DIggerNSE
  1. Thank you very much Michel and robr!! I thought with a mac I wasnt going to have to worry about anything! Thanks again guys!
  2. Thank you Michel .. If i upgrade to 10.7 some of my older docs will not be able to open. I tried the second option and it didnt work.
  3. I have been running my system now for about 6 weeks.. basically with few problems.. however this morning I cannot log into admin consol. I get a pop up "Unable to launch the application." When i click on details of window, another window say: Error: The application has requested a version of the JRE (version 1.6+) that is not installed. I am on a imac os 10.6.8 with all the software up to date according to "software updates" ISY994i/IR Pro Any suggestions ....Thank you
  4. I believe that the modules are small enough to be installed within the metal body of each fixture.. Would the modules work inside the fixture (the part that houses the ballast etc)
  5. I currently have 4 Under cabinet fluorescent fixtures each 4 foot in length, controlled by one single pole switch. My goal is to be able if possible to control each fixture independently. Would this be possible with the new micro modules and a 6 button keypadlinc? Thanks
  6. apostolakisl and Lee.... your both giving conflicting info... Per apostolakisl instructions and my testing.....In the entry box... the red is the HOT and the black in the garage is the LOAD . Now Lee you have different approach??
  7. The Red, Black, White wires in the entry box are all connected to a standard 3-way switch? YES Are these three wires in the same cable? YES I dont know where the 3 wire cable from the entry runs; either to the fixtures or garage gang box ????? I can measure voltage on various wires In answer to oberkc: The garage is 3 gang box with 3 swithces : the 3 way that is the issue, another single pole controling a ceiling light in garage bay 1 and another single pole switch controling ceiling lighting in bay 2 and 3. Garage box has 5 cables coming in: Cable 1 is 2 wire blk/white (blk goes to dark colored screw on 3 way switch) (white to Neutrals) Cable 2 is 3 wire blk/white/red (blk and white to 3 way switch) (red to wirenut with all blacks) Cable 3 is 2 wire blk/white (blk to single pole switch) white to neutrals Cable 4 is 3 wire blk/white/red (blk to other wire nutted blks as well as red from cable 2 Cable 5 is 2 wire blk/white (blk to wire nutted blk) white to neutrals I hope I have all the details !! thank you!
  8. I am a new user to home automation, have completed isy setup as well as multiple single pole switclincs, outletlincs. Now attempting to install my first 3 way switch which controls outside entry lighting from 2 locations. (Front entry and garage.) Front entry switch wiring looks normal; red, white and black wires. Garage configuration has two black wires and one white. I should mention both locations are 3 gang boxes containing 2 other single pole switches that control interior foyer lights and garage lights. Please advise. I have answered most of my questions by reading this forum! It has been a great help!!
