dizzyjay
Everything posted by dizzyjay
  1. I believe it's a dimmer: KPL (#2486DWH8); I just tried the suggestion of deleting/factory reset of one of the 2 KPL and it did not resolve the issue appreciate the attempts.
  2. thanks for hanging in there with me LeeG; both interfaces are 3.3.4; a factory reset & restore on one of the KLP did not fix. to confirm how i set everything up i made another scene with just the light on the KLP (node A) and assigned it to another button (node C) on the same KLP (as a responder); it did not work either. If i run it from anywhere other than the KLP, it works fine.
  3. I ran thru the tests and it did not fix; I also upgraded the ISY to 3.3.4 and it did not resolve either. Is there a way to factory reset the KPL?
  4. keypadLinc v.41
  5. levels for A-nodes on both keypadLincs set to 100% for the scene assigned to B-node; the A-node in off position when I click the B-node. Firmware for ISY: v3.2.6; not sure on the firmware for keypadLinc but happy to check if you can point me towards a "how to".
  6. I have a ISY program set to turn on all my (insteon) lights including the ones assigned to the main dimmer on each of my two 8 button keypads. I have assigned the "All On" scene to the "B-scene" slot on each of the keypads. When i turn on the scene using the html interface, all of lights function as programmed; when I turn them on using the keypad, all the lights except for the ones assigned to the same keypad i'm using turn on. This happens on both keypads. If I manually turn on the individual light using the keypad while the B-scene is on and then turn it off using the B-scene button, all lights turn off including the ones assigned on the keypad i'm using. Any ideas what I'm doing wrong? thanks in advance- dj
