romeo_echo
Everything posted by romeo_echo
  1. That is true. With all eight bulbs I bought in place, dimming does indeed seem to be smooth. I think they tried really hard to match the dimming curve of an incandescent! I don't see any adverse effects on my insteon network but I'm not pro enough to know what to look for -- everything still kind of just works, so that seems OK :) I just bought 16 more, let's hope they are all the same thing! Thanks,
  2. WOW!!! I just got in my (first) 8-pack of these: https://www.amazon.com/dp/B08667GGJW?psc=1&smid=ATVPDKIKX0DER TOTALLY different dimming curve than the "same" Philips Warm LED dimmable bulbs I bought two years ago... now my sunrise does look exactly like the pics lilyoyo1 uploaded! They also seem WAY "warmer" than my old "warm" LEDs at the lower light levels. Oddly, there doesn't seem to be any kind of model number or version/revision number on the box, or on the bulbs themselves, so there's no way to be sure my next purchase will be the same bulb with the same technology (except to check the SKU/UPC code). I am STOKED. I just redesigned my sunrise program, I can't wait to see it in the A.M. THANKS ALL
  3. Thanks lilyoyo1. Those pictures don't look at all like my dimming curve. And FYI, this problem is not the same as some people are describing where the lights won't come on at all until dimmer hits high numbers like 40%. Mine come on when my ISY/LampLinc is at 1% -- they jump up to a level that looks awfully dim in the daytime, but in the pitch dark of a "sunrise" scenario, it's quite a jump... especially when I have eight lightbulbs in my master bedroom (hey I like it bright when I need it ) Anyway, I just bought the lastest Philips warm LEDs (https://www.amazon.com/dp/B08667GGJW?psc=1&ref=ppx_yo2_dt_b_product_details), when they come in I will report back as to whether the dimming curve has improved over my two-year-old bulbs (which should be the "same", they are also Philips warm LEDs). I also worked around the problem a bit by having a couple of smaller incandescent accent lights that do their sunrise thing about 15 minutes before the LEDs flare up to their so-called "1%" .... kind of takes the edge off. But a nicer LED dimming curve couldn't hurt too ... Thanks all for the input!
  4. Hi all, I didn't know where else to put this question, so I'm just throwing it out there... My question is about dimmable bulbs. Which (LED, white, warm, dimmable) bulb has the best "dimming curve"? I bought a bunch of these, which have a nice warm glow when turned down: https://www.amazon.com/gp/product/B07CFRCGKC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 The problem is, when I change the brightness control on them from 0% (off) to, say, 1% or 2%, they just kind of snap on at dim but still fairly bright value. It is quite a jump, especially if you're trying to do a "sunrise" type thing. Very unlike an incandescent bulb, which at 1 or 2% is more like an extinguished matchhead that is still glowing, if even that. Are there ANY LED bulbs that have truly incandescent-like dimming curve? Or is there a bulb known to have the best dimming curve, even if it's not quite incandescent-like? One requirement would be that the bulb also achieve "normal" brightness, 60-watt equivalent or better... just switching to a very low watt LED bulb wouldn't be a good solution, as these also have to function as my normal room lights. Thanks in advance for any thoughts on this topic. Just FYI, my system is an ISY 994i that controls a lot of Insteon LampLincs and OutletLincs.. the dimming curve is of course awesome when using incandescents. --Ralph
  5. SwitchLinc! That's what they're called. Thanks for the reminder. As I tried to say above (but couldn't remember the name), I got rid of my SwitchLincs because I don't have Neutral wiring and thus lost ability to control the lamp/light the switch used to control. I think I've got about six used SwitchLincs I could sell to someone at a reasonable price via ebay or just via paypal, if anyone's interested, I wouldn't use them again unless I got my whole house rewired. Cheers, Ralph
  6. So true! I was able to simplify my system greatly once I went "full alexa", and got rid of all my wall switches and RemoteLincs completely, but man when the cloud is down, it is TOUGH out there without a Plan B!!! Thanks again all!
  7. Thanks all! Good to know the 2342-222 is still viable, just wish they were cheaper and/or more popular?! Might go order one now... Cheers, --Ralph
  8. Hi all, Short version of the question: What is the latest good alternative for a battery-operated or rechargeable controller, like the RemoteLinc 2? Those don't seem to be much of a thing any more... Back Story: After the recent portal outage, I've been looking at more ways to implement local control for my 994i. So I broke out my old RemoteLinc 2 (model 2444A2) which I hadn't been using, but unfortunately the rechargeable battery had swollen so much that it's not usable. So I went to look for a new one. After proceeding cautiously because my browser said SmartHome.com was not a safe website (!?!?), I find that the new model is 2342-222, however SmartHome.com is almost the only place that has it in stock, so, it's far from popular...plus they are hella pricey... Should I buy one of these? Are these even still the same thing as a RemoteLinc 2? (Places that sell it never mention "remotelinc"... i.e. Would I still add them via the "Link a RemoteLinc 2" option)? Is there a better alternative that is programmable in the same way through the ISY 994 Administrative Console? I have some wired in-wall controllers, but I generally don't like to use them because my wiring is ancient (no neutral) so I can only use them if I'm willing to lose local control of the lighting fixture in question...Thus a battery or rechargeable option would be preferred. Any suggestions welcome, thanks much! Ralph
  9. romeo_echo replied to JGraham's topic in UD Portal
    Thanks MrBill, good info. Quick question though: I've never contacted Universal Devices for support directly before... As a casual owner of a single ISY994i, am I allowed to open tickets by sending an email to that support@universal-devices.com also? Or do I need to be some kind of subscriber or developer or something to open a ticket? Cheers, Ralph
  10. romeo_echo replied to JGraham's topic in UD Portal
    online for me now since 11:07am Mountain time Sunday. Thanks for fixing!
  11. romeo_echo replied to JGraham's topic in UD Portal
    My portal is showing offline too! Since 11:19 pm Mountain time, Saturday night. Everything else is working fine. Posting this so I can follow and get updates. Is there also a better forum to post problems like this? I thought I saw the description say this forum is only for developers...? On the new UD Mobile app, does anyone know if there's a way to flip-flop between portal connectivity and local network connectivity? It only seems to offer portal connectivity, right? Thanks, Ralph
  12. thanks all for the feedback. yep I've lived with 8 minutes forever, I can go on living with it Would love to see even longer options but I guess that's not going to happen either
  13. Hi there, I have question that has always bugged me but I've always just lived with it. Thought I might throw it out there and see if there's an actual fix. I have an ISY 994i (firmware 5.3.4, dated 2021-07-07) and lots of Insteon OutletLincs and LampLincs. Everything has always worked great, except... When I set a device in a scene to have a ramp rate of 8.0 minutes, everything works fine. However when I set the ramp rate to the max of 9.0 minutes, it ramps very fast, it looks the same as a ramp rate of 2.0 seconds. Any thoughts? Is there a secret setting to get max ramp rate of 9.0 minutes to actually work? Does everyone have this problem with LampLincs and OutletLincs? Thanks, Ralph
  14. never mind, it's all green now. Weird... think it was a glitch on ISY end or my end?
  15. Help! My ISY portal is showing that my ISY is offline. Don't know what went wrong, it's been working forever. See pic, attached. Everything else is working fine. All the lights in my house are totally controllable via the admin.jnlp interface, and locally via keypadlincs. But Alexa can't control the lights. For laughs, I removed the Alexa skill "ISY optimized for Smart Home V2" and followed instructions to upgrade to the V3 skill. After installation I was even able to pull down a new fresh list of all my devices and scenes, but now the skill says "Sorry the hub that device XXX connected to is not responding" when trying to control any device. Tried resetting my 994i of course, but since it's working in every other way, that did not help. Is the portal just temporarily down? Thanks, Ralph
  16. Just one more note. FYI only. I experienced this problem again, with Button H this time as well. This happened on a completely different KPL, but again button H had previously been successfully programmed to have a "House OFF" scene and was working fine in Non-Toggle OFF mode. All I did this time was to add some new devices to the "House OFF" scene, and suddenly that KPL's Button H toggled over to "Toggle ON" and couldn't be changed back via normal means. The solution: Remove Button H from ALL scenes, set to Toggle mode, then set to Non-Toggle OFF (& confirmed it was working as such), then add it back to the House OFF Scene as a controller. Once it was a member of the Scene as a controller, I did not attempt to change Button H's "state" to "Off" in the scene-- doesn't matter since it's a Toggle-Off button anyway. Again, it's a minor bug if anything, but kind of annoying. Just wanted to highlight it, especially the solution, in hopes it will help someone else. P.S. FYI -- When I try to search in this forum for "button H" it tells me that the "H" is being ignored in the search. Is there a way that I am missing to search for a phrase such as "button H" that include just a single letter? It would be unfortunate if it were impossible to search for phrases such as that... Thanks much, Ralph
  17. Hello Michel and thanks for your response, Yes, that's more or less correct. After a factory reset, but before any programming, I could set button H to non-toggle-OFF. But after programming it up, when ISY was showing it as a controller of scene, and ISY showing mode as non-toggle-OFF, it would act as a non-toggle-ON. JohnnyT's problem does sound remarkably similar. However, I think I fixed it. I think there might still be a bug in the software though; I was able to reproduce the problem once, but now using the same steps I cannot. Here's what I did to make it work: 1. remove H from all scenes (it was a controller for one scene and a responder for another) 2. factory reset 3. restore KPL (other buttons besides H are still scene members/controllers) 4. set H to non-toggle-OFF via software. Non-toggle-OFF works correctly. 5. add H to scene as controller 6. Non-toggle-OFF still working! Now, I was able to break it -- just once -- by doing the following, after the above steps were completed: I went to the scene, and adjusted the "On Level" of the H button to "Off". This caused the button's behavior to flip to non-toggle-ON and stay there. Again, I was able to do this only once; I have tried to recreate this behavior two more times now, but the H button is staying in non-toggle-OFF mode... thankfully! Trying to switch the "On Level" of the H button to Off (within the scene) makes sense from an intuitive standpoint - if I'm looking at an "All Off" scene, it's an easy visual check to see that all devices are "Off". However, strictly speaking, it does not matter whether the state of "H" is On or Off in the scene, since it has been set to be a non-toggle-OFF button anyway. Anyway, not sure if there's a minor bug in the software that could use fixing, or if there was some type of scene corruption due to buggy communications maybe? Not a high priority for me since it's fixed now! It's just a little odd to me that the ISY software was apparently showing everything in the correct state, and yet a factory reset/restore does not resolve the issue... I don't mind performing a little voodoo-jiu-jitsu to get things working, but it would be nicer if I didn't have to... of course... Any suggestions as to what I might have been doing wrong would be most welcome. Apparently the trick is to set the Toggle mode of the button before adding it to any scenes? Maybe? I wish I could do a better job of reproducing the problem now! Anyway, thanks all for your time and consideration, I hope this info might help someone else... Ralph P.S. when I try to attach a file of type TXT, I'm still getting the message "The extension txt is not allowed." I would love to be able to upload files, can anyone tell me what's wrong? Do I have to be approved for uploading files? Thanks again...
  18. If it helps, here are 3 mini-logs, one for when I set the button to Toggle, another when I set it to non-toggle-ON, and another when I set it to non-toggle-OFF. https://dl.dropbox.com/u/18937746/1_setting_to_Toggle.txt https://dl.dropbox.com/u/18937746/2_setting_to_non-toggle-ON.txt https://dl.dropbox.com/u/18937746/3_setting_to_non-toggle-OFF.txt I'm guessing these look "normal", since I can see a difference between file #2 and file #3.... however, to recap, setting the button H to either non-toggle-ON or non-toggle-OFF results in behavior at the KPL of non-toggle-ON. I cannot achieve a button state of non-toggle-OFF via my ISY 3.3.10 interface running on my Mac... Thanks! Ralph
  19. Hi there and thanks for replying, KPL definitely shows 8 button: Did as you suggested, and the button H went from Toggle-mode (which I had manually set) back to non-toggle-ON: Welcome to any other suggestions. It's such a minor thing, I can manually set it to Toggle mode and that's almost as good, but it just seems.. well, it annoys me Thanks, Ralph
  20. Hi All, Pretty new to the UDI scene (recently upgraded/replaced all my old X10 to Insteon) and only been lurking here for a short while, but I have something that's really bugging me and I need to post my first question... so thanks in advance... Short version of the question: I have a KPL that, when I reset it to factory and do a Restore Device, 2 of the 3 buttons that I have defined as non-toggle OFF ("D" and "F") work fine, but a third KPL button ("H") defined as non-toggle OFF is not working correctly, it appears to be always set to non-toggle ON. Programming appears to go successfully. Attached is a log of when I program the KPL. When I check and compare the ISY links table to the device links table, it appears to be a 100% match (except for the last "ignore" entry). If I do a factory reset on the KPL, and simply manually toggle the "H" button mode before any programming (by using the "hold-Set-down 3 times method), I can successfully put the "H" button into non-toggle mode, so I have no reason to suspect that the KPL itself is bad...? However, any time I program it up, the H button appears to now have 3 states I can switch it between: toggle, non-toggle-ON, and another non-toggle ON. If (after programming) I try to manually set the toggle mode of H button, I have to cycle through what are apparently two distinct non-toggle-ON modes before I get back to Toggle mode, which is strange. I am trying to assign a "whole floor OFF" scene to this H button. I'm running v3.3.10 across the board on a Mac computer. I have a total of 6 KPL's programmed successfully now, including one other KPL which has an H button that has an "all OFF" non-toggle-OFF button/scene successfully programmed. I have a few Filterlincs in place and programming everything else seems to be going pretty smoothly nowadays. I have tried removing the H button as a controller for that "floor OFF" scene and re-adding it, but that did not help. Weird bug in 3.3.10? Broken KPL? Any suggestions would be greatly appreciated, thanks tons! Ralph P.S. Hmmm. that's weird, the forum claims I cannot attach a file with a .txt extension so I am pasting the log file below. Sorry for the large paste! Do I have to be authorized to post files? Sat 02/09/2013 12:44:43 PM : [ 1F 2A C0 1] Preparing Device 'studio_KPL.A_Studio_' for Restore Sat 02/09/2013 12:44:43 PM : [ 1F 2A C0 1] Device 'studio_KPL.A_Studio_' ready for Full Restore Sat 02/09/2013 12:44:43 PM : [iNST-TX-I1 ] 02 62 1F 2A C0 0F 0D 00 Sat 02/09/2013 12:44:43 PM : [iNST-ACK ] 02 62 1F.2A.C0 0F 0D 00 06 (00) Sat 02/09/2013 12:44:43 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 0D 02 (02) Sat 02/09/2013 12:44:43 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:43 PM : [1F 2A C0 0 ] Calibrating engine version Sat 02/09/2013 12:44:43 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Sat 02/09/2013 12:44:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 0D 02 (02) Sat 02/09/2013 12:44:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:44:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Sat 02/09/2013 12:44:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:44 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0F FF 00 A2 28 21 33 67 FF 1F 05 1A Sat 02/09/2013 12:44:44 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 02/09/2013 12:44:44 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F FF 08 A2 28 21 33 67 FF 1F 05 11 Sat 02/09/2013 12:44:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F FF 08 A2 28 21 33 67 FF 1F 05 11 06 (00) Sat 02/09/2013 12:44:45 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:45 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:45 PM : [MNG-LNK-RSP ] 02 6F 40 E2 28 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:45 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F F7 08 A2 1F 21 33 67 00 1F 08 1E Sat 02/09/2013 12:44:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F F7 08 A2 1F 21 33 67 00 1F 08 1E 06 (00) Sat 02/09/2013 12:44:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:46 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F EF 08 A2 1F 21 33 67 00 1F 07 27 Sat 02/09/2013 12:44:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F EF 08 A2 1F 21 33 67 00 1F 07 27 06 (00) Sat 02/09/2013 12:44:47 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:47 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:47 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:47 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F E7 08 A2 1E 21 33 67 FF 1F 03 35 Sat 02/09/2013 12:44:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F E7 08 A2 1E 21 33 67 FF 1F 03 35 06 (00) Sat 02/09/2013 12:44:48 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:48 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:48 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1E 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F DF 08 A2 1D 21 33 67 FF 1F 02 3F Sat 02/09/2013 12:44:49 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F DF 08 A2 1D 21 33 67 FF 1F 02 3F 06 (00) Sat 02/09/2013 12:44:49 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:49 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:49 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1D 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:49 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F D7 08 A2 1C 21 33 67 00 1F 03 46 Sat 02/09/2013 12:44:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F D7 08 A2 1C 21 33 67 00 1F 03 46 06 (00) Sat 02/09/2013 12:44:50 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:50 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:50 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F CF 08 A2 1C 21 33 67 00 1F 02 4F Sat 02/09/2013 12:44:51 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F CF 08 A2 1C 21 33 67 00 1F 02 4F 06 (00) Sat 02/09/2013 12:44:51 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:51 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:51 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:51 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F C7 08 A2 1B 21 33 67 FF 1F 03 58 Sat 02/09/2013 12:44:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F C7 08 A2 1B 21 33 67 FF 1F 03 58 06 (00) Sat 02/09/2013 12:44:52 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:52 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:52 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F BF 08 A2 1B 21 33 67 FF 1F 02 61 Sat 02/09/2013 12:44:53 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F BF 08 A2 1B 21 33 67 FF 1F 02 61 06 (00) Sat 02/09/2013 12:44:53 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:53 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:53 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:53 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F B7 08 A2 16 21 33 67 FF 1F 07 69 Sat 02/09/2013 12:44:54 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F B7 08 A2 16 21 33 67 FF 1F 07 69 06 (00) Sat 02/09/2013 12:44:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:54 PM : [MNG-LNK-RSP ] 02 6F 40 E2 16 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:54 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F AF 08 A2 14 21 33 67 FF 1F 07 73 Sat 02/09/2013 12:44:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F AF 08 A2 14 21 33 67 FF 1F 07 73 06 (00) Sat 02/09/2013 12:44:55 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:55 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:55 PM : [MNG-LNK-RSP ] 02 6F 40 E2 14 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F A7 08 A2 12 21 33 67 FF 1F 07 7D Sat 02/09/2013 12:44:56 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F A7 08 A2 12 21 33 67 FF 1F 07 7D 06 (00) Sat 02/09/2013 12:44:56 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:56 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:56 PM : [MNG-LNK-RSP ] 02 6F 40 E2 12 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:56 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 9F 08 A2 11 21 33 67 00 1B 08 88 Sat 02/09/2013 12:44:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 9F 08 A2 11 21 33 67 00 1B 08 88 06 (00) Sat 02/09/2013 12:44:57 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:57 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:57 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 97 08 A2 11 21 33 67 00 1B 07 91 Sat 02/09/2013 12:44:58 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 97 08 A2 11 21 33 67 00 1B 07 91 06 (00) Sat 02/09/2013 12:44:58 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:58 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:58 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:58 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 8F 08 A2 11 21 33 67 00 1B 06 9A Sat 02/09/2013 12:44:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 8F 08 A2 11 21 33 67 00 1B 06 9A 06 (00) Sat 02/09/2013 12:44:59 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:44:59 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:44:59 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:44:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 87 08 A2 11 21 33 67 00 1B 05 A3 Sat 02/09/2013 12:45:00 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 87 08 A2 11 21 33 67 00 1B 05 A3 06 (00) Sat 02/09/2013 12:45:00 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:00 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:00 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:00 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 7F 08 A2 11 21 33 67 00 1B 04 AC Sat 02/09/2013 12:45:01 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 7F 08 A2 11 21 33 67 00 1B 04 AC 06 (00) Sat 02/09/2013 12:45:01 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:01 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:01 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:01 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 77 08 A2 11 21 33 67 00 1B 03 B5 Sat 02/09/2013 12:45:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 77 08 A2 11 21 33 67 00 1B 03 B5 06 (00) Sat 02/09/2013 12:45:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:02 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 6F 08 A2 11 21 33 67 00 1B 02 BE Sat 02/09/2013 12:45:03 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 6F 08 A2 11 21 33 67 00 1B 02 BE 06 (00) Sat 02/09/2013 12:45:03 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:03 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:03 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:03 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 67 08 A2 08 1F 29 94 00 1F 08 A4 Sat 02/09/2013 12:45:04 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 67 08 A2 08 1F 29 94 00 1F 08 A4 06 (00) Sat 02/09/2013 12:45:04 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:04 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:04 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 5F 08 A2 08 1F 29 94 00 1F 07 AD Sat 02/09/2013 12:45:04 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 5F 08 A2 08 1F 29 94 00 1F 07 AD 06 (00) Sat 02/09/2013 12:45:05 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:05 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:05 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 57 08 A2 08 1F 29 94 00 1F 06 B6 Sat 02/09/2013 12:45:05 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 57 08 A2 08 1F 29 94 00 1F 06 B6 06 (00) Sat 02/09/2013 12:45:06 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:06 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 4F 08 A2 08 1F 29 94 00 1F 05 BF Sat 02/09/2013 12:45:06 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 4F 08 A2 08 1F 29 94 00 1F 05 BF 06 (00) Sat 02/09/2013 12:45:06 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:06 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 47 08 A2 08 1F 29 94 00 1F 04 C8 Sat 02/09/2013 12:45:06 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 47 08 A2 08 1F 29 94 00 1F 04 C8 06 (00) Sat 02/09/2013 12:45:06 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:06 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 3F 08 A2 08 1F 29 94 00 1F 03 D1 Sat 02/09/2013 12:45:07 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 3F 08 A2 08 1F 29 94 00 1F 03 D1 06 (00) Sat 02/09/2013 12:45:07 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:07 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:07 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 37 08 A2 08 1F 29 94 00 1F 02 DA Sat 02/09/2013 12:45:07 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 37 08 A2 08 1F 29 94 00 1F 02 DA 06 (00) Sat 02/09/2013 12:45:08 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:08 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:08 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 2F 08 A2 06 1F 2D 18 FF 1F 05 5A Sat 02/09/2013 12:45:08 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 2F 08 A2 06 1F 2D 18 FF 1F 05 5A 06 (00) Sat 02/09/2013 12:45:08 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:08 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:08 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 27 08 A2 06 1F 2C C1 FF 1F 05 BA Sat 02/09/2013 12:45:08 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 27 08 A2 06 1F 2C C1 FF 1F 05 BA 06 (00) Sat 02/09/2013 12:45:09 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:09 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:09 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 1F 08 A2 05 1F 2D 18 FF 1F 03 6D Sat 02/09/2013 12:45:09 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 1F 08 A2 05 1F 2D 18 FF 1F 03 6D 06 (00) Sat 02/09/2013 12:45:10 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:10 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:10 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 17 08 A2 05 1F 2D 18 FF 1F 02 76 Sat 02/09/2013 12:45:10 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 17 08 A2 05 1F 2D 18 FF 1F 02 76 06 (00) Sat 02/09/2013 12:45:10 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:10 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:10 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 0F 08 A2 05 1F 2C C1 FF 1F 03 D5 Sat 02/09/2013 12:45:10 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 0F 08 A2 05 1F 2C C1 FF 1F 03 D5 06 (00) Sat 02/09/2013 12:45:11 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:11 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:11 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 07 08 A2 05 1F 2C C1 FF 1F 02 DE Sat 02/09/2013 12:45:11 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 07 08 A2 05 1F 2C C1 FF 1F 02 DE 06 (00) Sat 02/09/2013 12:45:12 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:12 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:12 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E FF 08 A2 04 1C 3F A4 FF 1F 07 F0 Sat 02/09/2013 12:45:12 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E FF 08 A2 04 1C 3F A4 FF 1F 07 F0 06 (00) Sat 02/09/2013 12:45:12 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:12 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:12 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E F7 08 A2 03 1F 29 94 FF 1F 07 1C Sat 02/09/2013 12:45:12 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E F7 08 A2 03 1F 29 94 FF 1F 07 1C 06 (00) Sat 02/09/2013 12:45:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E EF 08 A2 02 1F 29 94 FF 1F 07 25 Sat 02/09/2013 12:45:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E EF 08 A2 02 1F 29 94 FF 1F 07 25 06 (00) Sat 02/09/2013 12:45:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E E7 08 A2 02 1C 3F A4 FF 1F 07 0A Sat 02/09/2013 12:45:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E E7 08 A2 02 1C 3F A4 FF 1F 07 0A 06 (00) Sat 02/09/2013 12:45:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36 Sat 02/09/2013 12:45:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:23 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36 Sat 02/09/2013 12:45:23 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36 06 (00) Sat 02/09/2013 12:45:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:24 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E D7 08 A2 01 1C 3F A4 FF 1F 07 1B Sat 02/09/2013 12:45:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E D7 08 A2 01 1C 3F A4 FF 1F 07 1B 06 (00) Sat 02/09/2013 12:45:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E CF 08 A2 00 21 33 67 FF 1F 05 6A Sat 02/09/2013 12:45:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E CF 08 A2 00 21 33 67 FF 1F 05 6A 06 (00) Sat 02/09/2013 12:45:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:25 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E C7 08 A2 1C 21 33 67 00 1F 01 59 Sat 02/09/2013 12:45:26 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E C7 08 A2 1C 21 33 67 00 1F 01 59 06 (00) Sat 02/09/2013 12:45:26 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:26 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:26 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E BF 08 A2 1B 21 33 67 FF 1F 01 63 Sat 02/09/2013 12:45:27 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E BF 08 A2 1B 21 33 67 FF 1F 01 63 06 (00) Sat 02/09/2013 12:45:27 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:27 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:27 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:27 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E B7 08 A2 11 21 33 67 00 1B 01 78 Sat 02/09/2013 12:45:28 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E B7 08 A2 11 21 33 67 00 1B 01 78 06 (00) Sat 02/09/2013 12:45:28 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:28 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:29 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:29 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E AF 08 A2 08 1F 29 94 00 1F 01 64 Sat 02/09/2013 12:45:29 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E AF 08 A2 08 1F 29 94 00 1F 01 64 06 (00) Sat 02/09/2013 12:45:29 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:29 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:29 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E A7 08 A2 05 1F 2D 18 FF 1F 01 E8 Sat 02/09/2013 12:45:29 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E A7 08 A2 05 1F 2D 18 FF 1F 01 E8 06 (00) Sat 02/09/2013 12:45:30 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:30 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:30 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 9F 08 A2 05 1F 2C C1 FF 1F 01 48 Sat 02/09/2013 12:45:30 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 9F 08 A2 05 1F 2C C1 FF 1F 01 48 06 (00) Sat 02/09/2013 12:45:31 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:31 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:31 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 97 08 A2 00 21 33 67 FF 1F 01 A6 Sat 02/09/2013 12:45:31 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 97 08 A2 00 21 33 67 FF 1F 01 A6 06 (00) Sat 02/09/2013 12:45:31 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:31 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:32 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:32 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 8F 08 E2 01 1A EA AD FF 1F 01 77 Sat 02/09/2013 12:45:32 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 8F 08 E2 01 1A EA AD FF 1F 01 77 06 (00) Sat 02/09/2013 12:45:32 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:32 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:32 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 87 08 E2 01 1A F5 20 FF 1F 01 01 Sat 02/09/2013 12:45:32 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 87 08 E2 01 1A F5 20 FF 1F 01 01 06 (00) Sat 02/09/2013 12:45:33 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:33 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:33 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 7F 08 E2 01 1F 2C C1 FF 1F 01 2C Sat 02/09/2013 12:45:33 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 7F 08 E2 01 1F 2C C1 FF 1F 01 2C 06 (00) Sat 02/09/2013 12:45:34 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:34 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:34 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 77 08 E2 01 1F 2D 18 FF 1F 01 DC Sat 02/09/2013 12:45:34 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 77 08 E2 01 1F 2D 18 FF 1F 01 DC 06 (00) Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:35 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 6F 08 E2 01 21 33 67 FF 1F 01 8D Sat 02/09/2013 12:45:35 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 6F 08 E2 01 21 33 67 FF 1F 01 8D 06 (00) Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:35 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:35 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 67 08 E2 02 1A EA AD FF 1F 02 9D Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 67 08 E2 02 1A EA AD FF 1F 02 9D 06 (00) Sat 02/09/2013 12:45:36 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:36 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:36 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 5F 08 E2 02 21 33 67 FF 1F 02 9B Sat 02/09/2013 12:45:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 5F 08 E2 02 21 33 67 FF 1F 02 9B 06 (00) Sat 02/09/2013 12:45:37 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:37 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:37 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 57 08 E2 03 1A F5 20 FF 1F 03 2D Sat 02/09/2013 12:45:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 57 08 E2 03 1A F5 20 FF 1F 03 2D 06 (00) Sat 02/09/2013 12:45:38 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:38 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:38 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 4F 08 E2 03 21 33 67 FF 1F 03 A9 Sat 02/09/2013 12:45:38 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 4F 08 E2 03 21 33 67 FF 1F 03 A9 06 (00) Sat 02/09/2013 12:45:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:39 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 47 08 E2 04 21 33 67 FF 1F 04 AF Sat 02/09/2013 12:45:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 47 08 E2 04 21 33 67 FF 1F 04 AF 06 (00) Sat 02/09/2013 12:45:40 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:40 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:40 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:40 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 3F 08 E2 05 1A F5 87 FF 1F 05 DA Sat 02/09/2013 12:45:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 3F 08 E2 05 1A F5 87 FF 1F 05 DA 06 (00) Sat 02/09/2013 12:45:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:41 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 37 08 E2 05 1F 2C C1 FF 1F 05 6C Sat 02/09/2013 12:45:41 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 37 08 E2 05 1F 2C C1 FF 1F 05 6C 06 (00) Sat 02/09/2013 12:45:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:41 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 2F 08 E2 05 1F 2D 18 FF 1F 05 1C Sat 02/09/2013 12:45:41 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 2F 08 E2 05 1F 2D 18 FF 1F 05 1C 06 (00) Sat 02/09/2013 12:45:42 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:42 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:42 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 27 08 E2 05 21 33 67 FF 1F 05 CD Sat 02/09/2013 12:45:42 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 27 08 E2 05 21 33 67 FF 1F 05 CD 06 (00) Sat 02/09/2013 12:45:43 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:43 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:43 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:43 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 1F 08 E2 06 21 33 67 FF 1F 06 D3 Sat 02/09/2013 12:45:43 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 1F 08 E2 06 21 33 67 FF 1F 06 D3 06 (00) Sat 02/09/2013 12:45:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:44 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:44 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 17 08 E2 07 1A EA A7 FF 1F 07 E9 Sat 02/09/2013 12:45:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 17 08 E2 07 1A EA A7 FF 1F 07 E9 06 (00) Sat 02/09/2013 12:45:45 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:45 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:45 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 0F 08 E2 07 1A F4 4F FF 1F 07 3F Sat 02/09/2013 12:45:45 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 0F 08 E2 07 1A F4 4F FF 1F 07 3F 06 (00) Sat 02/09/2013 12:45:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 07 08 E2 07 1A F5 66 FF 1F 07 2F Sat 02/09/2013 12:45:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 07 08 E2 07 1A F5 66 FF 1F 07 2F 06 (00) Sat 02/09/2013 12:45:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D FF 08 E2 07 1A F5 AD FF 1F 07 F1 Sat 02/09/2013 12:45:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D FF 08 E2 07 1A F5 AD FF 1F 07 F1 06 (00) Sat 02/09/2013 12:45:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D F7 08 E2 07 1A F5 BC FF 1F 07 EA Sat 02/09/2013 12:45:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D F7 08 E2 07 1A F5 BC FF 1F 07 EA 06 (00) Sat 02/09/2013 12:45:47 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:47 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:47 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D EF 08 E2 07 1A F7 CB FF 1F 07 E1 Sat 02/09/2013 12:45:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D EF 08 E2 07 1A F7 CB FF 1F 07 E1 06 (00) Sat 02/09/2013 12:45:48 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:48 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D E7 08 E2 07 1D 0B 75 FF 1F 07 28 Sat 02/09/2013 12:45:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D E7 08 E2 07 1D 0B 75 FF 1F 07 28 06 (00) Sat 02/09/2013 12:45:48 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:48 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D DF 08 E2 07 1D 0B 81 FF 1F 07 24 Sat 02/09/2013 12:45:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D DF 08 E2 07 1D 0B 81 FF 1F 07 24 06 (00) Sat 02/09/2013 12:45:49 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:49 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:49 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D D7 08 E2 07 1D 0E 39 FF 1F 07 71 Sat 02/09/2013 12:45:49 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D D7 08 E2 07 1D 0E 39 FF 1F 07 71 06 (00) Sat 02/09/2013 12:45:50 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:50 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D CF 08 E2 07 1D 0F 5E FF 1F 07 53 Sat 02/09/2013 12:45:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D CF 08 E2 07 1D 0F 5E FF 1F 07 53 06 (00) Sat 02/09/2013 12:45:50 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:50 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D C7 08 E2 07 1D 0F 7A FF 1F 07 3F Sat 02/09/2013 12:45:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D C7 08 E2 07 1D 0F 7A FF 1F 07 3F 06 (00) Sat 02/09/2013 12:45:51 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:51 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:51 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D BF 08 E2 07 1D 10 3E FF 1F 07 82 Sat 02/09/2013 12:45:51 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D BF 08 E2 07 1D 10 3E FF 1F 07 82 06 (00) Sat 02/09/2013 12:45:52 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:52 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D B7 08 E2 07 1F 29 94 FF 1F 07 19 Sat 02/09/2013 12:45:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D B7 08 E2 07 1F 29 94 FF 1F 07 19 06 (00) Sat 02/09/2013 12:45:52 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:52 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D AF 08 E2 07 1F 2C C1 FF 1F 07 F1 Sat 02/09/2013 12:45:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D AF 08 E2 07 1F 2C C1 FF 1F 07 F1 06 (00) Sat 02/09/2013 12:45:53 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:53 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:53 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D A7 08 E2 07 21 33 67 FF 1F 07 4A Sat 02/09/2013 12:45:53 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D A7 08 E2 07 21 33 67 FF 1F 07 4A 06 (00) Sat 02/09/2013 12:45:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:54 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:45:54 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 9F 08 E2 08 1A EA A7 FF 1F 08 60 Sat 02/09/2013 12:45:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:45:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:45:54 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 9F 08 E2 08 1A EA A7 FF 1F 08 60 06 (00) Sat 02/09/2013 12:45:55 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:55 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 97 08 E2 08 1A F4 4F FF 1F 08 B6 Sat 02/09/2013 12:45:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 97 08 E2 08 1A F4 4F FF 1F 08 B6 06 (00) Sat 02/09/2013 12:45:55 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:55 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 8F 08 E2 08 1A F4 7A FF 1F 08 93 Sat 02/09/2013 12:45:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 8F 08 E2 08 1A F4 7A FF 1F 08 93 06 (00) Sat 02/09/2013 12:45:56 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:56 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:56 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 87 08 E2 08 1A F4 95 FF 1F 08 80 Sat 02/09/2013 12:45:56 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 87 08 E2 08 1A F4 95 FF 1F 08 80 06 (00) Sat 02/09/2013 12:45:57 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:57 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 7F 08 E2 08 1A F5 66 FF 1F 08 B6 Sat 02/09/2013 12:45:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 7F 08 E2 08 1A F5 66 FF 1F 08 B6 06 (00) Sat 02/09/2013 12:45:57 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:57 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 77 08 E2 08 1A F5 AD FF 1F 08 77 Sat 02/09/2013 12:45:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 77 08 E2 08 1A F5 AD FF 1F 08 77 06 (00) Sat 02/09/2013 12:45:58 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:58 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:58 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 6F 08 E2 08 1A F5 BC FF 1F 08 70 Sat 02/09/2013 12:45:58 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 6F 08 E2 08 1A F5 BC FF 1F 08 70 06 (00) Sat 02/09/2013 12:45:59 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:59 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 67 08 E2 08 1A F6 34 FF 1F 08 FF Sat 02/09/2013 12:45:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 67 08 E2 08 1A F6 34 FF 1F 08 FF 06 (00) Sat 02/09/2013 12:45:59 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:45:59 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:45:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 5F 08 E2 08 1A F7 0E FF 1F 08 2C Sat 02/09/2013 12:45:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 5F 08 E2 08 1A F7 0E FF 1F 08 2C 06 (00) Sat 02/09/2013 12:46:00 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:00 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:00 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 57 08 E2 08 1A F7 C7 FF 1F 08 7B Sat 02/09/2013 12:46:00 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 57 08 E2 08 1A F7 C7 FF 1F 08 7B 06 (00) Sat 02/09/2013 12:46:01 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 27 2F 00 (00) Sat 02/09/2013 12:46:01 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=1 Sat 02/09/2013 12:46:01 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 4F 08 E2 08 1A F7 CB FF 1F 08 7F Sat 02/09/2013 12:46:01 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 4F 08 E2 08 1A F7 CB FF 1F 08 7F 06 (00) Sat 02/09/2013 12:46:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 47 08 E2 08 1A F9 7B FF 1F 08 D5 Sat 02/09/2013 12:46:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 47 08 E2 08 1A F9 7B FF 1F 08 D5 06 (00) Sat 02/09/2013 12:46:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:46:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 3F 08 E2 08 1A FA 3D FF 1F 08 1A Sat 02/09/2013 12:46:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 3F 08 E2 08 1A FA 3D FF 1F 08 1A 06 (00) Sat 02/09/2013 12:46:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 37 08 E2 08 1D 0B 75 FF 1F 08 D6 Sat 02/09/2013 12:46:03 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 37 08 E2 08 1D 0B 75 FF 1F 08 D6 06 (00) Sat 02/09/2013 12:46:03 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:03 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:03 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2 Sat 02/09/2013 12:46:04 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:04 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2 Sat 02/09/2013 12:46:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2 06 (00) Sat 02/09/2013 12:46:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 27 08 E2 08 1D 0E 39 FF 1F 08 1F Sat 02/09/2013 12:46:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 27 08 E2 08 1D 0E 39 FF 1F 08 1F 06 (00) Sat 02/09/2013 12:46:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 1F 08 E2 08 1D 0F 5E FF 1F 08 01 Sat 02/09/2013 12:46:14 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 1F 08 E2 08 1D 0F 5E FF 1F 08 01 06 (00) Sat 02/09/2013 12:46:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 17 08 E2 08 1D 0F 7A FF 1F 08 ED Sat 02/09/2013 12:46:14 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 17 08 E2 08 1D 0F 7A FF 1F 08 ED 06 (00) Sat 02/09/2013 12:46:15 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:15 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:15 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 0F 08 E2 08 1D 10 3E FF 1F 08 30 Sat 02/09/2013 12:46:15 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 0F 08 E2 08 1D 10 3E FF 1F 08 30 06 (00) Sat 02/09/2013 12:46:16 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:16 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:16 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 07 08 E2 08 1D F4 0B FF 1F 08 87 Sat 02/09/2013 12:46:16 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 07 08 E2 08 1D F4 0B FF 1F 08 87 06 (00) Sat 02/09/2013 12:46:17 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:17 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:17 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C FF 08 E2 08 1F 29 94 FF 1F 08 D0 Sat 02/09/2013 12:46:17 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C FF 08 E2 08 1F 29 94 FF 1F 08 D0 06 (00) Sat 02/09/2013 12:46:17 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:17 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:17 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C F7 08 E2 08 1F 2C C1 FF 1F 08 A8 Sat 02/09/2013 12:46:17 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C F7 08 E2 08 1F 2C C1 FF 1F 08 A8 06 (00) Sat 02/09/2013 12:46:18 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:18 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:18 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C EF 08 E2 08 1F 2C D6 FF 1F 08 9B Sat 02/09/2013 12:46:18 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C EF 08 E2 08 1F 2C D6 FF 1F 08 9B 06 (00) Sat 02/09/2013 12:46:19 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:19 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:19 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C E7 08 E2 08 1F 2D 18 FF 1F 08 60 Sat 02/09/2013 12:46:19 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C E7 08 E2 08 1F 2D 18 FF 1F 08 60 06 (00) Sat 02/09/2013 12:46:19 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:19 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:19 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C DF 08 E2 08 21 33 67 FF 1F 08 11 Sat 02/09/2013 12:46:19 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C DF 08 E2 08 21 33 67 FF 1F 08 11 06 (00) Sat 02/09/2013 12:46:20 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00) Sat 02/09/2013 12:46:20 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:46:20 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1F 2A C0 01 1C 41 15 Sat 02/09/2013 12:46:20 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C D7 08 00 00 00 00 00 00 00 00 E4 Sat 02/09/2013 12:46:20 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:20 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:20 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C D7 08 00 00 00 00 00 00 00 00 E4 06 (00) Sat 02/09/2013 12:46:21 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:21 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:21 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 Sat 02/09/2013 12:46:21 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 06 (00) Sat 02/09/2013 12:46:22 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:22 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:22 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0C CF 00 00 00 00 00 00 00 00 00 F5 Sat 02/09/2013 12:46:22 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 02/09/2013 12:46:22 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 Sat 02/09/2013 12:46:22 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 06 (00) Sat 02/09/2013 12:46:23 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:23 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:23 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0C CF 00 00 00 00 00 00 00 00 00 F5 Sat 02/09/2013 12:46:23 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sat 02/09/2013 12:46:23 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C CF 08 00 00 00 00 00 00 00 00 EC Sat 02/09/2013 12:46:23 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C CF 08 00 00 00 00 00 00 00 00 EC 06 (00) Sat 02/09/2013 12:46:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00) Sat 02/09/2013 12:46:24 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 06 00 00 00 00 00 00 00 00 00 00 00 C4 Sat 02/09/2013 12:46:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 06 00 00 00 00 00 00 00 00 00 00 00 C4 06 (00) Sat 02/09/2013 12:46:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:24 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 05 1F 00 00 00 00 00 00 00 00 00 00 A6 Sat 02/09/2013 12:46:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 05 1F 00 00 00 00 00 00 00 00 00 00 A6 06 (00) Sat 02/09/2013 12:46:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC Sat 02/09/2013 12:46:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC 06 (00) Sat 02/09/2013 12:46:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2E 00 (00) Sat 02/09/2013 12:46:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:46:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD Sat 02/09/2013 12:46:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD 06 (00) Sat 02/09/2013 12:46:26 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:26 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 07 7F 00 00 00 00 00 00 00 00 00 00 4B Sat 02/09/2013 12:46:26 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 07 7F 00 00 00 00 00 00 00 00 00 00 4B 06 (00) Sat 02/09/2013 12:46:26 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:26 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75 Sat 02/09/2013 12:46:27 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:27 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:36 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75 Sat 02/09/2013 12:46:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75 06 (00) Sat 02/09/2013 12:46:37 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:37 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 03 40 00 00 00 00 00 00 00 00 00 00 87 Sat 02/09/2013 12:46:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 03 40 00 00 00 00 00 00 00 00 00 00 87 06 (00) Sat 02/09/2013 12:46:37 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:37 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 08 A8 00 00 00 00 00 00 00 00 00 00 21 Sat 02/09/2013 12:46:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 08 A8 00 00 00 00 00 00 00 00 00 00 21 06 (00) Sat 02/09/2013 12:46:38 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:38 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:38 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 02 00 00 00 00 00 00 00 00 00 00 00 C8 Sat 02/09/2013 12:46:38 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 02 00 00 00 00 00 00 00 00 00 00 00 C8 06 (00) Sat 02/09/2013 12:46:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 02 06 00 00 00 00 00 00 00 00 00 00 C9 Sat 02/09/2013 12:46:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 02 06 00 00 00 00 00 00 00 00 00 00 C9 06 (00) Sat 02/09/2013 12:46:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC Sat 02/09/2013 12:46:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC 06 (00) Sat 02/09/2013 12:46:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2E 00 (00) Sat 02/09/2013 12:46:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0 Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD Sat 02/09/2013 12:46:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD 06 (00) Sat 02/09/2013 12:46:40 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:40 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:40 PM : [iNST-TX-I1 ] 02 62 1F 2A C0 0F 24 00 Sat 02/09/2013 12:46:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 0F 24 00 06 (00) Sat 02/09/2013 12:46:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00) Sat 02/09/2013 12:46:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sat 02/09/2013 12:46:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 24 00 (00) Sat 02/09/2013 12:46:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
