Roman
Everything posted by Roman
  1. Ditto just as I was reprogramming things, thought I had really screwed up my app, now I see everyone is having issues, hopefully a simple fix soon.
  2. Up and running with IOS 15.3, so something definitely was/has been fixed. Thanks Roman
  3. Did a couple of resync, update only to the OrchMobiLinc, and seems to be working today. Let us see if it maintains.. Roman
  4. Well my iPhone12Plus working like a charm, still not consistent with the iPhone7Plus... I know it was mentioned to deleted the variable in the ISY.. Do you just leave the phone alone and let the phone update the ISY ? Roman
  5. So wanted to give it a day or two before I responded... Had to delete OrchMobiLinc from the iPhone completely reinstall and reset the GEOFENCING, as well did delete the variable from the ISY. This procedure though a bit time consuming did end up working the best for me thus far. Roman
  6. Still working on my wife's iPhone.. Removed the GEOFENCE variable from ISY and resync still issue, did you by chance have to completely remove the app from the phone... I did so much with mine now not certain what steps in the past helped with me upgrading to 15.3 which on my phone working no issues.
  7. So my iPhone no issues, with regards to my spouse, had issues so just now deleted the geofence variable in the ISY, and setup a new variable on the phone syc'd to the ISY, fingers crossed... Her phone was untouched and never upgraded to IOS 15 until 2 days ago so probably why I had to do this. With myself I had done these steps when trouble shooting why the geofencing was not working during the upgrades of IOS 15.. Keep you posted, but it looks like the above is necessary... Roman
  8. Upgraded IPhone to IOS 15.3, took a bit of time. Using OrchMobiLinc app... did an "update only" to the app on my IPhone, just in case. Been in and out of the GEOFENCE only once but it did work... Roman
  9. Initial test is showing that GEOFENCING seems to have been fixed in version IOS 15.3... Anyone else wish to confirm ? Roman
  10. Anyone having any success with GEOFENCING with IOS 15.3 that just came out ? Roman
  11. Upgraded last week to IOS 15.2.1 and at first seemed to have worked but now consistently nothing. All started with IOS version 15.. GEOFENCING has been broken hope it gets fixed in next release.. I believe some are running IOS 15.2.2 and same issue GEOFENCING not working ?
  12. Looked for the auto update on my IPhone still no 15.2.2 update listed for me, as soon as it become available will definately post results.. Now you have me excited... Roman
  13. No luck using OrchMobiLinc and the ISY portal... Using IOS 15.1.1 Roman
  14. Just got the IOS 15.1.1 update notification and installed. Only note I seen was a fix for dropped calls on iPhone 12 & 13.. I guess one can only hope GEOFENCE is fixed but doubt it... Well let us see what happens next few days.. Roman
  15. Just received an update and installed IOS 15.1.1. Only notes I see is it improves dropped calls for iPhone 12 and 13.. Doubt that the GEOFENCE got fixed but one can only hope... will see for just installed the update. Roman
  16. Not using Locative but using OrchMobiLinc. That said we have concluded that IOS 15.1 location services does not work on most apps and more and more posts have confirmed this. That said I am reading that IOS 15.2 should be out next 2-3 weeks, anyone Beta testing IOS 15.2 and does it fix the location issue that we are experiencing within IOS 15.1 ? Curious...
  17. No such luck, using OrchMobiLinc... Deleted GEOFENCE, in ISY, within then completed deleted and reinstalled OrchMobiLinc, created new GEOFENCE, no success... Though manually can set the variable, did noticed as soon as I upgraded to IOS 15.x that when I would enter and exit the GEOFENCE location was no longer getting notifications that I had entered and existed the GEOFENCE.. every once in a while very very scarce it would work, but as mentioned before seemed to help if I opened the Maps app, Find My iPhone app, and also had just opened the app OrchMobiLinc.. which when opened noticed now gives me the Disconnected from MobiLinc error and then connects within 15-30 seconds.. Definitely I would conclude issue with IOS 15.x Roman
  18. This makes so much more sense for my iPhones still on version 14.x working without any issues, thank goodness I only updated my iPhone to version IOS 15.1... I can live with this until the fix comes.. I also notice a huge lag in Find My iPhone almost takes 30-60 seconds to sync up to find my iPhone...
  19. Thank you Wes for all your assistance... Definitely an issue with IOS version 15.X is what I am concluding. Roman
  20. Well I have 2 iPhones iPhone 7 and iPhone 7Plus still running IOS14.x, no issues, Upgraded my phone iPhone 12 Pro Max to IOS 15.1 and having GOEFENCE issues using the app OrchMobiLinc... but only on the iPhone with IOS15.1... So I would conclude for now that IOS 15.1 is buggy... I do occasionally have the iPhone GEOFENCE work but maybe 10% of the time.. Hopefully next update will fix this issue... Roman
  21. Thanks Wes, well upgraded to IOS 15.1 on my Apple 12 Pro Max.. and Notice unlike my Iphone 7plus running still on version IOS 14.x when I enter GEOFENCE zone, 7Plus consistently updates but my new Iphone 12 running IOS 15.1 do not see the notifications consistently that I have entered or exited my GEOFENCE zone as well or obviously then the variable of me entering/exiting does not change from 0/1 etc.. Though upgrading to IOS 15.1 did start having some success but definately not consistent. Almost as if the software is going into sleep mode ??? Roman
  22. Trying to use the ISY Portal so that I do not have to Open any ports on the router. That said my IPhone 7 Plus working fine however upgraded another IPhone to 12 PRO MAX and it seems location/GEOFENCE not working using ORCHMOBILINC app on IPHONE. Cannot change settings on the APP when connected to ISY Portal as far as GEOFENCE variables go, yet no issues when using WiFi... Anyone else having issues Also both the IPhone 7 Plus and IPhone 12 PRO MAX on IOS 15.1 Thanks Roman
  23. Seems I have resolved.. Had to increase the Timeout setting to 5,000 as well, check my junkmail for the TEST email.. Sorry for the inconvenience.. Did not even think of going back to the basics.. Roman
  24. I seem to be having email setting issues on the new version of 5.3.0 just upgraded from version 5.0.9. I noticed that my email settings went back to default.. Inputted all values, only issue is I am getting a Mail server failure {From timed out} only value that at this point would be off would te the Timeout (ms) value what value is recommended here ? Thanks Roman PS.. cannot remember what I had for thought this would just be retained.
