ejh
Everything posted by ejh
  1. ejh replied to bh56's topic in ISY994
    That was it. Thank you very much. The PLM has a limitation of around 1000 links I thought. I have over 100 Insteon devices in the home. What happens if the link table outgrows the PLM. I do not believe you can add a second PLM.
  2. ejh replied to bh56's topic in ISY994
    Result Device Links Table 0 : 0FF8 : E2 01 1C.FB.8D FF 1F 01 1 : 0FF0 : E2 02 1C.FB.8D FF 1F 02 2 : 0FE8 : 00 00 00.00.00 00 00 00 ISY Links Table 0 : 0FF8 : E2 01 1C.FB.8D FF 1F 01 1 : 0FF0 : E2 02 1C.FB.8D FF 1F 02 2 : 0FE8 : 00 00 00.00.00 00 00 00
  3. ejh replied to bh56's topic in ISY994
    Log from Leak sensor device add Sun 02/10/2013 07:39:52 PM : [21 7d d7 ] Added to list of devices to link to ISY Sun 02/10/2013 07:39:52 PM : [iNST-TX-I1 ] 02 62 21 7D D7 0F 0D 00 Sun 02/10/2013 07:39:52 PM : [iNST-ACK ] 02 62 21.7D.D7 0F 0D 00 06 (00) Sun 02/10/2013 07:39:52 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 0D 02 (02) Sun 02/10/2013 07:39:52 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:52 PM : [iNST-TX-I1 ] 02 62 21 7D D7 0F 10 00 Sun 02/10/2013 07:39:52 PM : [iNST-ACK ] 02 62 21.7D.D7 0F 10 00 06 ID-REQ (00) Sun 02/10/2013 07:39:53 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 10 00 ID-REQ (00) Sun 02/10/2013 07:39:53 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:53 PM : [iNST-SRX ] 02 50 21.7D.D7 10.08.3E 8B 02 00 (00) Sun 02/10/2013 07:39:53 PM : [std-Broadcast] 21.7D.D7-->10.08.3E, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:53 PM : [21 7D D7 0 ] Calibrating engine version Sun 02/10/2013 07:39:53 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 Sun 02/10/2013 07:39:53 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00) Sun 02/10/2013 07:39:53 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:53 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:54 PM : [iNST-ERX ] 02 51 21 7D D7 1C FB 8D 11 2F 00 00 01 0F FF 01 E2 01 1C FB 8D FF 1F 01 1B Sun 02/10/2013 07:39:54 PM : [Ext-Direct ] 21.7D.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sun 02/10/2013 07:39:54 PM : [21 7D D7 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0FF8) Sun 02/10/2013 07:39:54 PM : [21 7D D7 1 ] Start : Adding device to ISY Sun 02/10/2013 07:39:54 PM : [21 7D D7 1 ] Finish : Adding device to ISY was Successful Sun 02/10/2013 07:39:54 PM : [21 7D D7 2 ] Start : Adding device to ISY Sun 02/10/2013 07:39:54 PM : [21 7D D7 2 ] Finish : Adding device to ISY was Successful Sun 02/10/2013 07:39:54 PM : [21 7D D7 0 ] Successfully added device Sun 02/10/2013 07:39:55 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 02 0F FF 08 E2 01 1C FB 8D FF 1F 01 13 Sun 02/10/2013 07:39:55 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 02 0F FF 08 E2 01 1C FB 8D FF 1F 01 13 06 (00) Sun 02/10/2013 07:39:55 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:55 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:55 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 21 7D D7 10 08 3E 15 Sun 02/10/2013 07:39:55 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 02 0F F7 08 E2 02 1C FB 8D FF 1F 02 19 Sun 02/10/2013 07:39:56 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 02 0F F7 08 E2 02 1C FB 8D FF 1F 02 19 06 (00) Sun 02/10/2013 07:39:56 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:56 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:56 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 21 7D D7 10 08 3E 15 Sun 02/10/2013 07:39:56 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 02 0F EF 08 00 00 00 00 00 00 00 00 C9 Sun 02/10/2013 07:39:57 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 02 0F EF 08 00 00 00 00 00 00 00 00 C9 06 (00) Sun 02/10/2013 07:39:57 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:57 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:57 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA Sun 02/10/2013 07:39:57 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00) Sun 02/10/2013 07:39:58 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:58 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:58 PM : [iNST-ERX ] 02 51 21 7D D7 1C FB 8D 11 2F 00 3C 01 0F E7 01 00 00 00 00 00 00 00 00 9D Sun 02/10/2013 07:39:58 PM : [Ext-Direct ] 21.7D.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sun 02/10/2013 07:39:58 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA Sun 02/10/2013 07:39:58 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00) Sun 02/10/2013 07:39:59 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:39:59 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 Sun 02/10/2013 07:39:59 PM : [iNST-ERX ] 02 51 21 7D D7 1C FB 8D 11 2F 00 00 01 0F E7 01 00 00 00 00 00 00 00 00 D9 Sun 02/10/2013 07:39:59 PM : [Ext-Direct ] 21.7D.D7-->ISY/PLM Group=0, Max Hops=1, Hops Left=0 Sun 02/10/2013 07:39:59 PM : [iNST-TX-I2CS] 02 62 21 7D D7 1F 2F 00 00 02 0F E7 08 00 00 00 00 00 00 00 00 D1 Sun 02/10/2013 07:39:59 PM : [iNST-ACK ] 02 62 21.7D.D7 1F 2F 00 00 02 0F E7 08 00 00 00 00 00 00 00 00 D1 06 (00) Sun 02/10/2013 07:40:00 PM : [iNST-SRX ] 02 50 21.7D.D7 1C.FB.8D 2B 2F 00 (00) Sun 02/10/2013 07:40:00 PM : [std-Direct Ack] 21.7D.D7-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
  4. ejh replied to bh56's topic in ISY994
    The sensor then as I understand it sends WET -On or DRY-On only which implies it's counterpart is in the Off state.
  5. ejh replied to bh56's topic in ISY994
    Both Firmware and UI are identical. Insteon_UD99 v3.3.10 (2013-01-17-01:38:06) ISY 99i/IR Pro
  6. ejh replied to bh56's topic in ISY994
    I have done no manual linking. I did delete the second device and then add it back in to see how the records were entered in the PLM. Again they are E2 not A2. The PLM is a 2413S V1.6 purchased about 6 months ago. I do not know if the PLM firmware version should matter. Is there a way to safely edit the PLM records without messing up what the ISY thinks they should be? It seems strange both devices are consistently entered in the PLM as E2 when I add them telling the ISY to delete all records in the sensor device. I have deleted them twice each and they consistently show back up the same way. Thanks again
  7. ejh replied to bh56's topic in ISY994
    After reading my post bad spelling may make things unclear The device links are as you suggested E2 01 and second line E2 02 The PLM links are not as you thought they should be they are E2 ..... Then E2....... Not A2.... A2.... I am about 6 feet away from one of my dual band devices and about 20 feet away from the dual band PLM. I do not think it is a signal issue. I think what I'm see is both links as controller and none as responder? However putting one device linked to a light in a dish of water will light the lamp. It will not shut it off I need to command it off manually.
  8. ejh replied to bh56's topic in ISY994
    Well cut and paste got me again. On the Device links it is 01 the 02 in the respective lines. However in the PLM the are E2 not A2. Is see nothing in the Event viewer for either device at L3 Both devices show E2 in the PLM Thanks for the help.
  9. ejh replied to bh56's topic in ISY994
    Forgot to add I'm running v3.3.10
  10. ejh replied to bh56's topic in ISY994
    I've added 2 Leak sensors. However I'm unable to see the status of either. I did link 1 sensor WET node to a light and when the sensor is placed in a dish of water the light will immediately turn on. I've tried deleting and re-adding the device as well as looking at the link tables of the Dry node. Link Table of device 0 0FF8 : E2 01 1C.FB.8D FF 1F 01 1 0FF0 : E2 01 1C.FB.8D FF 1F 02 2 0FE8 : 00 00 00.00.00 00 00 00 Same as above in PLM Linking looks OK?? I know I'm receiving the signal as the linked lamp does turn on. The above table is for the second device that is not linked to the lamp so there is no entry for the lamp. Still no status of either device WET or DRY. Any suggestions are welcome.
