Issacsim
  1. Any update on how to setup Lifx node ?
  2. Got it, thanks!
  3. Moderator please delete, got posted twice,
  4. Is there a way to remove a scene from a a button in a KPL? I would like to avoid resetting all buttons on the KPL.
  5. Is there a way to remove a scene from a a button in a KPL? I would like to avoid resetting all buttons on the KPL.
  6. There are 2 wires, I just closed the circuit.
  7. Thank you oberkc, I did check. When connecting the wires, the controller resets and door does not open.
  8. Thanks, will explore both options.
  9. I am using Chamberlain Model # HD920EV I purchased at the home depot. I have contacted Chamberlain support, and there is no way to use a simple open/close switch with this unit. I guess my next step will be is to take the RF remote apart and try soldering some wires to the on/off button.
  10. On the topic of garage doors, did anyone figure out a way to connect the kit to one of the newer encrypted garage door openers?
  11. Also keep in mind that Smarthome made changed the magnetic contact in the kit, so maybe the wiki needs updating. The only reason I started this thread was that I was getting oppsite results from the WiKi.
  12. Thank you!
  13. Thanks LeeG, Do I need to get a new magnet switch? If yes, could you recommend one?
  14. I just installed the Garage Door kit model: 74551 and followed the instructions in the Wiki to program into ISY. The problem I am having is the KPL button is on when the door is closed and off when open, status LED on I/O Link is green when door is closed as per instruction that came with the kit. The Wiki refers to different color wiring, my kit came with all white wires. How can I fix this?
  15. Thank bsobel Makes sense, thanks! It works fine now.
