fox7
  1. Just a quick note to follow up on the 'Safari 7.0 not being able to save logs' issue discussed above. burke has posted this solution in another topic/thread: http://forum.universal-devices.com/viewtopic.php?f=25&t=12505&sid=bf3c11dd359c09813e2b3319a2d5c194&p=98059#p98030
  2. Hi Xathros: Yes, using FireFox v24.0 under Mac OS 10.9, I'm able to save more than once, without any problems. For example, filenames from 3 saves just now: ISY Error Log.v4.0.5__Fri 2013.10.25 11.23.46 PM.txt ISY Error Log.v4.0.5__Fri 2013.10.25 11.23.59 PM.txt ISY Error Log.v4.0.5__Fri 2013.10.25 11.24.17 PM.txt Patrick
  3. Hi Xathros: As was suggested in the other topic, I can confirm that using FireFox v24.0 (instead of Safari v7.0) does allow one to save log files without any problems, under Mac OS 10.9. Patrick
  4. Hi Knight: Using iOS 7.0 or 7.0.2 and clicking on a Home Screen shortcut, both resulted in the Load Config message (was never prompted for username/password). iOS 7.0.3 will prompt for username/password without the Load Config message. Hi Xathros: Using Mac OS 10.9, I did the following: - accessed my ISY Admin page with User ID and password - from the Tools menu, select Error Log -> am presented with a Save Log To... dialog -> the default filename is 'ISY Error Log.v4.05__Wed 2013.10.23 10.19.41 AM.txt' -> the default path presented is inside 'PluginProcess.app' - I change the path to my Desktop - click on the Save button The 'ISY Error Log...txt' file is not saved to my Desktop (or anywhere else, that I can see). I'm running Java 7 Update 45 (build 1.7.0_45) My Java Security is set to Medium. Patrick
  5. Hi Michel and Knight: I've since upgraded to iOS 7.0.3 on my iPhone and iPad. Now, when I click on a Home Screen shortcut (of http://10.0.2.202/WEB/INDEX.HTM) on my iPhone, I'm prompted for my ISY Login and Password. After entering the Login and Password, it works as expected. (no longer hangs on Load Config) I was hoping to be able to provide a copy of my Error Log for you, but after upgrading my MacBook Air to Mac OS 10.9, I'm not able to save error logs anymore (or any ISY logs, for that matter). Patrick
  6. Hi Michel: Here are the results. Patrick Time User Code Message Mon 2013/09/30 05:08:55 PM System -170001 [HTTP] 10.0.2.16:53197->80 Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51739->80 Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/INDEX.HTM Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/itouch.css Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51740->80 Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/udi.css Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/jtemp.js Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/jquery.js Mon 2013/09/30 05:09:44 PM System -170001 [HTTP] 10.0.2.19:51741->80 Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/cookie.js Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/isyajax.js Mon 2013/09/30 05:09:44 PM System -170001 [HTTP]: GET-->/WEB/camTypes.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51742->80 Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/jjson.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/common.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51743->80 Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/jstorage.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/flot.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51744->80 Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/hashch.js Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/udlogo.png Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/rest/config/ Mon 2013/09/30 05:09:45 PM System -170001 [HTTP]: GET-->/WEB/bg_menu.gif Mon 2013/09/30 05:09:45 PM System -170001 [HTTP] 10.0.2.19:51745->80 Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152-pr Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152-pr Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=3 Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152.pn Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=4 Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-152x152.pn Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=5 Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=6 Mon 2013/09/30 05:09:46 PM System -10108 Check log Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=7 Mon 2013/09/30 05:09:46 PM System -10108 Check log Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=8 Mon 2013/09/30 05:09:46 PM System -10108 Check log Mon 2013/09/30 05:09:46 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png Mon 2013/09/30 05:09:46 PM System -170001 [Auth] 10.0.2.19:51745->80, Num=9 Mon 2013/09/30 05:09:46 PM System -10108 Check log Mon 2013/09/30 05:09:46 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:46 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:09:46 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55280->80 Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/INDEX.HTM Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/itouch.css Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55281->80 Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/udi.css Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jtemp.js Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jquery.js Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55282->80 Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/cookie.js Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/common.js Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/camTypes.js Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:01 PM System -170001 [HTTP] 10.0.2.18:55283->80 Mon 2013/09/30 05:10:01 PM System -170001 [HTTP]: GET-->/WEB/jjson.js Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/flot.js Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55284->80 Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/hashch.js Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/isyajax.js Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55285->80 Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/jstorage.js Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/udlogo.png Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/rest/config/ Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55285->80, Num=10 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/WEB/bg_menu.gif Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] 10.0.2.18:55286->80 Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120-pr Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=11 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120-pr Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=12 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120.pn Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=13 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-120x120.pn Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=14 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=15 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:02 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:02 PM System -170001 [HTTP]: GET-->/apple-touch-icon-precompose Mon 2013/09/30 05:10:02 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=16 Mon 2013/09/30 05:10:02 PM System -10108 Check log Mon 2013/09/30 05:10:03 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png Mon 2013/09/30 05:10:03 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=17 Mon 2013/09/30 05:10:03 PM System -10108 Check log Mon 2013/09/30 05:10:03 PM System -170001 [HTTP]: GET-->/apple-touch-icon.png Mon 2013/09/30 05:10:03 PM System -170001 [Auth] 10.0.2.18:55286->80, Num=18 Mon 2013/09/30 05:10:03 PM System -10108 Check log Mon 2013/09/30 05:10:03 PM System -170001 [HTTP] Closing socket normally Mon 2013/09/30 05:10:03 PM System -170001 [HTTP] Closing socket normally
  7. Hi Michel: Unfortunately the button to 'Add to Home Screen' doesn't present itself until after the web page has been loaded in Safari. (i.e. until after the URL is resolved as http://10.0.2.202/'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM) Also, there is no way to edit the URL used by a Home Screen shortcut. Creating a Safari bookmark, on my iPhone of either http://10.0.2.202/ -or- http://10.0.2.202/WEB/INDEX.HTM works fine. On an iPad, running iOS 7.0.2, the results are slightly different: - a Home Screen shortcut accessing http://10.0.2.202/WEB/INDEX.HTM still doesn't work (same as iPhone) - using a a Safari bookmark, of either http://10.0.2.202/ -or- http://10.0.2.202/WEB/INDEX.HTM results in an "Authentication Required" dialog. Entering acct/pswd of admin/admin allows access to the web page. Subsequent use of either bookmark does not require authentication, just direct access to the web page. Patrick
  8. Whenever I try to use an iPhone HomeScreen Shortcut to access the default web interface of my ISY994i (v4.0.5), under iOS 7.x, the shortcut hangs. I didn't have any problems under iOS 6.x. For example, on my iPhone 5, using iOS 7.0.2: - use Safari to access my ISY994i by going to http://10.0.2.202 - Safari will resolve to http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM'>http://10.0.2.202/WEB/INDEX.HTM - tap the middle button at the bottom of the Safari screen to "Add To Home Screen" - a Home Screen Shortcut will be created to access http://10.0.2.202/WEB/INDEX.HTM If I tap on that newly created Home Screen Shortcut, the Universal Devices logo appears, but the page gets hung up on "Load Config" and doesn't display anything else. (screenshot attached) If I use Safari on my iPhone and manually enter http://10.0.2.202/WEB/INDEX.HTM it works fine. Any suggestions for getting Home Screen Shortcuts to my ISY994i working under iOS 7.x? Thanks for any help. Patrick
  9. Here's a picture of the limitation I'm running into. When programming the ISY, the pop-up values for temperature, only go up to 122. Preventing me from testing a 140 to 150 range.
  10. My goal is to monitor my solar hot water heater, and to turn on a recirculation pump whenever the water temperature reaches 140 degrees or above, and off if the water temperature falls below 140 degrees. I purchased an INSTEON Wireless Thermostat (2441ZTH) and a Waterproof Temperature Sensor for INSTEON Wireless Thermostat (2433A3). I saw the post by jmed999 showing how to get the Wireless Thermostat to report the external Waterproof Temperature Sensor readings to the ISY (instead of its internal temps). http://forum.universal-devices.com/viewtopic.php?f=26&t=9833&p=74607&hilit=waterproof+temperature+sensor#p74607 I've confirmed with the Smarthome INSTEON support line that the external Waterproof Temperature Sensor supports temperatures up to 185 degrees. The problem I'm running into, is that within an ISY program, the ISY994i only supports temperatures up to 122 degrees. Any suggestions on how to get the ISY to monitor temperatures up to 150 degrees or so? If it turns out this isn't possible with this combination of hardware, are there any other INSTEON solutions for monitoring temperatures up to 150 degrees or so? Thanks for any help. Patrick
