Roman
  1. Ditto just as I was reprogramming things, thought I had really screwed up my app, now I see everyone is having issues, hopefully a simple fix soon.
  2. Up and running with IOS 15.3, so something definitely was/has been fixed. Thanks Roman
  3. Did a couple of resync, update only to the OrchMobiLinc, and seems to be working today. Let us see if it maintains.. Roman
  4. Well my iPhone12Plus working like a charm, still not consistent with the iPhone7Plus... I know it was mentioned to deleted the variable in the ISY.. Do you just leave the phone alone and let the phone update the ISY ? Roman
  5. So wanted to give it a day or two before I responded... Had to delete OrchMobiLinc from the iPhone completely reinstall and reset the GEOFENCING, as well did delete the variable from the ISY. This procedure though a bit time consuming did end up working the best for me thus far. Roman
  6. Still working on my wife's iPhone.. Removed the GEOFENCE variable from ISY and resync still issue, did you by chance have to completely remove the app from the phone... I did so much with mine now not certain what steps in the past helped with me upgrading to 15.3 which on my phone working no issues.
  7. So my iPhone no issues, with regards to my spouse, had issues so just now deleted the geofence variable in the ISY, and setup a new variable on the phone syc'd to the ISY, fingers crossed... Her phone was untouched and never upgraded to IOS 15 until 2 days ago so probably why I had to do this. With myself I had done these steps when trouble shooting why the geofencing was not working during the upgrades of IOS 15.. Keep you posted, but it looks like the above is necessary... Roman
  8. Upgraded IPhone to IOS 15.3, took a bit of time. Using OrchMobiLinc app... did an "update only" to the app on my IPhone, just in case. Been in and out of the GEOFENCE only once but it did work... Roman
  9. Initial test is showing that GEOFENCING seems to have been fixed in version IOS 15.3... Anyone else wish to confirm ? Roman
  10. Anyone having any success with GEOFENCING with IOS 15.3 that just came out ? Roman
  11. Upgraded last week to IOS 15.2.1 and at first seemed to have worked but now consistently nothing. All started with IOS version 15.. GEOFENCING has been broken hope it gets fixed in next release.. I believe some are running IOS 15.2.2 and same issue GEOFENCING not working ?
  12. Looked for the auto update on my IPhone still no 15.2.2 update listed for me, as soon as it become available will definately post results.. Now you have me excited... Roman
  13. No luck using OrchMobiLinc and the ISY portal... Using IOS 15.1.1 Roman
  14. Just got the IOS 15.1.1 update notification and installed. Only note I seen was a fix for dropped calls on iPhone 12 & 13.. I guess one can only hope GEOFENCE is fixed but doubt it... Well let us see what happens next few days.. Roman
  15. Just received an update and installed IOS 15.1.1. Only notes I see is it improves dropped calls for iPhone 12 and 13.. Doubt that the GEOFENCE got fixed but one can only hope... will see for just installed the update. Roman
