DualBandAid
  1. It's kinda amazing all this network stuff is still being sorted out, requiring this kind of detailed fine-tuning. Then again, it's kinda amazing any of this works at all. (Though maybe the problem is, this whole Hue node thing is kinda a kludge - and should just shut up and be grateful it even exists in the first place)
  2. I took your advice and also followed this link: https://github.com/exking/udi-hue-pg3/blob/master/README.md And added this to the mix which basically reiterated what you said: It wasn't particularly specific but I put << IP >> in the key paramenter and then I put my IP address, in brackets like you said. It transformed to this, I guess (I just looked at it) and all is well now. Question though on the new hub which is working fine. Should I just do an IP reservation? Or should I do an IP reservation and specifically tell the Hue node what that IP is? Also, is there a difference here between a DHCP reservation and an IP reservation? Thanks for all the help!
  3. I will dig in and check everything when I'm home. I didn't realize I could connect all my bulbs DIRECTLY to the EISY - without using a hub - if that's what you mean. Is that what you mean? I'm not sure all my old bulbs could do that - nor do I know how. But one thing I want to add. I added a second hub, and that works find. I hit the button on the hub and restarted the node, and the outside lights were all recognized. Also, fwiw, I had no DHCP reservations nor did I tweak anything on my router/switch/modem at all. It's all off the shelf.
  4. I have an EISY. I was able to get my Hue bulbs into the system. All was well. Then things got a little weird with one Hue device. I tried to delete the offending Hue device but couldn't. THEN!!!!... I had a grand idea that if I UNGROUPED the Hue bulbs, I could delete the errant Hue device. That worked. But then I couldn't group the devices again. So like an idiot, I tried to delete everything from the system. I deleted the Hue from the EISY; I went into Polyglot and deleted Hue there. Then I tried to reinstall. So that worked. But it appears that the only thing showing in the EISY is the Hub. There is an option to Rediscover Bulbs in the EISY. That does nothing. Also, jumping back, when I install the Hue back into Polyglot, it told me to hit the hue hub buttong and restart within 30 seconds. I did that. Nothing worked. I have tried many combinations of deleting and reinstalling and vomitting in my mouth in despair. Any thoughts?
  5. So a few things. Opening the scene and changing the on level for the scene, like so to 39%... All that changed is what happened if I turned the scene itself on. But if I hit the pseudo "3-way" switch, the LEDs still shot to 100%. (NOTE: I changed both devices to 39% - and it didn't matter). The only way I could get LEDs level to change by hitting the switch is if I clicked on the actual device in the scene and changed it. Like so... I guess highlighting the scene itself, versus a device in the scene, gives one differnet behaviors. I actually know this (sorta kinda). But keep forgetting. So my problem is sorta half-solved. One, I would like program this change. And two, I would any idea how I can use variables in this situation? I have a program that uses variables to change all my switches on-levels throughout the day. I was hoping I could do that here. That's really what I'm after.
  6. That definitely helped with the second problem! Thx!
  7. There is another weird thing going on. Almost the opposite of the above. Back to the switch in the virtual 3-way that is wired directly to the light: Let's say it has an ON-LEVEL of 50%. When I toggle that switch on, yes, the light goes to 50% and the ISY STATUS says 50%. But when I double-tap the light to send it to 100%, yes, the light goes to 100% but the ISY STATUS still says it's at 50%. Thoughts?
  8. So this is weird. I have a switch in a 3-way with another switch. (Both KeyPadLincDimmer 5 buttons - but the problem occurs with two regular dimmers in another 3-way, as well) HERE IS THE SET-UP: At night, the ISY sets the Local On Level of the switch to 25%. Like so: Then I turn the physical switch on and the ISY says, "Yep, the light is only 25%" - as you can see here: HERE IS THE PROBLEM: The problem is, the light actually goes to 100%. This only occurs with the one switch the isn't wired directly to the light. The switch that is wired directly to the light doesn't have this problem (it has a different one - see next post). Thoughts?
  9. Ah. I see I maybe have misunderstood what you meant by: I thought you meant that if, say a light is on, you slowly would dim the light down to the lowered setting. I had a set-up like that. If, say, my living room lights were on, they would slowly dim over the course of 9 minutes to the evening light. I wouldn't even notice the dimming. In the case I was talking about (and thought you were talking about) whether the lights were on was important. Think of it this way. Light is on 100%. Program starts... 1) Ramp rate is changed to 9 minutes 2) Light is slowly dimmed down to 50% If my light is NOT on, I don't want this program to run at all. If it runs, the light will turn on and start dimming, right? The reason I used a scene for this was, if I changed the switch's ramp rate for this event, anyone trying to use the switch to override the current light change would have a ramp rate of 9 minutes. But lemme ask you something else. Let's say I don't worry about the ramp rate. Light is on 100%. Program starts... 1) Light is dimmed to 50% at 7:00 pm But I don't want that change to happen if the light is off, do I? Summarizing: I am already set on how to change the local on levels. Light is on or off, doesn't matter. It just changes what happens at the switch. But what if I want a light that is ON ALREADY to dim to a lower level, but if the light is NOT on, I don't want anything to happen. What then?
  10. I am trying to set a Hue brightness level so that, when a Hue light is turned on, it does to that particular brightness. I have four such programs throughout the day. However, when the Hue brightness level is changed, it turns the Hue light on. Thoughts?
  11. How do you do this? With a scene? A scene with a slow ramp rate that dims to a certain level? And do you need an if statement to verify the light is on the first place? And then you need one for every light?
  12. I had something like that set up at my old place but I had programmed it, like 9 years ago...and I wonder if A) I was doing it clunky to begin with and B ) if there is a more elegant way now. It sure is a lot easier to change the LOCAL ON level at the switch than it was a decade ago. The way I'm thinking, I need to determine if a light is on? And then, if so, change the ramp rate to the max (9 min?) and then ramp down from it's current level down to a lower level? Is that the right way to think of it? Or do I have make scenes for every light? And then adjust the scene?
  13. I may be doing the same thing differently, or I'm missing some opportunity with what you are doing. My "If" section has a time frame on it:
  14. I def have been using ISY to control the level of dim at all my switches. I just find that it's a *constant* change. SUN-UP: 100% SUN-DOWN: 70% LATE EVENING (SUN DOWN +3 hours): 40% LATE NIGHT (after 11): 20% I have an ISY program that changes the on switches for all these. But this confused me: If I want to change my lights outside of my program, I just tell Alexa to change the lights directly "Alexa, set [group] to 45%". But my program is still running. But it sounds like you are telling Alexa to change the program itself that controls the lights? Are you finding the % that you set up in the program needs to be tweak that often?
  15. What’s the use case here with Alexa? By that, I mean, if I want my lights to be at 45%, I just tell Alexa to set the lights at 45% without any need for a program. Or are you saying that you use Alexa to change the value of a local press of the switch? What do you use that for? I generally just have my local value change as the time of day changes, on a consistent basis. With no need to use Alexa to change the local value of the on button. If I’m going to use Alexa with my mouth, to change the on value, I would just use my mouth Alexa combo to turn the light on to a desired value. The only time I could see this being valuable is if I am, for whatever reason, having to constantly change the value of the local switch on an unpredictable basis.
