JeremyLaurenson
Everything posted by JeremyLaurenson
  1. The device is a dual mode insteon high-load dimmer 2477DH- theres also a lamp being controller. I see that its sending off and then on again. Mon 01/14/2013 10:59:31 AM : [ELK 0 40 0] Zone : Ofc Call Sensor : Normal (51/0/0) Mon 01/14/2013 10:59:31 AM : [iNST-TX-I1 ] 02 62 1F 02 73 0F 11 FC Mon 01/14/2013 10:59:31 AM : [VAR 2 1 ] 1 Mon 01/14/2013 10:59:31 AM : [iNST-ACK ] 02 62 1F.02.73 0F 11 FC 06 LTONRR (FC) Mon 01/14/2013 10:59:31 AM : [ELK 0 40 0] Zone : Ofc Call Sensor : EOL (52/2/0) Mon 01/14/2013 10:59:31 AM : [iNST-SRX ] 02 50 1F.02.73 1F.22.3C 2B 11 FC LTONRR (FC) Mon 01/14/2013 10:59:31 AM : [standard-Direct Ack][1F.02.73-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/14/2013 10:59:31 AM : [ 1F 2 73 1] ST 252 Mon 01/14/2013 10:59:36 AM : [ELK 0 40 0] Zone : Ofc Call Sensor : Violated (51/2/0) Mon 01/14/2013 10:59:36 AM : [VAR 2 1 ] 0 Mon 01/14/2013 10:59:36 AM : [iNST-TX-I1 ] 02 62 1F 02 73 0F 13 00 Mon 01/14/2013 10:59:36 AM : [iNST-TX-I1 ] 02 62 0A B9 2B 0F 13 00 Mon 01/14/2013 10:59:36 AM : [iNST-ACK ] 02 62 1F.02.73 0F 13 00 06 LTOFFRR(00) Mon 01/14/2013 10:59:37 AM : [iNST-SRX ] 02 50 1F.02.73 1F.22.3C 2B 13 00 LTOFFRR(00) Mon 01/14/2013 10:59:37 AM : [standard-Direct Ack][1F.02.73-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/14/2013 10:59:37 AM : [iNST-ACK ] 02 62 0A.B9.2B 0F 13 00 06 LTOFFRR(00) Mon 01/14/2013 10:59:37 AM : [iNST-SRX ] 02 50 0A.B9.2B 1F.22.3C 2B 13 FE LTOFFRR(FE) Mon 01/14/2013 10:59:37 AM : [standard-Direct Ack][0A.B9.2B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/14/2013 10:59:38 AM : [iNST-TX-I1 ] 02 62 1F 02 73 0F 11 CC Mon 01/14/2013 10:59:38 AM : [iNST-TX-I1 ] 02 62 0A B9 2B 0F 11 FC Mon 01/14/2013 10:59:38 AM : [ELK 0 40 0] Zone : Ofc Call Sensor : Open (52/1/0) Mon 01/14/2013 10:59:38 AM : [ 1F 2 73 1] ST 0 Mon 01/14/2013 10:59:38 AM : [iNST-ACK ] 02 62 1F.02.73 0F 11 CC 06 LTONRR (CC) Mon 01/14/2013 10:59:38 AM : [ A B9 2B 1] ST 0 Mon 01/14/2013 10:59:38 AM : [iNST-SRX ] 02 50 1F.02.73 1F.22.3C 2B 11 CC LTONRR (CC) Mon 01/14/2013 10:59:38 AM : [standard-Direct Ack][1F.02.73-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/14/2013 10:59:38 AM : [ 1F 2 73 1] ST 204 Mon 01/14/2013 10:59:38 AM : [iNST-ACK ] 02 62 0A.B9.2B 0F 11 FC 06 LTONRR (FC) Mon 01/14/2013 10:59:39 AM : [iNST-SRX ] 02 50 0A.B9.2B 1F.22.3C 2B 11 FE LTONRR (FE) Mon 01/14/2013 10:59:39 AM : [standard-Direct Ack][0A.B9.2B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2 Mon 01/14/2013 10:59:39 AM : [ A B9 2B 1] ST 255
  2. I have an ELK zone I am monitoring. When the sensor is tripped, the lights brighten to 99% (No 100% available!?) When I am off the call (video call, by the way) they are supposed to dim to 75%. They actually turn off and then go to 75% If Elk Zone "Office Call Sensor" is Normal Then $incall=1 Set 'Jeremy Office Overhead Lifghts' 99% else $incall=0 Run Program 'Office Lights On Normal' (Then Path) Office Lights On Normal: if - No conditions then Set 'Jeremy Office Overhead Lights' 70% Else - No Actions
  3. There is a new Java update just released. Give it a whirl - it fixes this issue and makes you more secure.
