scrutch
  1. It appears that this lock only supports smart start. When I follow the instructions, On UD Mobile I see Progress Report Starting show progress does not show anny progress (ever). In the log on my Mac I. see [ZWAVE-SMARTSTART] SmartStart provisioning entry added [17902-60867-38559-11501-33055-52036-52317-51741] After that message, the only suspicious Messages are: 01/13/2025 02:31:14 PM : [ZWAVE-CTL-EVENT ] Basic Set from 3.0 unmapped (ignored) I just tried with secure inclusion after removing the provisioning. I got the same result except that I do not see the [ZWAVE-CTL-EVENT messages. And the progress report screen disappeared on UD Mobile. It seems like some people did not have this problem installing the 620. Please let me know what you did.
  2. WeatherFlow is connecting but not showing any data. Was working on 5.7.0 not working on 5.8.0 There is no error indication that I can find
  3. This nodeserver looks so promising if only I knew how to use it. A good place to start would be to explain how to fill in the fields on the add dialog. e.g. What is an address? Is there a format? What is a device controller? How would I use it? There must be documentation.
  4. Query did the trick. Thank you. You are a wizard.
  5. Bob, it is not counting anything. Screenshot attached. I have over 100 Insteon devices and 20+ Z-wave devices. Is a post like this the best way to get support? ST-Inventory_5-22-2023_20713_PM.zip
  6. After installing Ring nodeserver, ST-Inventory stopped displaying nodes. It was working before. From Debug Log 2023-05-21 13:37:44 error: NS: Parsing Error: TypeError: Cannot read properties of undefined (reading 'includes') at Controller.processNetworkResources (/var/polyglot/pg3/ns/0021b9026061_2/Nodes/ControllerNode.js:209:19) at Controller.onDiscover (/var/polyglot/pg3/ns/0021b9026061_2/Nodes/ControllerNode.js:85:12)
  7. In addition to the number of Insteon and Z-wave nodes. Please count the number of Insteon and Z-wave physicaldevices.
  8. Actually when I click on the ST-Inventory Node, it Displays the same thing as the last node I had displayed before. E.g if I display an insteon switch, then ST-Inventory it shows me the switch status. If I had displayed a z-wave weather node, it displays the humidity.
  9. I purchased free trial and installed it. I see a node for ST-Inventory, but no Data. It says it is idle and the battery is 100%. Went back to PG3 to see if I was missing something. Is says it is self configuring. What have I failed to do? How do I see the inventory?
  10. scrutch replied to jlegault's topic in eisy
    I have (pre) ordered my eisy, zMatter USB, and Serial PLM Kit. I see that the zMatter USB has 2 connectors for external antennas. Does anyone have a recommendation for Antennas?
  11. The problem is still not resolved. I am so frustrated I am considering making them a contribution to an artificial reef. This has the makings for the journal of irreprduceable results. I have a ticket open with UD. 2 weeks and no response to my last question.s I have set the project aside because it is just too frustrating. I will work on building resolve and go back to it soon.
  12. ISY 994/IR PRO (1110) Z-Wave (21010) 500 Dongle Firmware 5.3.0 Discovered this when trying to configure 2 new Zooz ZSE18 Motion Sensors.When I got the same errors on both, I tried query one a Dome door window sensor and got similar results. >>>>>>ATTEMPTED SET CONFIGURATION PARAMETER 12 VALUE 7 SIZE 1 BYTE On ZSE18 Motion Sensor >>>>>> Filled in values in notification sensor node and pressed SET CONFIGURATION Sun 09/12/2021 12:28:17 PM : [ZW-TX-FAILED] enc=Fail uid=88.0 cmd=0x70.04 CONFIGURATION Sun 09/12/2021 12:28:19 PM : [ ZW088_1] ERR 1 Sun 09/12/2021 12:28:19 PM : [ZW-TX-FAILED] enc=Fail uid=88.0 cmd=0x70.04 CONFIGURATION Sun 09/12/2021 12:28:24 PM : [ ZW088_1] ERR 0 Sun 09/12/2021 12:28:24 PM : [ZW-TX-FAILED] enc=Fail uid=88.0 cmd=0x70.04 CONFIGURATION Sun 09/12/2021 12:28:24 PM : [ ZW088_1] ERR 1
