mad_scot
Everything posted by mad_scot
  1. Interestingly I have exactly the same problem on all 45 of the ZEN77 4.1 f/w version units I have installed. I tried the rewrite all device links and still same problem - the ZEN77 does not report status event (button / paddle pushes). ZEN77 800 LR with f/w 4.1 I can control the units and query - just not status reporting. No issues with GE / Inovelli / Jasco in same install.
  2. Here's sequence. Log onto 99i. Click Admin console Log into admin console. Then get pop up with titel "security warning", "ISY is currently configured with the default SSL cart." Two buttons - Disable Internet access and Request/manage SSL certs. Click Request/Manage SSL cert New browser window opens Then get popup "Warning - security", "Java has discovered application components the could indicate a security concern. Name: com.universaldevices.isy.keygen.ui.S ... "Block potentiall unsafe components being run?" CLICK No ISY Config util opens - log in again CLICK SSL Cert. management CLICK generate / install new self signed cert Cert parameters dialog opens I enter my Dyndns address Then guess what it worked!
  3. bouncy castle library warning - no - never saw anything like that.
  4. from original post - take from help-about in admin console Model: ISY 99i 256 IR Platform: ISY-C-99 Version: 3.2.6
  5. Yes - both PC and ISY99 were on local network, albeit PC was connected wirelessly and ISY99 is directly hooked into router port - same subnet, router for wireless and ethernet networks.
  6. Having an issue generating a self signed cert on iSY99i Model: ISY 99i 256 IR Platform: ISY-C-99 Version: 3.2.6 I have no issue accessing externally via http or https but get the pop up warning about certificate. I can access the java app and request self signed cert but all I get is the Win 7 spinning circle. I cleared Java cach (using Java 7) - same issue. Tried on Chrome and IE8 with same result. It seems others have the issue too: viewtopic.php?f=27&t=7817 Anyone have any advice for me. I'm new to certs but am well versed otherwise. Thanks mad_Scot viewtopic.php?f=27&t=7817
