pkeberly
  1. pkeberly replied to pkeberly's topic in ISY994
    Now I'm really confused... I've been playing with the settings to try and get what I want. The dimmers seemed to do things that the ISY scene and program don't ask for. I deleted and installed the nite dimmer, with remove existing links checked. The other dimmers appeared to remember the removed dimmer, but the membership tree doesn't have the Nite dimmer in any device? I pulled up a device link table and the Nite dimmer is in there? A compare shows all identical so ISY thinks it should be there (I assume?) Is the device membership tree the same as a device link table? Is there a place to edit the link table to remove any errant links? Thanks,
  2. pkeberly replied to pkeberly's topic in ISY994
    Thanks Lee, that's the way I had it, and it doesn't seem to work? A local press goes to 100%. An ISY ON and it goes to 30%. I suspect I have a conflict in the other 4 way scene. I did a link table compare and have two ignores that are valid devices, I'll dig a bit deeper into that. Happy Thanksgiving, Paul
  3. pkeberly posted a topic in ISY994
    Hi all, I'm a newbie to Insteon and the ISY-99. So far I just love it, but I just can't seem to get my idea to work correctly. I'm not sure if it can be a scene, need to be written as a program, both, or some other way that I haven't learned yet. We have 5 kitchen cans (main) on one dimmer, and a single can (nite) on another dimmer. I also have 2 other dimmers that are virtual 4 ways to the main. Our concept is when the 5 main lights are on/off, the nite lite follows along. When the nite dimmer is pressed, the mains go off and the nite is dimmed down. I have the 4 way as a scene, and the nite dimming as a scene. All works as planned except for the dimming of the nite, it goes to 100%. Any ideas on what I'm doing wrong here? Thanks, Paul
