jrini
  1. jrini replied to jrini's topic in ISY994
    Yes, I have one scene for each Fan Light and four scenes for each fan motor. Because I do not work with the scenes very often, I saved the set of scenes that were working for the master bedroom fan before the catastrophe. After I finished rebuilding all of the scenes, I found one button, the C button for one fan that turned that fan off. All four of the A, B, C, & D buttons turned all of the LED back lights on and the A, B, & D buttons put the fan motor in what appears to be medium speed. On other key pads, the A, B, & D buttons all seem to put the fan motors in high speed and all result in what I have to call random lighting of the LED back lights. John Rini
  2. jrini replied to jrini's topic in ISY994
    My main concern is the five (5) FanLincs and six (6) 6 Button Key Pads for which none of the scenes involving the fan motors are working while all of the scenes for the fan lights are working. At the present time, I am only turning fans off and on with the attached pull chains. I provided the information about the eight button RemoteLinc2 in the hope that it could help someone more familiar with the technology get an idea about the problem. John Rini
  3. jrini replied to jrini's topic in ISY994
    Two weeks ago I installed a new PLM. I used the “Restore modem” command to re-initialize the PLM. Nothing I saw made any sense. Everything either had a green 1011 icon or a red exclamation mark on it. So I then used the “Restore devices” command. This eliminated all of the green icons and most of the exclamations. However all of the 6 button key pads and the RemoteLinc 2 8 button keypad did not work properly. I have since replaced every scene in my Admin console. As a result of deleting all of the scenes, shutting down the Admin console, then re-opening the Admin console and re-programming all of the scenes for the 6 button key pads, the lights associated with the FanLincs are now working properly. None of the four ABCD buttons are working properly. I have spent the last week trying to identify a pattern of failures for the buttons controlling the fan speeds but even the LED lights behind those buttons behave differently on each of the 6 button keypads. The RemoteLinc2 8 button key pad is only used via ISY programs and none of those buttons are recognized by the ISY programs. Only my Insteon thermostat that uses a combination of ISY programs and scenes is working exactly as it did before I replaced the PLM. The three RemoteLinc 2 Paddle switches are working properly. One of them is working in a Scene with the Kitchen Fan Light. However all three of these RemoteLinc 2 Paddle infrequently follow up their action with 10 flashes of the red led. I hope my conclusion is wrong but I am thinking that either my ISY or the new PLM is defective. Any advice will be appreciated. John Rini
  4. jrini replied to jrini's topic in ISY994
    I have not been responding to this issue because I was getting a lot of irreconcilable results. e.g. If I deleted a device from a scene, it disappeared from the admin console, if I then attempted to return that device to the scene, I would get a message that the device was already in the scene. The weirdest results was when I added a Mini Remote Switch to a scene and it appeared in the admin console represented by a light bulb icon. It was listed as a responder but acted as a controller. I did a screen scrape of the Mini Remote Switch represented by a light bulb icon. I attempted to attach that image but did not succeed. After some more testing it became obvious that all, save one, of the scenes implemented by the ISY 994IR pro were working but none of the programs involving ISY operations were working. I therefore assume that my PLM is inoperative. This is not the first project that I have worked on where we had to specify the brand names of all of the passive and active components. I have opened the PLM and do not see any deformation of capacitors. Without seeing any indication of failures, I have to ask, How are the newest generation of PLM's holding up? John Rini
  5. jrini replied to jrini's topic in ISY994
    First to answer Stu's comment. I did perform an automatic update to my ISY Firmware today. The results after the update were the same. I attempted to find an update for the user interface. I obviously did not find such an update. If someone can tell me where to find a user interface update I will be appreciative. Second to address Teken's and Techsman's comments. Normally the ISY Admin Console puts a small window up for each device that is being added to a scene. That window NORMALLY WAITS for a user to confirm that the device is being added as a Responder or as a controller. Each time I attempt to add a RemoteLinc 2 to a scene, that window DOES NOT ALLOW THE STATUS of the battery powered RemoteLinc 2 to be changed from Responder. Techman's statement "The Remotelinc can only be added to a scene as a controller, it is never a responder" is describing the necessary condition for the RemoteLinc 2 to be useful. My Admin console is always adding RemoteLinc 2s to scenes as responders. To repeat: My problem is that I cannot change the status of a RemoteLinc 2 in any scene to "controller". John Rini
  6. jrini posted a topic in ISY994
    I recently bought three Mini Remotes, Model 2342-2. I planned to use them in what the electricians call a three-way switch configuration. I then perform the following steps: 1) I do a factory reset. 2) I use the "Link Management" drop down menu on the admin console 3) "Link a RemoteLinc 2. 4) Switch. At this point I assign the address and name. The proper model number appears to be assigned. However the ISY then shows the device as an "Unsupported Device 0.28". I can move the Switch to the correct folder and add it to the scene I want it in. The problem -- the Switch is always added to the scene as a "Responder". There is no opportunity to change the status. This makes the Switch useless. I have tried this with all three switches. I have also tried the procedure on the "Quick Start Guide" to verify that the Switches are functioning properly. FWIW My ISY Firmware is v.4.4.6 My ISY UI is v.4.2.2 John Rini
  7. jrini replied to jrini's topic in ISY994
    I followed the directions from Paul. Seconds later everything was restored. Thanx John Rini
  8. jrini posted a topic in ISY994
    I recently had multiple power interruptions while an electrician was working on a problem in my house. When the work was finished, I tried to restart my ISY 994/IR Pro admin console. I got a message saying the ISY was in safe mode. I tried executing the “Restore Modem(PLM)”. The result has been red exclamation marks on all of my insteon devices. 1) All of the previous scenes appear to be working. 2) None of the ISY programs appear to be working. 3) I have been able to mechanically link devices. 4) I have tried to restore the ISY from the most recently archived firmware load with no effect. What can /should I do next? John Rini
  9. This evening I printed the various suggestions and started to work through them. The first thing I did was read the page "Why are Java...with the latest Java?". I then tried to restart the admin console, IT WORKED PERFECTLY. I am of the opinion that our dear benefactor had screwed something up in the previous update and corrected it with last nights update. Not long ago they had left my machines boot code set to boot from the LAN and that was corrected last night. The best they have done was post the Microsoft 800 number in Bing with a single digit changed so that I actually contacted a Phishing site. John Rini
  10. 1) The ISY is running correctly. 2) The 64 bit computer running Windows 7 had no problem connecting to the ISY. This verified the router connection. 3) I use the URL on the UDI web site to reload the Admin Console. 4) There has been no change in the 64 bit Surface Pro 3 protection software for over a year. 5) The ISY finder opens a window on the Surface Pro 3's screen. That window contains only column headings. 6) New development that I had failed to include in the original post. The following data is displayed in a separate window on the Surface Pro 3. "Java Web Start 11.73.2.02 Using JRE version 1.8.0_73-b02 Java HotSpot Client VM User home directory = C:\Users\John ---------------------------------------------------- c: clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- Missing Application-Name manifest attribute for: http://isy.universal-devices.com/994i/4.3.26/insteon.jar"
  11. I have two computers on my LAN. One computer is an old Notebook computer running Windows 7 64 bit the other is the Surface Pro 3 running Windows 10 64 bit. Last week some event occurred such that neither machine could access the admin console. All attempts to restore access to the ISY from the Surface Pro 3 fail. The Notebook computer connected to the ISY as soon as I reloaded Jave and made sure that the cache was empty. What can I do to get the Windows 10 machine talking to the ISY again?
  12. Following up on Paul Bates questions: I did not see the mini remote changing states, so I rewrote updates to it. The mini remote does now change states in the Admin Console. It also does now turn off the X-10 A7 switch. I do not see the X-10 switch in the “Main” page of the Admin Console and am not sure of how to change the state of the switch except via ISY programs. Do I need to buy the X-10 module to do that?
  13. I have the following programs on my ISY. If Control 'Basement / FrontRoom / BasementStairs - A' is switched Off Then Wait 3 seconds Send X10 'A7/Off (11)' Else - No Actions - (To add one, press 'Action') If Control 'Basement / FrontRoom / BasementStairs - A' is switched On Then Wait 3 seconds Send X10 'A7/On (3)' Else - No Actions - (To add one, press 'Action') If the X10 switch is on, executing the Then phrase of the first program does set the switch off. If the X10 switch is off, executing the Then phrase of the second program has no effect. Using the Insteon Mini Remote paddle switch named “BasementStairs-A” has no effect. Any suggestions would be greatly appreciated. John Rini
  14. Thanks for the help! Everything is now working! John Rini
  15. I have learned that: “The PLM was inadvertently unplugged and plugged back in last week.” While the electrician, and other workmen were here. Could that explain the sixteen “Cannot communicate with ….” Messages that I was receiving from last Thursday thru Saturday? I found the PLM unplugged this morning. There was a pile of boxes in front of it. Unfortunately, I immediately plugged it back in. I am still getting the: “Your system is in safe mode….” Messages. What must I do now to recover?
