lukeharrington
  1. I may be in the wrong area and if so feel free to move. Im trying to simply make it possible to use my harmony one remote and when I am on the activity "watch a blu ray" that the play button dims my insteon and isy994 controlled lights and pause and stop brightens them. Seems simple but I cant figure out what I need as far as hardware and or software. Thanks
  2. You guys are amazing I remembered that I had installed a remote controlled fan and light dimmer (cheap one from lowes) about two years ago. So all I need to do is simply remove it and my newly installed switches should work at full brightness? Separate question.. Where is the best source for info on how to do programs with the isy. I feel so dumb when working with them
  3. Fast on gives the same dim result
  4. Sorry. No. Not a fan linc. A seperate switchlinc controls fan. I'm using the toggle linc as the load controller. Admin console shows 100 percent. Replaced the bulbs I haven't checked voltage at the light. I'll do that this evening and report back. Thanks so much for the prompt replies
  5. No sir. I didn't. It's part of a fan (which works fine still). I'll do that. Thanks Any other ideas ?
  6. Hello Im a long time lurker and have a question that im simply unable to figure out. I have an ISY-994i running an insteon network throughout my home. I have about 100 devices with numerous scenes and programs. I recently installed a 6 button Keypad linc and a toggle linc in a new room, created a scene, and made both devices controllers within the scene as ive done many times before with no issues. The scene responds properly in that it turns on and off from both devices as well as some remotes and control lincs and in the admin console. The problem is that the light that is controlled is much dimmer than before with regular switches. Ive checked that all the items in the scene are correct so that scene level and device level is at the highest. Ive also made sure I have 120 volts going to the light from the load wire attached to the toggle linc. The light seems to flicker some also. What am I missing? Thanks again
