JeffWLeach
Everything posted by JeffWLeach
  1. This takes some effort. From reading another thread on this forum you need to use the nearest airport. I live in Arlington Heights, IL the find point to Mount Prospect. The weather data is not correct for example humidity was 0% when it is 65%. I need to select the nearest airport where the weather comes from and that is palwaukee airport. Once I did that it works. What about this "Climate Module to point to HAM Weather Stations instead of WeatherBug". This was requested on the firmware page. I don't see any place to do that.
  2. The firmware and UI match v.4.2.5 and I cleared the Java Cache. The climate tab has Weather provider a check box for enabled is not checked Location ID is blank Unit is English (F) Polling Interval (sec) is 300 What do I do? Firmware documentation says "you will need to reconfigure your Climate Module to point to HAM Weather Stations instead of WeatherBug" how do I do that? Is there documentation?
  3. I don't think ID matters for State Variables it looks like you use the name. Here is a good reason to put this in the Firmware. When I imported your programs the Day of the Month in the Then and Else clause replaced $iDay.of.Month with Jeff's_4S_IPhone_Arlington_Heights because that was in ID 2 from MobiLinc being installed first. Also would this being in the Firmware eliminate the problem with the unit being off at midnight and having to run Advance one? How much work would this be to do in the firmware since you have already written this code?
  4. Is the ID important for State Variables? I have 3 State Variables that must have been add for MobiLinc. State ID 1-3 are for my mobile devices like the IPhone, IPad and ITouch that use MobiLinc.
  5. I tried that and it is still the same. The Climate tab still says WeatherBug.
  6. Will this be supported in the Firmware it would be much cleaner and simple to do.
  7. I want to test the date before going into a program folder but I don't want the year. The example is Halloween happens every year and I don't want to keep updating the year in the If test every year. I just want Month and Day without the year.
  8. How do I configure the location? If I go to Climate tab in the configuration tab in the Universal Devices Console. The Information still says WeatherBug. The location ID does not work. In Location ID I put in my zip code of 60004 and a screen popup asking me to make a selection but the choices are blank. I am on the latest beta release insteon_4.2.4.
  9. I have ISY 994I and I am on firmware 3.3.6 beta. Mobil Linc was working and has stopped working on my IPhone a few day ago. I use DHCP with a fixed address. I created a firewall rule for port 443 but I did not know of that was UDP or TCP, what should I use? I made that WAN to LAN and I target the fixed IP address of the ISY 994I. If I reboot it is fixed for a time and then stop working. Does the error 170001 mean web module out of space. What does that mean? I get this in the error log Mon 2012/12/24 08:47:59 PM System -5012 27 Mon 2012/12/24 08:48:19 PM System -10011 n/a Mon 2012/12/24 08:48:19 PM System -10011 n/a Mon 2012/12/24 08:58:26 PM System -170001 [Auth] 27.27.1.57:52121->80, Num=3
