sbex55
Everything posted by sbex55
  1. Hello. I'm having a problem with a KeypadLinc I recently installed. I placed an 8-Button Dimmer (2334-2 V .43) on my wife's nightstand. I linked and programmed one of the buttons (G) to an ApplianceLinc to control her table light. This has worked reliably. My problem is when I try and use another button to control a device connected to my Elk security panel. Here is the program I use: If Control 'Dar Keypad F' is switched On Then Set Elk Audio 'Master Bedroom' 'ITouch' Volume Up Else - No Actions - (To add one, press 'Action') When I press the "F" key it doesn't do anything. When I push the "F" key again (typically) it makes a long beep sound and then the entire keypad stops working. Sometimes not on the second press of the "F' key but eventually it happens. I then have to reset the keypad and re-link it. Either my program is screwing this keypad up or it's defective. Any help would be appreciated.
  2. Now it's clear. Thank you both for the help!
  3. Thank you for your responses. I was not aware the remote had to be in line of sight to the ISY. My ISY is located in the basement. The remote activity now shows up in the event viewer when I'm in line of sight. Since I can successfully use my RemoteLinc2 on the 1st floor I thought the Harmony remote would also work on the 1st floor. I guess not. I do have an access point on the 1st floor in line of sight of the remote but it still does not work. So do I assume the remote does not have the 'power' as the Remotelinc2 or something else? Thanks for the help!
  4. Thanks for the reply. The 1100 is a touchscreen so I don't think I have to assign IR Codes to 'buttons'. Just to try it I assigned 'Light1' to the (physical) mute button. Still no luck. For the ISY experts, if I am not seeing any activity on the Event Viewer when I press 'Light1' then does that mean the IR codes sent from the harmony remote are not valid or recognizable by the ISY? How do I diagnose this problem? Thanks for the help!
  5. I've setup my ISY99i/IR PRO by importing the default IR codes. I've setup my Harmony 1100 by adding a UDI device ISY99i/IR PRO. I've created a program that turns on a light when the 1st IR button on the Harmony device is pressed. I get no response and I see no activity under Event Viewer. When I use ISY99i/IR PRO to setup the Harmony device, the buttons are 'Light1', Light2', etc. When I use ISY99i/IR to setup the Harmony device, the buttons are 'IR001', 'IR002', etc. Neither setup worked. I know my IR works since I use a Remotelinc 2. I know the Harmony works since I can control other devices. What's wrong with my setup? Thanks for the help!
