PLCGuy
  1. Hi Javi Thanks for such a detailed reply. For some reason the forum didn’t inform me of your reply but now that I’ve seen it I’m going to try it out, especially your idea for the variables.
  2. Hi Inspired by Javi's cool idea "Favorite Custom Toggle" in the UD Mobile Wiki, I started trying to develop a full-fledged lock management strategy for UDMobile and the EISY. In particular, the last comment in the sample logic "This is a simple example, a real installation should include checks for things like door open status" really seemed to throw down the gauntlet - it got me thinking about what a "Real Installation" should achieve. The following is my effort to date - I thought I'd throw it out to the UD community to critique and suggest improvements. First, what are the requirements for a "real" lock management system? Assuming the system is using Z-wave smart locks and an ELK alarm system for door status, these were the initial requirements that I came up with: Users should only be able to lock a lock if the door is closed. Users should have full visibility of the lock's status in a single lock object on the Favourites tab. The typical user will only work from favorites and there should be no need to for them to click around to other screens or objects determine status - it is best if it is all visible in one "Lock Object". At a minimum, users should be able to determine with a single look at UD Mobile Favorites if a door is one of the following states: closed and locked, closed and unlocked, open or in a trouble/fail/dead battery state The battery level should be displayed on the Lock Object, as that will impact the ability to lock It should be efficient to program and operate. (I have quite few locks, so I don’t want something that requires ten programs for each lock.) Q1: Did I miss anything? Assuming I didn't, achieving Req #1 was easy. I just added an AND condition to the If statement in the Lock Toggle program to check if the door was closed (aka “Normal” in Elk Alarm speak). Here is the revised version of Jari's program: Toggle KtchDr_Lock - [ID 00A9][Parent 0019][Not Enabled] If 'Door Control / ZW Locks / KtchDr_Lock (ZY007 Door Lock)' Status is not Locked And 'Alarm / House Alarm System / Kitchen Dr' Logical Status is Normal Then Set 'Door Control / ZW Locks / KtchDr_Lock (ZY007 Door Lock)' Lock Else Set 'Door Control / ZW Locks / KtchDr_Lock (ZY007 Door Lock)' Unlock // This program must be disabled or every time the KtchDr_Lock is unlocked (not Locked) the KtchDr_Lock will lock. // The status is "not locked" as there are multiple status values such as "unlocked", "locked", "Jammed", and "unknown". // Door open status must be Normal (aka closed) for the KtchDr_Lock to lock, otherwise it will unlock. Req #2 has been more of a challenge as displaying states that rely on more than one device requires using variables as flags. In this case I wanted to combine the door status from my Elk with the lock status from the Zwave lock. I'd hope to write a simple program that would mathematically combine the integer values coming from these two devices into a single door status variable. Maybe something like tghis: 0= Closed and Locked, 1= Closed and Unocked 2= Open 3= Trouble Unfortunately I wasn't able to dream up a math function to generate such a status variable because the Elk reports door status as: 0= Normal (aka closed) 1= Trouble 2= Violated (aka open) 3= Bypassed While the Yale lock report lock status as: 0= Unlocked 100= Locked ?= Jammed Instead I wrote a program that mashes together boolean logic with math operations, which IMHO is rather inelegant. This program checks if the door is both closed and locked and if it is, runs the Then branch to set the Door_Flag to 0. Otherwise it sets the Door_Flag to 1 if the door is closed and adds door status - the lock status is ignored in this case (which is a bit ugly). The flag is interpreted as follows: 0= Closed and Locked, 1= Closed and Unlocked, 2= Trouble and 3= Open (lock status unknown). Here is the program: KtchDr_Door_Status - [ID 0022][Parent 0021] If 'Alarm / House Alarm System / Kitchen Dr' Logical Status is Normal And 'Door Control / ZW Locks / KtchDr_Lock (ZY007 Door Lock)' Status is Locked Then $Ktch_Dr_Door_Flag = 0 Else $Ktch_Dr_Door_Flag = 1 $Ktch_Dr_Door_Flag += 'Alarm / House Alarm System / Kitchen Dr' Logical Status // The program checks if the door is both closed and locked and if it is, sets the Door_Flag to 0. Otherwise it sets the Dr_Flag to 1 if the door is closed (0) but unlocked (1+0) and 3 if the door is open (1+2) - the loock status is ignored.. // The flag is interpreted as follows: 0= Closed and Locked, 1= Closed and Unocked 2= Trouble and 3= Open (lock status unknown) // FYI Door Status values from the Elk are 0=Normal, 1=Trouble 2= Violated and 3=Bypassed. Then I headed into UD Mobile to build the Lock Object in Favorites. It took Javi's configuration design and pointed it to the Door_Flag, rather than the lock. I also had to adjust the Advanced Configuration Status to display the Flag. This is the configuration and the end result: It works pretty well and my family is happy with it. However it has some serious limitations: It doesn't display the battery level of the lock. It neglects all the other door and lock status info, which I'm sure will cause me trouble one day. The icon doesn't change because I couldn't find a representative icon for a smart lock that might indicate the various states. Yes I tried using the open and closed padlock symbol, but it just confused everyone. @Javi - please add more door icons or let us load our own. For example, sliding door icons in an open and close state would be very nice. I'd really appreciate any feedback and improvements to this design. If anyone can solve the missing features in an elegant way or come up with a clean math function I'll send you the $10 Starbucks gift card sitting beside me on my desk 😀
  3. Yes - almost identical. Now what is really strange is the Elk Node has now reconnected and seems to be fine. The only changes I made bbefore it started working again was: a) to upgrade the packages on the EISY, which necessitated a reboot. But I had tried a reboot earlier. b) to change the user name on the EISY admin account name from Admin. But I assumed that the Elk Node would not care about the EISY admin account - maybe it does. And I subsequently changed the name back and it doesn't seemed to harmed the connection this time. Either way, the system is working well now, but I'm not a whole lot smarter Thanks for reach out!
  4. I did - maybe I'm missing the obvious, but other than the host IP address (which is correct) there isn't any setting in there that I can see that could cause the Elk Plugin report "Disconnected". Interestingly, it seems that the logs are also failing. When i try to get the log I get this message "File not found: /var/ployglot/pg3/ns/00221b9026077_5/logs/debug.log Any troubleshooting ideas? I suspect this is a trivial fix (as nothing much has changed), but without logs or any other settings I'm a bit stumped.
  5. On the weekend i replaced my decade old Apple Airport Wifi mesh system. All IP addresses remained the same and the transition seemed to be flawless. Then 48 hours ago the EISY lost contact with my Elk system. All I can determine is the Elk Plugin report "Disconnected" when I view it in the Polyglot 3x console. Frankly it has been so long since I set this up, I don't even remember where to enter the Elk's IP address in the NodeServer. What are the troubleshooting steps I should be following to solve this? Thanks.
  6. Hi SteveB I've been having exactly the same issue with my Elk Node Server so I strongly suspect that this is PG3 issue and not an issue with the individual node server plugins. Now my Elk NS actually started to work correctly on the weekend after several attempts at reinstalls from the PG3 portal and at least 3 reboots of the EISY. I'm unsure exactly what got it working in the end but it might have been a "Restart" from the Elk Node Server Details page immediately after a Reboot of the EISY. I definitely did not have any luck deleting and reinstalling the Elk NS - it started working after a restart or reboot event. I also caught the issue before my trial expired, so don't blame yourself for missing the trial expiry date. That doesn't seem to be related.
  7. Hi Dennis I see that @SteveB is having the same problem with his Ecobee Node Server So I strongly suspect that this is PG3 issue and not an issue with the individual node server plugins. Now my Elk NS actually started to work correctly on the weekend after several attempts at reinstalls from the PG3 portal and at least 3 reboots of the EISY. I'm unsure exactly what got it working in the end but it might have been a "Restart" from the Elk Node Server Details page immediately after a Reboot of the EISY.
  8. Hi I just noticed the following ELK Notices message on my Elk PG3 dashboard: "The subscription for this node server will expire tomorrow" Now after testing the Elk Node Server in my new EISY, I fell in love with it and purchased a subscription last month (Order 3HD38148JM4462532). What step have I missed to get the purchased version installed and the trial version disabled? Thanks.
  9. Thanks everyone. I removed the KPL and wired it to a line voltage pigtail. It appears to be toast. .
  10. I have an old Insteon 2486D KPL in an area that recently underwent some renovations. Now my EISY won't connect to it. I noticed the electrician never connected the red load wire, which makes sense as I don't think it was connected before - I can't think of a light the KPL might have controlled directly. However maybe it was connected - can a KPL work without a load? If so, what should I do with the red wire. Just cap it off?
  11. Thanks Geddy - I probably knew that a decade ago when iIfirst programmed my isy-994. I forgot that the partly green icon indicated the program was not currently running, but last ran THEN code. My bad...
  12. I just migrated from an ISY to an eisy and have a very simple program that is triggered by a scheduled IF and is staying always True. You can see in the screenshot below that the time of day is 7:44:23 PM and the program is still true and has been since 2:00:00 AM. I've tried disabling the program, rebooting the eisy, etc and I always that the program remains true once it is triggered at 2:00 :00 am the next morning. I had expected the program to be False at say 2:00:01 am. Am I missing something or is this a bug?
  13. Never mind... found the answer and all seems to be working well 😄 WaterLvlCalc - [ID 0012][Parent 0013] If 'Alarm / House Alarm System / KitchenKeypad' is switched F4 Then $ElkWtrVoltage = 'Alarm / House Alarm System / Water Level' Voltage Volts Wait 2 seconds $WtrGallons = 10 $WtrGallons *= $ElkWtrVoltage $WtrGallons *= $SlopeDiv10 $WtrGallons -= $Offset $WtrLvl = $WtrGallons $WtrLvl /= $GallonsPerInch Set 'Alarm / House Alarm System' Display Message $State_LvlCalc = 1 Wait 10 seconds Set 'Alarm / House Alarm System' Clear Message Else - No Actions - (To add one, press 'Action') Wait for a trigger to calculate cistern $WtrGallons (= 10 x $ElkWtrVoltage x $SlopeDiv10 - $Offset), $WtrLvL = ($WtrGallons / $GallonsPerInch), and then display the level on the Elk Keypad
  14. Is there any way to take the voltage level from an Elk Zone and use it in an eisy math function? I currently have an exceptionally ugly set of IF statements in my old ISY-994 that has 100 variations of the following: =================================================================================== Chk02xVolt - [ID 0036][Parent 004D] Folder Conditions for 'Chk02xVolt' If Elk Zone 'Water Level' 'Voltage' >= 2.0 Volts And Elk Zone 'Water Level' 'Voltage' <= 2.9 Volts Then Allow the programs in this folder to run. ----------------------------------------------------------------------------------- Chk020Volt - [ID 0016][Parent 0036] If Elk Zone 'Water Level' 'Voltage' is 2.0 Volts Then $ElkVoltageX10 = 20 Else - No Actions - (To add one, press 'Action') Test if the Elk Voltage is 2.0 Volts and if so, set $ElkVoltageX10 to 20 (i.e. ten times the voltage) ----------------------------------------------------------------------------------- and so on... Is there a nicer way to do this in the esiy using the Elk Node Server?
  15. I'm working on migrating from my old workhorse ISY944 to a shiny new eisy with the ZMatter Dongle. I have been stuck at 5.0.16C for a while because I have a 300 Series Z-Wave board, and while Michel was very generous in offering to help get me a loaner 500 Series Z-Wave board, I decided it would be simpler to do a restore from a 5.0.16 back up to the eisy and rebuild my Z-Wave network from scratch. Now I've completed a restore from a 5.0.16 backup to the eisy, and that went pretty well. And I was about to manually remove all my Z-Wave devices from my ISY994 and add each to my eisy. However, I noticed that all the restored programs in my eisy that reference Z-Wave devices are pretty much a mess. This is more of an issue as some are relatively complex, and frankly, I don't remember all the details of creating them (yes, I'm guilty of some pretty poor documentation in my old ISY logic). So, I was wondering if I could use the "Shift Primary to another Controller" option I see in the ISY's menu to move my old 300 Z-Wave network to the new eisy, or is that just asking for trouble? Finally, I remember using a text editor to do bulk edits to some 50 ISY programs about a decade ago. That could also solve my Z-Wave program migration challenges. However, I don't remember how I did that. Can someone remind me? Thanks
