Gee
  1. I have a Dimming KPL(2334) wired to a set of hall sconces. In a separate adjacent hallway, I have a ceiling fixture (not wired to the KPL) with an Insteon 2672 LED bulb. I have set up a scene were the main KPL key pad brings up the sconces to 12% and also brings the 2672 LED bulb in the adjacent hall to 12%. Everything works fine ! Am I "OK" with this ? I understand not to wire a dimmer to the 2672 LED bulb. What I'm fuzzy on is how the bulb, as a responding scene member, is being powered up/controlled when the key on the dimmer is pressed. Also, local dimming of both the bulb and the sconces works fine (and in tandem) when the main key is held in, which is precisely what I desire. I just want to be safe with this.
  2. Gee replied to Gee's topic in ISY994
    thanks
  3. Gee replied to Gee's topic in ISY994
    Let me try this again. Will the HUB "function" the same as a $39.95 Range Extender Item #: 2992-222 AND not screw-up the ISY if no devices are linked to the HUB ? Yes ? or No ?
  4. Gee replied to Gee's topic in ISY994
    So I can use da HUB - as a range extender even without any devices linked to da HUB, and it will function as a range extender in my system, and IT WILL NOT SCREW UP THE ISY and by FUNCTION, I mean that it will extend the range of all insteon devices hooked up in my home and linked to the ISY, but NOT LINKED TO da HUB ? YES ? or NO ?
  5. Gee replied to Gee's topic in ISY994
    plastic
  6. Gee replied to Gee's topic in ISY994
    Tedious, very tedious. OK, can I use the HUB (since it is all ready money spent) as a range extender ? Specifically, the open/close sensor is the furthest away from everything else. The ISY sees the HUB, the devices see the HUB, the open/close sensor sorta sees the HUB. If I clear the HUB of all devices and go solely with the ISY, can I still have the HUB plugged in at a central location (empty with no devices added to the HUB) and utilize it as a system wide range extender ? I'm assuming the interaction between devices via RF is "passive" (ie that the HUB will forward Insteon RF signals to the power line regardless of it's being program aware of that device) ?
  7. Gee replied to Gee's topic in ISY994
    If I must physically visit each module and do a factory reset on each (as has been suggested) does this imply that the Insteon HUB will then need to be re-linked or worse, does this imply that you must choose between either the HUB or the ISY but you can not utilize both ?
  8. Gee replied to Gee's topic in ISY994
    Used the HUB app on my phone to get the addresses of each device (while I was in front of my computer) and added everything - except the Open/Close and the Motion Sensors. Pretty clear now these will require a personal visit in order to link them. Still, doing the bulk of the linking from my computer was preferred, and I've managed to accomplish this. Since I just happened to begin the linking process (this time around) with the Open/Close sensor, it stymied my progress being unawares this particular device MUST be woken up. Live & learn. Would be nice if the ISY could just query/search and discover or even read the HUB data since I had managed to "link" the HUB a while ago (don't even remember when I did that).
  9. Gee replied to Gee's topic in ISY994
    "I tried posting..." I'm familiar with the interface. When "I tried" I got a message from the board regarding the inability to post imgs to this forum. I will do a reset and go from there (up to a point)
  10. Gee replied to Gee's topic in ISY994
    Firmware is 4.3.26 plus the "FAIL" message references the device specifically - it wouldn't know what it is if the firmware was older than the device, I'd imagine ? no trick, how about a sensible and convenient way ? is there a sensible-convenient way to accomplish adding 10 devices in every corner of the home ? I tried posting a screen capture but I can't do that here either The message sez: NEW DEVICE ERRORS then it shows the address I entered then the device model number then the device name ("Open/Close Sensor v.00 then "- Cannot determine Insteon Engine"
  11. Gee posted a topic in ISY994
    Do I actually have to add each insteon device by going to each one individually or is there a "trick" ? Also, Trying to add an Open/Close 2843-222 device. I am manually entering the Isnteon address and I get a "fail" message I have an insteon hub and a lot of devices already in service. I've had the UD isy994i for years but it's such a PITA I've gotten little use out of it
  12. Teken, I grasp the issue of extreme ambient temps adversely effecting electronic equipment, and do not fault Smarthome or Insteon for that reality. Right now, however, the temps in my attic are within a normal range. The comm problem is what I'm feed up with. If the 2473 unit worked as it should, dealing with ambient temps would be something I'd be willing to address. For example, I saw this INSTEON 2634-222 On/Off Outdoor Module (Dual-Band) . This 2634 "should" obviate the concern about ambient temps, no ? (AND IT'S "DUAL BAND" unlike the old version of the 2473 I was unwitting sold). I'd consider spending the extra bucks (over the Levitron) for this outdoor module IF my 2473 in normal temps even implied that I'd have a functional set up. But what I have is comm issues that are nothing but a black hole. Is it line noise from the fan itself ? Is it a phase coupling issue ? Is it some other device in my house that needs filtering ? Is it several devices (I have a bunch of UPS's for audio and computer equipment) ? The Levitron will be installed within the bathroom (I will bite the bullet and run some romex from the fixture power source in the attic), but the Levitron itself will be in the living space. I'll get both a timer functionality and a humidity sensor functionality AND IT WILL BE RELIABLE AND FUNCTIONAL out of the box (most likely). I don't mean to seem argumentative and I do appreciate all the input, but I'm pretty PO'd over all the insteon money I've already spent for nothing much more then the same sort of X10 aggravation I was trying to eliminate.
  13. Going with one of these: Leviton IPHS5-1LW Humidity Sensor and Fan Control If I have to go up into the attic again, if I have to spend $$$$ on devices to make the device I bought work like it should, if I have to wait for a newer version Insteon device that will be out any day now (after I've unknowingly bought the old one), then I think I'll just run some romex and get it done. Thanks again
  14. KPL= 2486d v.41 is that "dual band" ? 2413S = YES "S" What's the least expensive way to phase couple this mess - er, ah "SmartHome" ? A 2406h ?
  15. Well, I think I've had it for today. Another day, I will try and crawl up into the attic, through all the carefully redistributed loose fill that was displaced when I installed this "OUTLETLINC" marvel last week and disconnect the fan to test out the FAN theory. At this time, I have only the OUTLETLINC, the 6way switch, the houselinc modem that came with my 994i, and a ControlLinc 4071. Can I still do this "4tab test" ? The thing I don't understand is if I have the OL and the Modem on the same circuit what does the phase coupling have to do with it - if I have a phase couple issue in the house I can address that separately and later on. Right now, I just want to press a button an have my exhaust fan come on for 30 mins I just want the #@$% outlet to %$^# work - jeesh !
