on Synology box (nothing was found when running from vmware but it could be my net problem). However, then it aborted with the following: AWS Emulator Configuration System is starting, Debug mode = All PNP Search has found 1 UDI ISY994 at address 192.168.0.55:80 uPnP Search Discovered UN-Declared Emulator at address 192.168.0.60:8080, Emulator count=1 PNP System located 1 Emulator at adress 192.168.0.60 HUE Initialization Process Beginning, time now is 15:34:10 HUE Getting list of devices from HUE Bridge1 at 192.168.0.60:8080 DBG SendToHUE has started, Bridge: Bridge1, message size=78, time=15:34:10 ISY Initialization Process Beginning, time now is 15:34:12 ISY Initialization Process, Completed, time now is 15:34:12 Abort Flag =25, retrieving ISY Devices. See Log for Details System cannot continue, aborting in 15 seconds ======================= Thanks!
  14. Barry, Do you think your program will run from vmware running windows 7 on Mac? Thanks, Max
  15. Thanks! Will give it a try.
