seallred
  1. Thanks for the feedback. They are access points (Access Point 2443), but they are probably as old as my PLM because I bought them all around the same time. Sounds like I either need to upgrade my PLM or send back the sensor. Appreciate the help, looks like I have a decision to make.
  2. Still no luck. I placed the sensor right next to a dual band switch, no luck. So I sat it right next to my PLM and tried again and still no luck. One thing to mention is I have an older PLM that is NOT dual band. Just in case that could be it. Anything else I should try before I just send it back to Smarthome. Thanks,
  3. I got a new Smarthome Leak Sensor 2852-222 but am having trouble linking it to my ISY. I have tried these two things: Option 1: From ISY Link Management - Start Linking Put Leak Sensor in the linking mode by holding button for 5 seconds until it starts blinking No luck. Option 2: From ISY, New Insteon Device Enter the Address, Name Enter Device Type to Leak Sensor Fails to link. Any suggestions. Do I have a defective unit? Thanks.
  4. I am moving from totally different software. I had been using Promixis Girder software and decided to change to ISY-994i/PRO. I have it up and running but before I start over was just wondering if there is a way to migrate all the links in the PLM database to ISY. If that's going to be a headache and the recommendation is to start all over then so be it, but before I go that route I thought I would ask. I have about 32 Insteon devices (most all of them are switches). I can now get to the wiki. Thanks for the quick reply. -Scott
  5. I just got my ISY-994i/IR Pro. I was working on get it setup but am running into several issues. Hopefully someone can help. 1. When I try to navigate to the wiki I get a 404 error. http://www.universal-devices.com/mwiki/ ... User_Guide 2. I have an existing PLM. I am looking for instructions on how to sync it with my ISY device so I don't have to start from scratch. Is this possible? or do I need to reset my PLM and start from scratch. Thanks, Scott
