Camect nodes update but programs don’t trigger
Quick update: today the Camect nodes are triggering IoX programs again. Nothing was changed on the system since yesterday (still PG3x 3.4.13), so it may have been related to the node server reinstall or IoX needing time to rebuild program event subscriptions. I'll keep monitoring it, but for now everything appears to be working normally again. Thanks for taking a look.
System: - Work system: eisy / IoX 6.0.4 / PG3x 3.4.13 - Home system: PG3x 3.4.11 works correctly - Camect plugin version: 3.1.0 - Status in PG3x: Connected Problem: Camect alerts are visible in the Camect UI and the PG3x log shows successful updates to IoX, but ISY/IoX programs are not triggering on the work system. What I already tested: - Removed and reinstalled the Camect plugin - Confirmed alerts appear in Camect - Confirmed PG3x shows node updates such as GPV and ST changing - PG3x log shows “Successfully set ...” for Camect nodes - This same setup works at home on PG3x 3.4.11 Why I suspect PG3x: The main difference I can see is PG3x version: - Home: 3.4.11 works - Work: 3.4.13 does not trigger programs Question: Has anything changed in PG3x 3.4.13 that could affect Camect node event/status handling in IoX programs after reinstall? Also, should Camect programs be triggered using STATUS, CONTROL, GPV, or another driver on current versions? Examples from log: - Host:update_status: cams=True report=True - Successfully set 01_004 :: GPV to 1 - Successfully set 01_004 :: GPV to 0 - Successfully set 01_003 :: GPV to 1 - Successfully set 01_003 :: GPV to 0 Thanks.
Upload Node Server Profile
Ok now I have the developer interface with polyglot on eisy. Maybe you can answer this question: In Polyglot v3 Developer Mode, where should server.json go so OAuth config and node metadata are properly picked up? I’m building a NodeServer manually, and although everything works in google_calendar_ns, PG3 isn’t seeing the server.json, so the “Authenticate” button fails and client_id is undefined. Do I need to manually copy server.json into /var/polyglot/pg3/ns/<slot>? Or is there a better dev workflow to make sure it gets registered? Kind regards, Mike2545
Jim, thanks for the screenshot, it's my understanding that one needs to be part of the developers to get that button. Hope my application for membership gets approved. Kind Regards Mike2545 Edit, I have the button, it just doesn't do anything.
I am using Eisy, polyglot PG3x, where is the Upload Node Server Profile button to test out a new node server i am working on? Kind Regards, Mike2545
Camect USPS alert
Jim, I know you have been busy, but is there an estimate on when you would be able to work on this?
Camect USPS alert
Jim, thank you for taking the time to investigate this issue. I can't speak for all Camect users, but for me just an alert on USPS, it really does not matter if it's a car or truck, etc... Kind regards, Mike2545
Camect USPS alert
JImbo, I am running iox v5.9.1 Can confirm status changes in iox for person, car, truck etc... but not USPS
Camect USPS alert
Paul, yes I can log into Camect and click on alerts, filter by mail truck and see that it recognizes the mail truck with its software. Run then on the program sends me a text message, so that is configured correctly. In iox clicking on USPS in Camect triggers the program. I can change the program to trigger with person, truck, car. USPS is not triggering in iox.
Camect USPS alert
Paul, thank you for the reply. I have watched the mail truck pass the camera and it does not trigger USPS. I have attached an image of the program that should work if the trigger is passed to the eisy.
Camect USPS alert
Hello, I am trying to get an alert when the USPS truck arrives but the Camect plugin wont trigger. Any help would be greatly appreciated. Kind Regards, Mike2545
Set up help
RESISTANCE SENSE! (Updated Solution for BasPi 'Hats' Users) **Hello again, fellow Universal Devices enthusiasts!** I'm back with an update on the issue I reported earlier regarding getting the Universal Input to read resistors on my BasPi 'hat'. After a bit of troubleshooting and collaboration with the fantastic folks at Contemporary Controls, we were able to resolve the problem. **The Fix:** As it turns out, there was a software error in the original Raspberry Pi image that prevented the Universal Input from reading resistances correctly. Contemporary Controls kindly updated my image to the latest version, which resolved the issue. **Make sure you're running the most up-to-date software on your BasPi 'hat' found here https://www.dropbox.com/scl/fi/wsxz0o2sf9462unpefyvn/BASpi-1.0.35.0-Image.zip?rlkey=uvi7tj4mbtirmom7dv4qzy1ah&e=2&st=ejd2oe80&dl=0 **Additional Tip:** While we were at it, I'd like to emphasize the importance of using a robust power supply for your BasPi 'hat'. I've found that a 3A (or higher) power supply ensures stable and reliable operation. Trust me, you don't want any unexpected shutdowns or glitches! **RESISTANCE READING WORKS NOW!** If you were experiencing issues reading resistors on your Universal Input, please update to the latest software image and see if that resolves the problem for you. Thanks again to Contemporary Controls for their assistance in resolving this issue. I hope this post helps fellow users who might have encountered similar problems. Mike 2545
Set up help
Hello, I got one of the Baspi 'hats' and cannot get the universal input to read a resistor. I have the jumpers set to RES and the web interface channel type set to resistance and it wont register a resistor. Any help would be appreciated.
IFTTT stopped working
Log Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 460, in _disconnect self._mqttc.reconnect() File "/var/polyglot/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 1044, in reconnect sock = self._create_socket_connection() File "/var/polyglot/.local/lib/python3.9/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source) File "/usr/local/lib/python3.9/socket.py", line 844, in create_connection raise err File "/usr/local/lib/python3.9/socket.py", line 832, in create_connection sock.connect(sa) ConnectionRefusedError: [Errno 61] Connection refused Restart node and I get this: Node Server Restart: No valid license Did something change?
