rodgetk
  1. Same issue for me, tried suggested procedure with the push button, and get this in the /var/udx/logs/log Updating FreeBSD repository catalogue... FreeBSD repository is up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... Fetching meta.conf: . done Fetching packagesite.pkg: ... done pkg: -----BEGIN PUBLIC KEY----- ..... -----END PUBLIC KEY----- : rsa signature verification failure pkg: Invalid signature, removing repository. Unable to update repository udi Error updating repositories!
  2. Exact same situation and issue for me, just got my new eisy today, also stuck on 5.5.9, planning upgrade and migration from old isy994 including Z-Wave/Matter USB.
  3. I have the exact same issue. No automatic updates, I have to Query it for it to update temperature. I also run FW 5.3.0, and have one DS18B20 attached to it.
  4. Michael, I followed the instructions in the document for register the my ISY 994iZ with PG&E HAN smart meter, with no success. All steps, getting the EUID, and Install Code, having PG&E register them etc, worked, it is the final pairing that was not success. PG&E could never see the ISY and I could never see the meter. (They did a ping test, and could not see the ISY during that test either). I saw on the forum that the install code length mattered for PG&E. I did choose a 24 Bytes install code length, but the ISY generated a 28 Characters long code (4 extra characters)?? Also, the PG&E technical person I spoke to confirmed that all other customers she worked with uses a 16 bytes character code. So now to my question, I noted that I can erase the install code and regenerate a new one, but if I select 16 bytes in the pull down menu on the Dashboard it generates 20 character code, and if choose the 12 byte, it does generate a 16 byte code. So should I pick 12 byte code, and retry? Also, I noticed that the Network status "Network" never reported any state like "scanning", "down" etc. I only got Time "Mon 2013/12/30... | Unsynchronized" and Meter "All OK" P.S. I'm on 4.1.1 Thanks, /Roger
